uPyEasy BETA-1 is available!
4 months ago, sept/2017, i started working on uPyEasy. Soon after that the first Alpha release where released, and a few people downloaded the firmware and tried it out. I've been building it for the last 4 months in a frantic, and my partner often called it 'obsessed' way of working. Development started from scratch, as an Data Architect is saw an opportunity to make a completely fresh start and choose NOT to reuse the existing C++ based source code of ESPEasy and only reuse the current web layout of ESPEasy(at least in the beginning). I wanted to use state of the art technology which are not part of ESPEasy, simply because they weren't available when ESPEasy was build, until a few months ago. Async, Threading, Templates on a SOC?, i would have been declared a mad women just a year ago.
I have kept uPyEasy's micropython sources secret, not to keep it for myself but to be enable to make fairly quickly very large changes to the source code.
Now i've entered a new phase of the development of uPyEasy, the Beta phase. Most important and large sections of uPyEasy are now stable enough to release the source code, albeit in beta format so that largescale changes are still possible but less likely. The source code will give more insight for those who wish to participate in the development of uPyEasy and lessen the fear of others that uPyEasy is actually a closed source application.
We'll it isn't because if have a proof that it is really open source: https://github.com/letscontrolit/uPyEasy
Starting right NOW all sources are available in the uPyEasy letscontrolit repository! Also two binaries have been created using these sources and placed in the beta section of the https://github.com/letscontrolit/uPyEasy/releases release section.
I invite everybody to download and try it out. For those among you that are developing ESPEasy and/or plugin's: come and take a look!
Re: uPyEasy BETA-1 is available!
Thanks Lisa,
but life is not only programming.
Great work, Lisa!
Awesome work!
Lisa,
again thank you for your great work!
I'm using the Beta-1 version but I'm seeing in the "System info" page that the version is 0.1 and build status is Alpha. Is it correct or I did some mistake? Thank you in advance for your answer.
Platform esp32
Version 0.1
Build Status Alpha
Build Version 57
Database Version 57
Micropython Version v1.9.3-255-g979c688-dirty on 2018-01-27
Machine Board ESP32 module with ESP32
Unique Identifier b'0\xae\xa4]\xb7<'
CPU Frequency b'0\xae\xa4]\xb7<'
Platform esp32
Version 0.1
Build Status Alpha
Build Version 57
Database Version 57
Oops, sorry for that!alpat59 wrote: ↑28 Jan 2018, 15:10 Lisa,
Platform esp32
Version 0.1
Build Status Alpha
Build Version 57
Database Version 57
I've build a new one with the correct build designation and version number and put it into the releases directory.
It's now as it should have been:
Platform esp32
Version 0.2.0
Build Status Beta
Build Version 59
The other version is the same, but i forgot to update the build/version number.
I'm looking at how github can autogenerate the build version.
I am doing some tests here and notice that:
response is very sluggish, especially while using the Hardware tab.
In the devices tab, I cannot select the switch, nor the DS18B20.
This is the fault I get:
stack: 2000 out of 15360
GC: total: 96000, used: 77024, free: 18976
No. of 1-blocks: 1382, 2-blocks: 150, max blk sz: 901, max free sz: 379
570498180.389 <HTTPRequest object at 3ffc49a0> <StreamWriter <socket>> "POST /device_setting?id=0"
2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Page
2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: Pages: POST
2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: id
2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: 0
2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: New Plugin: 4
2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: Pages: Create Device
2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choosen: 4
2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-01-28 23:43:04 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with plugin: 4
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instantiate plugin: DS18B20
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 init
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used: d0
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Hal: pin = d0
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Hal: pin esp32: 0
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugins: Loadform plugin dummy
2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 loadform
570498180.389 <HTTPRequest object at 3ffc49a0> <StreamWriter <socket>> AttributeError("'ds18_plugin' object has no attribute 'pincnt'",)
File "picoweb/__init__.py", line 186, in _handle
File "upyeasy/pages.py", line 1256, in devicesettingpage
File "upyeasy/plugin.py", line 126, in loadform
File "upyeasy/plugin.py", line 124, in loadform
File "upyeasy/plugins/ds18.py", line 92, in loadform
File "upyeasy/utils.py", line 407, in plugin_loadform
AttributeError: 'ds18_plugin' object has no attribute 'pincnt'
And the test plugin? It's a test plugin designed to always return 17 as value for testing purposes.BertB wrote: ↑28 Jan 2018, 23:46 I am doing some tests here and notice that:
This is the fault I get:Code: Select all
