ESP32 boards
karl222
Re: ESP32 boards
#251 Post by karl222 » 25 Mar 2018, 21:55
It is not possible to set IP Settings in Config tab. Can this somehow be changed.
regards
karl
AndrewJ
Re: ESP32 boards
#252 Post by AndrewJ » 25 Mar 2018, 22:10
Hi Karl,
Great news! :D
Out of interest, which ESP32 model is it you are using there?
I agree with you, special thanks to LisaM for all her hard work on this! :D
Andrew
LisaM
Re: ESP32 boards
#253 Post by LisaM » 25 Mar 2018, 23:30
karl222 wrote: 25 Mar 2018, 21:55 It is not possible to set IP Settings in Config tab. Can this somehow be changed.
regards
karl
Hmmm, checking...
@karl: can you verify the correct values are written in the config?
To verify:
- Goto webgui
- tools
- filesystem - files
- click on config
- click on network
- click the edit button
"ssid": and "key": should have the right values!
After changing the ssid values, a reboot is necessary.
I'm also busy with finding out why on all platforms async is work, except for the esp32... :x
karl222
Re: ESP32 boards
#254 Post by karl222 » 26 Mar 2018, 06:34
Ssid and pw do have the right values, but i can’t enter values in ip settings field, they are greyed out...
karl222
Re: ESP32 boards
#255 Post by karl222 » 26 Mar 2018, 08:28
AndrewJ wrote: 25 Mar 2018, 22:10 Hi Karl,
Great news! :D
Andrew
it is running on a NODEMCU ESP-32S V1 but i haven’t checked the other one yet.
regards
karl
LisaM
Re: ESP32 boards
#256 Post by LisaM » 26 Mar 2018, 09:50
karl222 wrote: 26 Mar 2018, 06:34 Hi
So far, when using wifi uPyEasy is using dhcp to get the ip-address. Do you have a need to specify a specific ip-address?
karl222
Re: ESP32 boards
#257 Post by karl222 » 26 Mar 2018, 10:05
Generally yes, i do most of stuff with fixed ip but i can do it via fixing on router level as well...
Karl
AndrewJ
Re: ESP32 boards
#258 Post by AndrewJ » 26 Mar 2018, 18:36
LisaM wrote: 26 Mar 2018, 09:50
Hi Lisa,
Just chipping in here if I may. In my case I would like to specify a fixed IP-address within the ESP32, please, as my wireless router only allows a limited number of fixed addresses in its table. :cry:
Cheers
Andrew
LisaM
Re: ESP32 boards
#259 Post by LisaM » 26 Mar 2018, 22:26
V0.2.2 released, firmware can be found in the release section.
Issues solved:
- Async ESP32 not working (work-around implemented: devices should be sending data to domoticz now)
Features added:
- Fixed IP Address possible for ESP32
BertB
Re: ESP32 boards
#260 Post by BertB » 26 Mar 2018, 23:12
LisaM wrote: 26 Mar 2018, 22:26 V0.2.2 released, firmware can be found in the release section.
Issues solved:
Features added:
yep, it works :D
But there still is something funny going on.
When I first create a BME280 device and then a Dallas device, right after the selection of the dallas and clicking submit, the WEB connection with the ESP is broken and a have to reset the ESP board.
After that, I can continue setting up the dallas device.
BertB
Re: ESP32 boards
#261 Post by BertB » 26 Mar 2018, 23:34
Update:
The Dallas show up correctly in Domoticz.
The BME has two devices in Domoticz, one for temp and one for weather.
Neither one sohwas values, but 'last seen' is correct.
LisaM
Re: ESP32 boards
#262 Post by LisaM » 27 Mar 2018, 00:07
BertB wrote: 26 Mar 2018, 23:34 Update:
BME should be one device:
1244 VirtualSwitches 1452C 1 uPyEasy Test Temp_Hum_Baro Temp + Humidity + Baro THB1 - BTHR918, BTHGN129 0, 25.9326.24707;0;1014.779;0
AndrewJ
Re: ESP32 boards
#263 Post by AndrewJ » 27 Mar 2018, 16:34
Issues solved:
Features added:
Hi Lisa,
Thanks for all your hard work on this! :)
I just tried the latest (20180326) binaries for ESP32 on my Lolin32 Lite board. Getting closer but still some issues.
