update to mega-Git v2.0-20180126, missing options ?
Posted: 29 Jan 2018, 16:38
I have been busy updating a lot of mainly esp-12 based nodes in and around the house last couple of days,
moved them all up to Mega, version GIT version: mega-20180104, with a manual rebuild of the config on the nodes,
backing up several times, and yesterday went on with version GIT version: v2.0-20180126.
i did some testing with GlobalSync, which did not work wen using long device-variable-name COMING OFF the sending node,
renamed that device on the local device name and it started working, was able to display the outside temp on livingroom-esp.
that is working, nice feature !
when comparing two Esp's which were both updated over the air with the same GIT version:v2.0-20180126 4096 normal bin file several
of the mega options were missing on a nodemcu-v2 based esp.
The whole screen of the config screen is different, for instance the IP acceslimitation for only localsubnet which i loved was not there.
that esp also reports Build 20000 - Mega (core 2_3_0) GIT version mega-20180104 Plugins 48 [Normal]
when you ask for info in the info option under tools menu. so took the laptop, flashed it via usb, with te same new file, it seemed blanco,
enterred the basic settings via the 192.168.4.1 ap-mode menu and still not the extra Mega options for Ip restriction .. ?
I tried to solve this by entering a Reset command in the serial console which should format and default all settings, but it did not solve anything,
yes the esp came back as a freshly flashed item, but still several of the mega options were missing as i wrote before..
Getting a bit confused on this esp, anyone with the same experiences ?
Peter
#edit, made clear what happened. underlined
Peter
