Bugfix removed for BMP280 on Domoticz
Posted: 17 Feb 2018, 20:26
I discovered a Bug in the handling of BMP280 (temp+baro) sensor when sending the values to Domoticz.
It was already discovered and solved according to issue: [Domoticz HTTP] Compatibility fix for BMP280 (#636)
I checked the Github repository and the solution has been wrongfully merged between mega and 2.0.0. File: src/_C001.ino Lines 98..103. Can you restore the original fix in both releases?
I don't have enough experience with Github and ESPEasy way of working with branches to get this right myself at the moment. I did fix it in my own copy of the source code.
Thanks for this great piece of software.