2048.bin:
Working with only the BME280 and DomoticzMQTT, can see Async processes running, values being updated - all good.
BUT, when I tried to add DS18B20, after clicking Submit to select DS18B20 the bottom two thirds of the screen was the one for BME280 (I2C address, three value settings (Temp, Press, Hum)!
I tried 'Submit' at the bottom anyway...
The main Devices page showed the "real" BME280, plus a device with three values (Temperature, Pressue, Humidity)! (It's a mutant!! :o )
4096.bin:
Similar to above. OK with Domoticz and BME280, Async process running, values being updated, all good.
This time when I tried to add DS18B20, it crashed as soon as I clicked 'Submit' to select it. See log below.
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Page
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: POST
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: id
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: 0
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: New Plugin: 4
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: Create Device
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choosen: 4
2018-03-27 15:06:21 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with plugin: 4
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Protocols: GetQueue controller 192.168.1.12-Domoticz MQTT-1
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instantiate plugin: DS18B20
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 init
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used:
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Hal: pin =
  File "boot.py", line 3, in <module>
  File "upyeasy/__init__.py", line 65, in main
  File "picoweb/__init__.py", line 298, in run
  File "uasyncio/core.py", line 146, in run_forever
  File "uasyncio/core.py", line 101, in run_forever
  File "picoweb/__init__.py", line 210, in _handle
AttributeError: 'Log' object has no attribute 'exc'
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-479-gb63cc1e-dirty on 2018-03-26; ESP32 module with ESP32
Type "help()" for more information.
Hope this helps to hunt down the problem.
So it looks like Async processes are fixed now, but an issue with DS18B20.
I really appreciate all the work you are doing on this. If there's any more information you'd like, let me know. Can I help in any way with debugging?
Cheers
Andrew
Martinus
Re: ESP32 boards
#264 Post by Martinus » 27 Mar 2018, 16:59
With the latest firmware, the Dallas sensor is working towards Domoticz and has been running for several hours.
One strange thing however:
This module has previously been used to check Dallas on ESPEasy32 and it has two dallas sensors attached (same pin).
uPyEasy has only 1 device configured but it seems to read both sensors anyway and it sends them both to Domoticz using the same IDX.
LisaM
Re: ESP32 boards
#265 Post by LisaM » 27 Mar 2018, 17:17
Martinus wrote: 27 Mar 2018, 16:59 With the latest firmware, the Dallas sensor is working towards Domoticz and has been running for several hours.
The ds18b20 plugin was a rush job to get it working, it was never intended to read two dallas sensors. I'm amazed it can actually do that... ;)
It definitely needs some improvements...
BertB
Re: ESP32 boards
#266 Post by BertB » 27 Mar 2018, 19:49
LisaM wrote: 27 Mar 2018, 00:07
I created a dummy device in Domotic, type: TEMP+HUM+BARO
upyeasy1 Ja Dummy (Does nothing, use for virtual switches only) Maak virtuele sensoren
And it appears like this in the devices list:
361 upyeasy1 141B9 1 UPYEASy Temp + Humidity + Baro THB1 - BTHR918, BTHGN129 0, 18.045.31738;0;1005.792;0
LisaM
Re: ESP32 boards
#267 Post by LisaM » 27 Mar 2018, 20:01
Looks like a Domoticz bug... The values are there...
AndrewJ
Re: ESP32 boards
#268 Post by AndrewJ » 27 Mar 2018, 21:38
Issues solved:
Features added:
Update:
I forgot to mention before, the Fixed IP Address is working for me. Thanks! :D :D
Andrew
BertB
Re: ESP32 boards
#269 Post by BertB » 27 Mar 2018, 22:08
LisaM wrote: 27 Mar 2018, 20:01 Looks like a Domoticz bug... The values are there...
Probably not.
