espeasy mqtt neopixel openhab
mrcage
#1 Post by mrcage » 03 Nov 2017, 23:36
Hi there,
I'm pretty stuck controlling the neopixel on ESP easy by openhab.
I configured a device: NeoPixel - Candle LedStrip - GPIO 5 - Color, Type, Brightness
MQTT is configured well, I see each 60 seconds the values are updated in openhab.
It seems however not possible to send date from either MQTT.fx or OpenHab. whatever value I send it will not update.
All seems running fine, if I change type,color directly from ESP easy it works (just about 20 pixels though).
ITEMS:
Number	LedStrip_type	"LedStrip Type [%s]"	            <switch>	    (tuin, LedStrip)        {mqtt=">[broker:/IoTCage107/LedStrip/Type:command:*:default]"}
Color	LedStrip_color	"LedStrip Color [%s]"	            <slider>	    (tuin, LedStrip)        {mqtt=">[broker:/IoTCage107/LedStrip/Color:command:*:default]"}
Number	LedStrip_bright	"LedStrip Brightness [%s]"         	<dimmer>        (tuin, LedStrip)        {mqtt=">[broker:/IoTCage107/LedStrip/Brightness:command:*:default]"}
LOGFILE OPENHAB:
23:28:35.302 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'LedStrip_type' received command 2
23:28:35.310 [INFO ] [marthome.event.ItemStateChangedEvent] - LedStrip_type changed from 6 to 2
LOG # in MQTT.fx:
2017-11-03 23:28:35,310  INFO --- MqttFX ClientModel             : messageArrived() with topic: /IoTCage107/LedStrip/Type
2017-11-03 23:28:35,310  INFO --- MqttFX ClientModel             : messageArrived() added: message #75 to topic '/IoTCage107/LedStrip/Type'
Connections seems fine, what do I miss? please advice
