ESPEasy servo controlled blinds
Posted: 28 Feb 2018, 16:45
At the momemt i'am busy to build my servo controlled venation blinds, but when using the standard servo control commands :
its not possible to use "-" commands .
With this blinds it's not only open - close , but you can move the blinds from horizontal ( 0 degree) to 180 degree left , or 180 degree's to the right
How can i arrange this with te default servo commands ?
The 2nd issue i'll get is so called : servo buzz . This means when you move the servo to some possition it keeps buzzing / shaking a bit.
Is there some solution for this ? I found somebody who changed the servo code a bit :
found here : https://electronics.stackexchange.com/q ... om-shaking
But how is this possible to test within ESPeasy ( i use the latest mega build v2.0-20180228 )
i also placed a capacitor , but the problem still remains
somebody who can help me with these questions ?
http://<espeasyip>/control?cmd=Servo,1,2,90
cli();
long start = micros();
digitalWrite(PIN, HIGH);
while (micros() - start < duration)
digitalWrite(PIN, LOW);
sei();
