Timing - general question
Posted: 28 Feb 2018, 10:12
Hi all,
I am new to this forum.
I have a general question about execution times of rules and other action with ESP_Easy:
What are or should be in general the execution times of rules?
I read in the forum something between 150 and 2500 ms .. And there are many discussions about MQTT slow response etc....
Maybe to my setup first:
Wemos D1 mini with 4 relays and 4 switches (later replaced by motion detectors).
I m running rules to communicate with my broker Mosquitto running on a PI3 and my homebridge on same PI using MQTT.
OpenHAB is on controller 1 without any passwords.
Now, when I press a button, this is published via my broker to the homebridge (works fine and quick).
With node-RED I advised the broker to switch on lamps my sending rule commands by MQTT to the ESP. One command, one rule for one lamp.
In the broke I can define which lamps should be switched on (say Lamp1 and Lamp2).
The Lamp rule publishes a MQTT message back that the Lamp is on or off using JSON format (works).
What I observe is the following:
Press the button : immediately the motion-sensor button in the homekit (via homebridge and Mosquitto) shows the activity (ms ...)
Then it takes about 1 second to switch the first lamp.
After another second the next lamp switches.
Looking into the log:
execution lamp1
1300 ms execution time
executing lamp2
1350 ms execution time.
My question is this long execution time normal?
Is it related to MQTT messages sent and received?
Can I reduce the reaction time somehow?
It is doing what it should, but I would like to have a quicker response time somehow, because I want to control finally using 2 ESP, 8 lamps, 5 motion sensors (=switches) and one other sensor (=switch).
Thanks in advance for any hint.
execution lamp1
executing lamp2