This is with the BME on a ESPEasy:
364 ESP16 141BC 1 BME1 Temp + Humidity + Baro THB1 - BTHR918, BTHGN129 22.0 C, 37 %, 1005 hPa
It looks like the string has a different format then.
LisaM
Re: ESP32 boards
#270 Post by LisaM » 27 Mar 2018, 22:22
BertB wrote: 27 Mar 2018, 22:08
Probably not.
Owwwww, then it must be a uPyEasy domoticz http controller bug! I'll check this out...
BertB
Re: ESP32 boards
#271 Post by BertB » 09 May 2018, 11:54
With the latest release, after installation and restart, I get:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3e (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4464
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:11816
entry 0x4007a9fc
I (467) cpu_start: Pro cpu up.
I (467) cpu_start: Single core mode
I (468) heap_init: Initializing. RAM available for dynamic allocation:
I (471) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (477) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (483) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (490) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (496) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (502) cpu_start: Pro cpu start user code
I (73) cpu_start: Starting scheduler on PRO CPU.
I (140) modsocket: Initializing
  File "ulog.py", line 110, in do_log
  File "syslog_sink.py", line 78, in log
  File "usyslog.py", line 60, in error
  File "usyslog.py", line 82, in log
OSError: 118
2000-01-01 00:00:02 [error] uPyEasy: Hal: esp32, ssid empty
  File "syslog_sink.py", line 76, in log
  File "usyslog.py", line 72, in warning
OSError: 118
2000-01-01 00:00:02 [warning] uPyEasy: Hal: init esp32 network: AP mode
I (2890) wifi: wifi firmware version: ebd3e5d
I (2890) wifi: config NVS flash: enabled
I (2890) wifi: config nano formating: disabled
I (2900) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2910) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2920) wifi: Init dynamic tx buffer num: 32
I (2920) wifi: Init data frame dynamic rx buffer num: 64
I (2930) wifi: Init management frame dynamic rx buffer num: 64
I (2930) wifi: wifi driver task: 3ffd0f0c, prio:23, stack:4096
I (2940) wifi: Init static rx buffer num: 10
I (2940) wifi: Init dynamic rx buffer num: 0
I (2940) wifi: wifi power manager task: 0x3ffd5b5c prio: 21 stack: 2560
I (3000) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (3000) wifi: mode : null
I (3010) wifi: mode : softAP (30:ae:a4:22:e8:1d)
I (3010) network: event 13
I (3120) network: event 14
I (3120) network: event 13
2000-01-01 00:00:04 [info] uPyEasy-uPyEasy: Main: uPyEasy running in Access Point mode
2000-01-01 00:00:04 [info] uPyEasy-uPyEasy: Main: uPyEasy Main Async Loop on IP adress: 0.0.0.0:80
After that, no communication possible.
BertB
Re: ESP32 boards
#272 Post by BertB » 09 May 2018, 12:13
The above happens with two versions of the ESP32 board, with both the 4096 and the 2048 version.
With a third board, I got:
D:\Program Files\Python\Python36>python esptool-master\esptool.py --port COM5 write_flash --compress 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_v030_20180506_test_esp32_2048.bin
esptool.py v2.3-dev
Connecting....
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0220
Compressed 1278000 bytes to 728894...
Writing at 0x0007d000... (71 %)
A fatal error occurred: Failed to write compressed data to flash after seq 31 (result was C100)
BertB
Re: ESP32 boards
#273 Post by BertB » 09 May 2018, 12:16
After a second attempt with one of the boards, with the 2048 version, I got:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (465) cpu_start: Pro cpu up.
I (465) cpu_start: Single core mode
I (466) heap_init: Initializing. RAM available for dynamic allocation:
I (469) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (475) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (481) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (488) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (494) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (500) cpu_start: Pro cpu start user code
I (71) cpu_start: Starting scheduler on PRO CPU.