stack: 2000 out of 15360 GC: total: 96000, used: 77024, free: 18976 No. of 1-blocks: 1382, 2-blocks: 150, max blk sz: 901, max free sz: 379 570498180.389 <HTTPRequest object at 3ffc49a0> <StreamWriter <socket>> "POST /device_setting?id=0" 2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Page 2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: Pages: POST 2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: id 2018-01-28 23:43:02 [debug] uPyEasy-uPyEasy: 0 2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: New Plugin: 4 2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: Pages: Create Device 2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choosen: 4 2018-01-28 23:43:03 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-01-28 23:43:04 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with plugin: 4 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instantiate plugin: DS18B20 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 init 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used: d0 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Hal: pin = d0 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Hal: pin esp32: 0 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugins: Loadform plugin dummy 2018-01-28 23:43:05 [debug] uPyEasy-uPyEasy: Plugin: ds18 loadform 570498180.389 <HTTPRequest object at 3ffc49a0> <StreamWriter <socket>> AttributeError("'ds18_plugin' object has no attribute 'pincnt'",) Traceback (most recent call last): File "picoweb/__init__.py", line 186, in _handle File "upyeasy/pages.py", line 1256, in devicesettingpage File "upyeasy/plugin.py", line 126, in loadform File "upyeasy/plugin.py", line 124, in loadform File "upyeasy/plugins/ds18.py", line 92, in loadform File "upyeasy/utils.py", line 407, in plugin_loadform AttributeError: 'ds18_plugin' object has no attribute 'pincnt'
17 shows up in the devices list and it all seems to be ok, but then:
GC: total: 96000, used: 72224, free: 23776
No. of 1-blocks: 1200, 2-blocks: 153, max blk sz: 901, max free sz: 617
570570373.535 <HTTPRequest object at 3ffbb2d0> <StreamWriter <socket>> "GET /devices"
2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Pages: Entering Devices Page
2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-01-29 19:46:41 [debug] uPyEasy-uPyEasy: Plugins: Read device test
2018-01-29 19:46:41 [debug] uPyEasy-uPyEasy: Plugin: test read
GC: total: 96000, used: 82224, free: 13776
No. of 1-blocks: 1293, 2-blocks: 167, max blk sz: 901, max free sz: 371
570570421.218 <HTTPRequest object at 3ffbfe40> <StreamWriter <socket>> "GET /static/upyeasy.css"
GC: total: 96000, used: 83840, free: 12160
No. of 1-blocks: 1339, 2-blocks: 174, max blk sz: 901, max free sz: 371
570570421.218 <HTTPRequest object at 3ffc5370> <StreamWriter <socket>> "GET /static/upyeasy.js"
static/upyeasy.css
static/upyeasy.js
2018-01-29 19:47:03 [debug] uPyEasy-uPyEasy: Plugin: test process
File "main.py", line 2, in <module>
File "upyeasy/__init__.py", line 56, in main
File "picoweb/__init__.py", line 275, in run
File "uasyncio/core.py", line 138, in run_forever
File "uasyncio/core.py", line 97, in run_forever
File "upyeasy/plugins/test.py", line 107, in asyncprocess
File "upyeasy/utils.py", line 277, in plugin_senddata
NameError: name 'stype' is not defined
MicroPython v1.9.3-255-g979c688-dirty on 2018-01-27; ESP32 module with ESP32
Type "help()" for more information.
tested plugin test ... same output. I neededd to reset ESP32.
Both bugs fixed and new firmware uploaded. Please log these bugs in github, in this thread i might lose track of them...BertB wrote: ↑29 Jan 2018, 19:4817 shows up in the devices list and it all seems to be ok, but then:
stack: 2000 out of 15360 GC: total: 96000, used: 72224, free: 23776 No. of 1-blocks: 1200, 2-blocks: 153, max blk sz: 901, max free sz: 617 570570373.535 <HTTPRequest object at 3ffbb2d0> <StreamWriter <socket>> "GET /devices" 2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Pages: Entering Devices Page 2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-01-29 19:46:41 [debug] uPyEasy-uPyEasy: Plugins: Read device test 2018-01-29 19:46:41 [debug] uPyEasy-uPyEasy: Plugin: test read stack: 2000 out of 15360 GC: total: 96000, used: 82224, free: 13776 No. of 1-blocks: 1293, 2-blocks: 167, max blk sz: 901, max free sz: 371 570570421.218 <HTTPRequest object at 3ffbfe40> <StreamWriter <socket>> "GET /static/upyeasy.css" stack: 2000 out of 15360 GC: total: 96000, used: 83840, free: 12160 No. of 1-blocks: 1339, 2-blocks: 174, max blk sz: 901, max free sz: 371 570570421.218 <HTTPRequest object at 3ffc5370> <StreamWriter <socket>> "GET /static/upyeasy.js" static/upyeasy.css static/upyeasy.js 2018-01-29 19:47:03 [debug] uPyEasy-uPyEasy: Plugin: test process Traceback (most recent call last): File "main.py", line 2, in <module> File "upyeasy/__init__.py", line 56, in main File "picoweb/__init__.py", line 275, in run File "uasyncio/core.py", line 138, in run_forever File "uasyncio/core.py", line 97, in run_forever File "upyeasy/plugins/test.py", line 107, in asyncprocess File "upyeasy/utils.py", line 277, in plugin_senddata NameError: name 'stype' is not defined MicroPython v1.9.3-255-g979c688-dirty on 2018-01-27; ESP32 module with ESP32 Type "help()" for more information. >>>
The stack trace is helping me a lot to find these bugs!
