Only two pins work with motion detectors??
Posted: 10 Nov 2017, 09:08
by supplex
Hi!
Just started my descent into the world of little devices that need a completely different way of interaction than the full fledged operating systems im used to
Yesterday i started a little project to open up my old alarm system and moving all the motion detectors one by one over to my v2 2866 ESP-12E running on ESP Easy mega 2.0.0. but noticed that i only got response on two motion detectors and 3 other ones do not seem to trigger anything at all. Could be defective sensors but i connected all of them to the working gpio ports and all of them respond nicely. I've also tried older firmware but it doesnt make a difference in which port responds.
So i'm a bit stuck...my thought was that i had around 6 to 7 usable pins but every gpio pin except GPIO0 and GPIO2 do not trigger any status at movement.
I'm sure this is my lack of knowledge so can someone point out what i did wrong or forgot to read?
Re: Only two pins work with motion detectors??
Posted: 10 Nov 2017, 10:45
by supplex
Update: after testing with a switch and leds it seems all the ports are working. gpio0 and gpio2 do seem to have a default high status, the others do not. But after manually setting the status to high on for example, gpio15 it does change the state of the motion detector but does not register motion or change its state.
Posted: 10 Nov 2017, 11:10
by grovkillen
Posted: 10 Nov 2017, 12:17
by supplex
Thnx, read it and still troubleshooting the possible issues.
Have scoured the internet trying to find a reason why gpio0 and 2 do work with triggering a state when motion is detected but why this does not work on the other ports. Have tried to change bootmodes for the pins, checking cables, see if ground is properly connected.
It does register the first state when i plug it in on all the ports, but triggering motions afterwards does not happen except for gpio0 and 2.
Posted: 10 Nov 2017, 12:42
by grovkillen
What PIR sensor are you using?
Posted: 10 Nov 2017, 12:57
by vader
Normally GPIO-0 and GPIO-2 are no problem. Disable any Pull-Ups in the settings (e.g. switch input for the HC-SR501) and all is fine! You can define the used GPIO port as Input under Hardware. That should work (I have it in use)....
Posted: 10 Nov 2017, 13:57
by Shardan
GPIO0 and GPIO2 are pulled up (hopefully) by external resistors, otherwise the ESP8266 starts with SD-Mode or in flash mode or something alike.
GPIO's 0,2 and 15 need predefined levels for correct booting so be aware none of your sensors triggers when ESP is booting.
Some more info would be helpfull:
Can you provide a schematic please? Or a photo?
A screenshot of the switch task configuration (Click "Edit" in the device list) is often helpful too.
Did you use pullup resistors? Just a switch connected to a GPIO might be not enough.
This might be the reason why GPIO0 and GPIO2 work but others do not.
Posted: 10 Nov 2017, 14:09
by supplex
Bit difficult to say which pirs they are. The pirs are from an old (analog) alarm system, all pirs are practically part of the wall so cant see the backside of the pir. I left the 12v connected to the alarm box to power all pirs and used the ground and v3.3 volt wire on the esp.
I tried disabling all pull up sensors and setting all gpio ports to input. Disconnected all pirs and testing only one at the moment.
Following shows up in the log when connected to gpio0 or gpio2
140658 : EVENT: Overloop#Motion=1.00
143761 : SW : State 0
143761 : EVENT: Overloop#Motion=0.00
145049 : SW : State 1
145049 : EVENT: Overloop#Motion=1.00
148097 : SW : State 0
148097 : EVENT: Overloop#Motion=0.00
But once i connect the same pir i'm testing with to a different gpio port the only trigger that gets logged is
490245 : SW : State 0
490272 : EVENT: 13#Motion=0.00
Already reflashed it with different versions but no success
Posted: 10 Nov 2017, 14:16
by Shardan
Shardan wrote: ↑10 Nov 2017, 13:57
Did you read it?
Posted: 10 Nov 2017, 14:33
by vader
Stupid question: What is the output level in V of your PIRs, when they are old and work with 12V as you wrote? Because, old hardware and 3.3V....!?
Posted: 10 Nov 2017, 14:49
by supplex
@Shardan, yes. Havent used external pullup resistors but did connect one just now to check and see if there was any change in behaviour. Sadly no difference or state change based on movement.
I measured around around 3.2 to 3.4v when triggered before i started the project. Otherwise i wouldn't have pulled apart the alarmsystem
but the fact that two ports are able to trigger state changes is hope enough for me that the system is able to register the correct values and notify upon them.
Posted: 10 Nov 2017, 16:03
by vader
I think it would be a good idea to provide us with some screen shots of your config. Pics say more than 1000 words, as you know...