  File "upyeasy/__init__.py", line 46, in main
  File "upyeasy/init.py", line 206, in init
  File "upyeasy/db.py", line 593, in getrow
  File "upyeasy/db.py", line 591, in getrow
  File "filedb.py", line 111, in get
ValueError: syntax error in JSON
MicroPython v1.9.3-549-gbe9277b-dirty on 2018-05-06; ESP32 module with ESP32
>>> upyeasy.setwifi('xxxxxx','yyyyyyyyy')
cache deleted: _config
>>> import machine
>>> machine.reset()
Guru Meditation Error: Core  0 panic'ed (IllegalInstruction)
. Exception was unhandled.
Guru Meditation Error: Core  0 panic'ed (|▒?22@P▒?s▒?▒▒?▒▒?22@3)
? Exception w22@3Guru Meditation Error: Core  0 panic'ed (|▒?22@P▒?s▒?▒▒?▒▒?22@3        )
? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3        ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error:        Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Erro        r: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Er        ror: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation        Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditatio        n Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditat        ion Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Medit        ation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Med        itation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru M        editation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru        Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Gu        ru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #        Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed        #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'        ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 pani        c'ed #▒▒?22@3Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Cor        e  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: C        ore  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error:        Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Erro        r: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Er        ror: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation        Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditatio        n Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditat        ion Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Medit        ation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Med        itation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru M        editation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru        Meditation Error: Core  0 panic'ed #▒▒?22@3Guru Meditation Error: Core  0 panic        'ed #▒▒?22@3Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core        0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Unknown reasonGuru Medita        tion Error: Core  0 panic'ed #Unknown reasonGuru Meditation Error: Core  0 panic        'ed #Unknown reasonGuru Meditation Error: Core  0 panic'ed #▒@pT▒?? Exception w2        2@3ets Jun  8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (466) cpu_start: Pro cpu up.
I (466) cpu_start: Single core mode
I (470) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (476) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (482) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (495) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (501) cpu_start: Pro cpu start user code
LisaM
Re: ESP32 boards
#274 Post by LisaM » 09 May 2018, 17:50
Hi Bert,
There have been database changes, can you erase the esp32, reflash and then try again? If you have settings in the database you want to remember, save/write/note it down first.
Cheers,
Lisa
BertB
Re: ESP32 boards
#275 Post by BertB » 09 May 2018, 19:53
LisaM wrote: 09 May 2018, 17:50 Hi Bert,
Cheers,
Lisa
Hi Lisa,
I did this esptool.py --port COM5 erase_flash as my first action on all boards.
LisaM
Re: ESP32 boards
#276 Post by LisaM » 16 May 2018, 20:59
Hi Bert,
This might be due to a to long build version in the config table, if have shortened it and put a new firmware version in the release section.
Can you erase/flash the esp32 again?
Cheers,
Lisa
BertB
Re: ESP32 boards
#277 Post by BertB » 17 May 2018, 20:09
Hi Lisa,
This happends after loading the 4096 version. It stops right after the 80.
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
Falling back to built-in command interpreter.
OK
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (467) heap_init: Initializing. RAM available for dynamic allocation:
I (489) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (72) cpu_start: Starting scheduler on PRO CPU.
OSError: 118
OSError: 118
I (2990) wifi: wifi firmware version: ebd3e5d
I (2990) wifi: config NVS flash: enabled
I (2990) wifi: config nano formating: disabled
I (2990) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFU        SE
I (3000) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFU        SE
I (3020) wifi: Init dynamic tx buffer num: 32
I (3020) wifi: Init data frame dynamic rx buffer num: 64
I (3020) wifi: Init management frame dynamic rx buffer num: 64
I (3030) wifi: wifi driver task: 3ffd0f0c, prio:23, stack:4096
I (3030) wifi: Init static rx buffer num: 10
I (3040) wifi: Init dynamic rx buffer num: 0
I (3040) wifi: wifi power manager task: 0x3ffd5b5c prio: 21 stack: 2560
I (3100) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (3110) wifi: mode : null
I (3110) wifi: mode : softAP (30:ae:a4:0d:6a:bd)
I (3110) network: event 13
I (3220) network: event 14
I (3230) network: event 13
2000-01-01 00:00:05 [info] uPyEasy-uPyEasy: Main: uPyEasy running in Access Point mode
2000-01-01 00:00:05 [info] uPyEasy-uPyEasy: Main: uPyEasy Main Async Loop on IP adress: 0.0.0.0:        80
80
BertB
Re: ESP32 boards
#278 Post by BertB » 17 May 2018, 20:24
Okay.
