Plugin 021: Niveauregeling
Posted: 10 Feb 2018, 14:35
Remote Threshold configuration
(feature implemented only on github version as of Aug 8th, 2017)
This plugin has the ability to change the Treshold (Set value in the GUI) with a command that can be send through HTTP/MQTT.
Syntax
config,task,<taskname>,setlevel,<value|calculation>
Example if your task name is set to "heater" and the threshold needs to be 21 degrees:
config,task,heater,setlevel,21
Because I only use ESP-Easy for a short time, it is not clear to me what I have to fill in for 'config'.
In 'task' I have entered '4' because at 'Devices' Level Control is the fourth device.
Can someone explain to me what to fill in 'config'.
Syntax