Hi Lisa,
Thank you for the great work.....
I am trying to set up upyeasy on the TTGO board (ESP32+display+battery):
I get this message at startup:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4364
load:0x40078000,len:0
load:0x40078000,len:10992
entry 0x4007a6c4
I (440) cpu_start: Pro cpu up.
I (440) cpu_start: Single core mode
I (441) heap_init: Initializing. RAM available for dynamic allocation:
I (444) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (450) heap_init: At 3FFDCDD0 len 00003230 (12 KiB): DRAM
I (456) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (463) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (469) heap_init: At 4009005C len 0000FFA4 (63 KiB): IRAM
I (475) cpu_start: Pro cpu start user code
I (46) cpu_start: Starting scheduler on PRO CPU.
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-255-g979c688-dirty on 2018-01-28; ESP32 module with ESP32
And I get this error messages when I try to setup wifi:
>>> import network
>>> sta_if = network.WLAN(network.STA_IF); sta_if.active(True)
I (42943) wifi: wifi firmware version: 111e74d
I (42943) wifi: config NVS flash: enabled
I (42943) wifi: config nano formating: disabled
I (42943) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (42953) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (42973) wifi: Init dynamic tx buffer num: 32
I (42973) wifi: Init data frame dynamic rx buffer num: 64
I (42973) wifi: Init management frame dynamic rx buffer num: 64
I (42983) wifi: wifi driver task: 3ffe15dc, prio:23, stack:4096
I (42983) wifi: Init static rx buffer num: 10
I (42993) wifi: Init dynamic rx buffer num: 0
I (42993) wifi: Init rx ampdu len mblock:7
I (43003) wifi: Init lldesc rx ampdu entry mblock:4
I (43003) wifi: wifi power manager task: 0x3ffe850c prio: 21 stack: 2560
W (43013) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
Brownout detector was triggered
Guru Meditation Error of type IllegalInstruction occurred on core 0. Exception was unhandled.
Any Idea ?
It looks like it can't set MAC Address.....
Paolo
entry 0x4007a6c4
>>> import network
Any Idea ?
Paolo
- download.jpg (5.87 KiB) Viewed 34541 times
There's your cause: you have a power problem. It may be caused by poor quality usb cable, bad solder joints or low power from USB connector. If you can monitor 5v and 3.3v voltage on esp32 during startup then you may have some clue. Use a better usb power source?
(If you see no power dip during startup of the esp32, you might try this:solder a 100nF ceramic or 220uF/16V capacitor on the 3,3V output on the esp32 to suppress the power peak.)
thx a lot, Lisa.
I'll check asap.
Paolo
I'll check asap.
Paolo
Houston, we have a go
Deeply impressed too, I am.
Works fine now, but it is very very very slooooooow. Lots of debug data on the serial output.
I guess this comes with the territory of being a beta tester?
Ohh you guys already have a delete option on the devices...
I wanted that on the V2.0/Mega for so long...
In uPyEasy, all data is just a record in a table in the database. All processes are reading from the database, so deleting device data from the database means the device's plugin no longer read by this device... Unloading the plugin the moment no device is using it anymore, is not implemented yet.
Hi @LisaM
Thanks for your hard work on this, I'm excited to give it a try today!
I notice the Wiki links seem to be dead, referenced from your gitHub page:
"Introduction and wiki: https://www.letscontrolit.com/wiki/inde ... troduction"
Have these pages moved?
Nope, not ready yet...jbishop129 wrote: ↑31 Jan 2018, 16:17 Hi @LisaM
