Sonof flash with mac
Posted: 18 Feb 2018, 13:52
It takes me the hole morning tot update my sonoff basic with the newest ESPsoftware and no succes. All the different versions maks me crazy. I used
Aduino IDE 1.8.4
ESP Release v2.0-20180218
A Sonoff Basic (recent)
Board: ESP8266 version 2.3.0 (when I update this to latest 2.4.0. I get a message that only 2.3.0 is supported)
Are these the correct latest version wich are compatible with each other?
I coppied the content of the libfolder from ESP-folder to the Arduino IDE librariesfolder.
I use a Macbook to flash the sonoff with a USBtoUART.
Now I get some failures in IDE:
I think this version isnt good tested. What is the latest stable version?
Aduino IDE 1.8.4
Arduino: 1.8.4 (Mac OS X), Board:"Generic ESP8266 Module, 80 MHz, 40MHz, DOUT, 115200, 1M (128K SPIFFS), ck, Disabled, None"
WAARSCHUWING: Categorie 'LED' in bibliotheek CHT16K33 LED Matrix Library is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: Categorie 'Input' in bibliotheek MechInputs is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: Categorie 'Input' in bibliotheek SerialSensors is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: bibliotheek LiquidCrystal_I2C beweert te werken onder architectuur (avr) en kan incompatible zijn met uw huidige board dat werkt onder architectuur (esp8266).
In file included from /Users/remko/Documents/Arduino/libraries/SD/src/utility/Sd2Card.h:26:0,
from /Users/remko/Documents/Arduino/libraries/SD/src/utility/SdFat.h:29,
from /Users/remko/Documents/Arduino/libraries/SD/src/SD.h:20,
from /Users/remko/Downloads/Sonoff/ESPEasy_v2-3/Source/ESPEasy/ESPEasy.ino:383:
/Users/remko/Documents/Arduino/libraries/SD/src/utility/Sd2PinMap.h:510:2: error: #error Architecture or board not supported.
Meerdere bibliotheken gevonden voor "Servo.h"
Gebruikt: /Users/remko/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/Servo
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/Servo
Meerdere bibliotheken gevonden voor "SD.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/SD
Niet gebruikt: /Users/remko/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/SD
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/SD
Meerdere bibliotheken gevonden voor "ArduinoJson.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/ArduinoJson
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/ArduinoJson
Meerdere bibliotheken gevonden voor "IRremoteESP8266.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/IRremoteESP8266
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/IRremoteESP8266
Meerdere bibliotheken gevonden voor "Adafruit_NeoPixel.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/Adafruit_NeoPixel
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/Adafruit_NeoPixel
exit status 1
Fout bij het compileren voor board Generic ESP8266 Module
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
