Increase number of devices
Posted: 25 Nov 2017, 23:51
by tuxmartin
I'm using ESPeasy v2.0.0-dev12. Firmware has limit to 12 devices.
Is possible to increase this limit?
I would like to connect 5 relays (Switch input) and 10 DS18B20 sensors on one gpio pin.
For each relay I need "virtual mqtt device" (Output - (Domoticz MQTT helper)).
I would like to add devices for system states: uptime, wifi signal and freemem - it is next 3 devices.
Is there any reason for only 12 devices?
Re: Increase number of devices
Posted: 25 Nov 2017, 23:55
by TD-er
How are you going to connect the 5 relais?
Finding 5 free GPIO's is already hard and then you also need one for the 1-wire.
Posted: 26 Nov 2017, 00:01
by tuxmartin
I'm using Wemos D1 mini
https://wiki.wemos.cc/products:d1:d1_mini
I found on wiki
Why only 12 tasks?.
But there is no info how to compile firmware with more devices support.
Posted: 26 Nov 2017, 00:36
by tuxmartin
I found limits in file
ESPEasy.ino:
#define TASKS_MAX 12 // max 12!
#define CONTROLLER_MAX 3 // max 4!
#define NOTIFICATION_MAX 3 // max 4!
What is the reason for comments with exclamation mark?
Posted: 26 Nov 2017, 01:05
by Domosapiens
Look here
https://github.com/letscontrolit/ESPEasy/issues/590
Hexenmeister explains ....see:
This is possible (up to about 28 without enlargement of config.dat), but some addresses have to be recalculated ...
#define DAT_OFFSET_TASKS 4096 // each task = 2k, (1024 basic + 1024 bytes custom), 12 max
#define DAT_OFFSET_CONTROLLER DAT_OFFSET_TASKS + (DAT_TASKS_SIZE * TASKS_MAX) // each controller = 1k, 4 max
#define DAT_OFFSET_CUSTOM_CONTROLLER DAT_OFFSET_CONTROLLER + (DAT_CUSTOM_CONTROLLER_SIZE * CONTROLLER_MAX) // each custom controller config = 1k, 4 max.
This recalculation is a clever way, that I didn't know a half year ago.
Without that recalculation I was able to run 24 tasks, but memory of the first controller position is overwritten,
so I used the second controller position.
Posted: 27 Nov 2017, 17:16
by tuxmartin
Thank you, it works!
Posted: 27 Nov 2017, 18:47
by danmero
Why someone will waste a Task/Device for a system variable, can't be changed remotely anyway and you can publish from rules.
In any case use a
$1IO Expansion Board I2C or
$1.4 IO Expansion Board I2C that will save you IO on the main board.
You can trigger multiple/different GPIO using a single mqtt import/rules and %eventvalue% variable.
Regards,
Posted: 27 Nov 2017, 19:19
by Shardan
Just as long as you use it as an output.
Use a 16port MCP21017 as an input and you will see...
Rgrds
Posted: 27 Nov 2017, 19:42
by papperone
Shardan wrote: ↑27 Nov 2017, 19:19
Rgrds
I support this as I'm designing new PCBs MCP23017 based (same as the one I've already for 8 relays + 8 inputs) and one of them I thought to have it 16 inputs, stack-able to be able to connect up to 8 (as MCP23017 can be set up to 8 different addresses) and go up to 128 inputs which of course will make ESPEasy completely unusable and I'm really puzzled on how to overcome this limits (power-wise ESP8266 has the capability to handle that many logical inputs, simply not possible with current ESPEasy design)
Posted: 27 Nov 2017, 19:49
by Shardan
I've a similiar circuit already running with PCF8574, stackable PCB......
That's why i suggested some changes on github already.
Posted: 27 Nov 2017, 20:00
by maluko
Rgrds
i have a home made board with 2 mcp but they dont work at same time because only has one i2c adress, even with the different gnd chant dont work.
Posted: 27 Nov 2017, 20:11
by Shardan
Don't leave adress inputs "floating".
The address inputs need Vcc or ground. I've a 10KOhm pull up resistor on all Ax-Inputs and jumpers to set them to ground as necessary.
Posted: 27 Nov 2017, 22:13
by danmero
I use the expander for both input and output and works as expected, the only limitation is that you have to waste a Task for each input.
Anyway I never use built in GPIO for direct input or output as per say, only via expander and/or optoisolator.
Regards,
Posted: 28 Nov 2017, 14:32
by maluko
Shardan wrote: ↑27 Nov 2017, 20:11
thanks shardan
can you explain with a schematic?
Posted: 28 Nov 2017, 16:45
by Shardan
danmero wrote: ↑27 Nov 2017, 22:13
Regards,
You use a 23017 with 16 inputs on ESPEasy with 12 tasks?
As said i use a similiar solution with two PCF8574, one as input, one as output, that works flawlessly.
Anyways i need much more then 8 or 16 inputs so i've requested a solution on github already, just one task per
PCD8574 or MCP23017 just reading the byte (PCF8574) or word (MCP23017) and giving the binary value back to the home control.
Posted: 28 Nov 2017, 16:46
by Shardan
As soon as i'm home
Posted: 28 Nov 2017, 18:06
by Shardan
And here we go:
- MCP_Addr.jpg (309.26 KiB) Viewed 19241 times
Posted: 28 Nov 2017, 21:00
by danmero
Shardan wrote: ↑28 Nov 2017, 16:45
As a note, you can use one device for both input and output(on different pins).
Great idea.
Posted: 28 Nov 2017, 22:35
by Shardan
danmero wrote: ↑28 Nov 2017, 21:00
I know - it's a remote control that uses 8 buttons and 8 status LED's.
- rc_8x8_1280.jpg (655.94 KiB) Viewed 19220 times
I was wondering if i should use a 23017 but the PCF8574 were in the shelf and PCB layout is easier for this configuration
