Feature request. Actually a UI web page request
- budman1758
Hello all.
Something that I think would be handy is to put the command input box at the top of the Tools page instead of the bottom. I find it quite a hassle when prototyping something to constanly have to scroll down to the bottom of the page to get back to the command box. It would also be nice if the cursor focus would be in the box when the page loads like most browsers focus on the search box. (something that actually annoys me most of the time). Just a minor thing.
What do all of you think?
Or.... Perhaps it could have its own page?
Re: Feature request. Actually a UI web page request
I think the entire web-interface would benefit from a good redesign.
Would it be good enough if you had a single link to open that command page?
Not to clutter the top bar too much, but just to allow quick access to certain sub pages.
I always like the "basic"/"advanced" approach. Not to overwhelm the new users, but allow advanced features for the more advanced users.
You can always trigger it with this URL:
<espeasyip> is the IP
<command> is the command you want to execute
http://<espeasyip>/tools?cmd=<command>
Maybe a plugin to disable/enable the WebUI from MQTT inport.
Regards,
Regards,
- budman1758
The single link idea sound pretty good. As for the entire web interface redesign methinks not a bad idea but probably a bit much to ask.TD-er wrote: ↑03 Dec 2017, 10:06 I think the entire web-interface would benefit from a good redesign.
Any web design gurus wanna take a swing at it?
This is quite true but adds to the amount of keystrokes necessary......grovkillen wrote: ↑03 Dec 2017, 11:11 You can always trigger it with this URL:
<espeasyip> is the IPCode: Select all
I was thinking to move the command box to the top vs the bottom would be the easiest to implement.
You can also run GET requests from the commandline (e.g. using curl), which makes it perhaps easier to test?budman1758 wrote: ↑04 Dec 2017, 09:31 [...]This is quite true but adds to the amount of keystrokes necessary......grovkillen wrote: ↑03 Dec 2017, 11:11 You can always trigger it with this URL:
Or external tools like Postman, which has several somewhat bookmark like queries you can store and adapt.
+1 for moving the command to the top of the page. For me, it would make it easier to use.
AndrewJ
AndrewJ
I made a PR for it just now. We'll see if it is accepted.
Many thanks.
PR is now merged and will appear in the dev13 release. If you cannot wait you can compile a version on your own.