When I after the 80 enter ctrl C, I get:
  File "upyeasy/__init__.py", line 85, in main
  File "upyeasy/__init__.py", line 83, in main
  File "picoweb/__init__.py", line 311, in run
  File "uasyncio/core.py", line 77, in run_forever
  File "uasyncio/__init__.py", line 69, in wait
KeyboardInterrupt:
MicroPython v1.9.3-549-gbe9277b-dirty on 2018-05-16; ESP32 module with ESP32
Afther that, I could enter the setwifi, the import machine and the machine.reset()
Thereafter I got:
>>> upyeasy.setwifi('wifiSSID','wifi password')
>>> import machine
>>> machine.reset()
I (139119) network: event 3
I (139119) wifi: flush txq
I (139119) wifi: stop sw txq
I (139119) wifi: lmac stop hw txq
? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3                                     ? Exception w22@3Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error:                                      Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Erro                                     r: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Er                                     ror: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation                                      Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditatio                                     n Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditat                                     ion Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Medit                                     ation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Med                                     itation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru M                                     editation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru                                      Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Gu                                     ru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #                                     Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed                                      #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'                                     ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 pani                                     c'ed #▒▒?22@3Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Cor                                     e  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: C                                     ore  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error:                                      Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Erro                                     r: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation Er                                     ror: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditation                                      Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditatio                                     n Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Meditat                                     ion Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Medit                                     ation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru Med                                     itation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru M                                     editation Error: Core  0 panic'ed #Guru Meditation Error: Core  0 panic'ed #Guru                                      Meditation Error: Core  0 panic'ed #▒▒?22@3Guru Meditation Error: Core  0 panic                                     'ed #▒▒?22@3Guru Meditation Error: Core  0 panic'ed #Guru Meditation Error: Core                                       0 panic'ed #ets Jun  8 2016 00:22:57
ho 0 tail 12 room 4
entry 0x4007a9fc
I (139) modsocket: Initializing
I (2829) wifi: wifi firmware version: ebd3e5d
I (2829) wifi: config NVS flash: enabled
I (2829) wifi: config nano formating: disabled
I (2829) system_api: Base MAC address is not set, read default base MAC address                                      from BLK0 of EFUSE
I (2839) system_api: Base MAC address is not set, read default base MAC address                                      from BLK0 of EFUSE
I (2849) wifi: Init dynamic tx buffer num: 32
I (2849) wifi: Init data frame dynamic rx buffer num: 64
I (2859) wifi: Init management frame dynamic rx buffer num: 64
I (2859) wifi: wifi driver task: 3ffd0f0c, prio:23, stack:4096
I (2869) wifi: Init static rx buffer num: 10
I (2869) wifi: Init dynamic rx buffer num: 0
I (2879) wifi: wifi power manager task: 0x3ffd5b5c prio: 21 stack: 2560
I (2939) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (2939) wifi: mode : null
I (2939) wifi: mode : sta (30:ae:a4:0d:6a:bc)
I (2949) wifi: STA_START
I (3799) wifi: n:7 1, o:1 0, ap:255 255, sta:7 1, prof:1
I (4349) wifi: state: init -> auth (b0)
I (4419) wifi: state: auth -> assoc (0)
I (4429) wifi: state: assoc -> run (10)
I (4439) wifi: connected with yyyyyy, channel 7
I (4449) network: event 4
I (5149) event: sta ip: xxxx, mask: xxxxxxx, gw: xxxxxxxxx
I (5149) network: GOT_IP
I (7429) wifi: pm start, type:0
2018-05-17 19:20:47 [info] uPyEasy-uPyEasy: Main: uPyEasy running in Station mod                                     e
2018-05-17 19:20:47 [info] uPyEasy-uPyEasy: Main: uPyEasy Main Async Loop on IP                                      adress: xxxxxxxxx:80
Now, something seems to be alive ...