Posted: 10 Nov 2017, 16:26
by supplex
You're right. Had to take a bit of time to open up stuff for proper pics.
Don't mind the messy cabling
Underneath the controlbox for the alarm panel. The red/blue cabling (12v) and the white cabling (0v) in the red circle on the alarm panel are for powering the pirs. The green circle shows the ground wires on the breadboard and pins for the alarm cable on the right side of the board (3v)
Right now i've unplugged the ESP from the breadboard and only connected the ground line to the board and one single pir alarm cable to test all the gpio pins.
I've managed to open up one of the pirs which also includes a small schematic of the connections. If a better quality pic of the cabling is required please let me know.
Posted: 10 Nov 2017, 16:46
by vader
The cabeling looks in fact a bit wild!
But I mean some screen shots of the ESP Easy config pages. My thought is, that there is something wrong.
Posted: 10 Nov 2017, 17:02
by supplex
Haha i know, typical engineer trait i guess. I'll fix it up once i get everything up and working
Underneath screenshots of certain settings in the esp.
The hal device works, the overloop device too, the woonkamer device does not and all other gpio pins i tried do not work either.
And two devices, one on a pin that works and the other that doesn't
Posted: 10 Nov 2017, 17:14
by vader
Ok, that looks good so far I can see. A bit careful with the use of GPIO-0. If it is LOW during boot, you enter flash mode! Have you connected the GPIOs direct with GND / 3.3V to see if the state change?
Posted: 10 Nov 2017, 17:32
by supplex
Thanks for the heads up on gpio 0
Yes gpio 13 for example does trigger if i directly connect it to ground. So the pins are fine, the motion detector is doing its work perfectly on gpio0 and gpio2. But once the pir is connected to gpio 13 for example it does not trigger anything.
Posted: 10 Nov 2017, 17:47
by vader
Ok, it seems that GPIO-0 and GPIO-2 have already an internal pull-up!? So enable pull-up in the config of woonkamer for GPIO-10 and check what happens. Have the outputs of the PIRs open collector? Then we need the pull-ups....
And I found this and maybe helpful why GPIO-0 and GPIO-2 works....
https://www.forward.com.au/pfod/ESP8266 ... index.html
https://tttapa.github.io/ESP8266/Chap04 ... oller.html
Posted: 10 Nov 2017, 18:20
by supplex
Enabled pull up for gpio 10 and tested functionality. taking the plug off the pin and putting it back gives the following log
141741 : SW : State 1
141757 : EVENT: Woonkamer#Motion=1.00
142977 : SW : State 0
142977 : EVENT: Woonkamer#Motion=0.00
But afterwards it does not trigger anymore. Tried it to be sure with gpio13 as well and a different pir and same story.
Thanks for the urls by the way
gives me something to read up on
Posted: 10 Nov 2017, 19:19
by vader
That's strange....
And the ESP with direct connection to GND works like expected? Have the PIRs a re-trigger delay?
Posted: 10 Nov 2017, 20:09
by grovkillen
I wonder what the voltage for LOW is (for the output from the PIR). Might be too high?
Posted: 11 Nov 2017, 13:41
by supplex
Ok, extra info after training my dog to trigger the pir in the hallway
Low is 0.7v
High is 1.6v
So i'm seeing a bit of a difference in voltage and guess i mistook the high output on the esp for the triggervalue
Would this be not enough of a difference in voltage? My idea is that if gpio0 and 2 are able to succesfully trigger each time movement is detected that this should be possible on the other ones as well.
Posted: 11 Nov 2017, 14:19
by vader
This values call for trouble, I would say.
Why is HIGH so low with 1.6V? That will never work stable. So, you should fix that first, that we have proper H/L-levels for the ESP. In this time you can set your dog in stand-by mode.....
Posted: 11 Nov 2017, 15:08
by supplex
Good news, managed to fix it by removing the resistors in the pir.
As you can see on the previous picture i posted of the inner workings there are two connected resistors between 3 connections for the tamper protection. Those little buggers messed it up, after removing them all pirs started communicating on all gpio pins! Now on to integrating the bunch into Home Assistant.
So problem solved, and learned a bunch of things about the esp. Thanks for the help, the ideas and the articles
Posted: 11 Nov 2017, 17:58
by grovkillen
Happy to have assisted.
Posted: 11 Nov 2017, 22:19
by grovkillen
For info, the ESP are expecting approx these levels for high and low.
High: 3.3V-2.4V
Buffer: 2.39V-0.81V
Low: 0.8V-0.0V
