Dear friends! Can i use EspEasy for analyze (include rules) periodical packets via Hardware or Software serial? For example, serial port recieve 0x23ab2c - i analyze it, and if condition is right, send something via MQTT?
I have this 433mHz reciever, that recieve and analyze 433 mHz RF code:
Full specification - https://www.aliexpress.com/item/RF-tran ... autifyAB=0
Serial port - analyze data?
- TB2aP31lXXXXXbXXpXXXXXXXXXX_!!218960742.jpg (90.11 KiB) Viewed 3842 times
- TB2xJE8lXXXXXXUXpXXXXXXXXXX_!!218960742.jpg (127.74 KiB) Viewed 3842 times
- TB2sd72lXXXXXaBXpXXXXXXXXXX_!!218960742.jpg (150.25 KiB) Viewed 3842 times
Re: Serial port - analyze data?
I think the most difficult issue would be to keep on reading and decoding.
Otherwise properly received messages would get lost.
It also depends on the messages you want to receive. Do they have some proper start of the packets, which is easy to detect?
Or do you want to support a lot of protocols?
The RFlink and RFXcom both have quite some codebase to support all those protocols and those use a CPU and codebase which is optimized to be as real-time as possible.
ESPeasy is not designed to be real-time.
TL;DR
Yes it should be possible to detect messages, but from within ESPeasy it will be very likely you will miss messages and it is quite hard to add a plugin interface to define what to consider a 'correct' message. On the other hand, adding support for a lot of protocols will take quite a lot of development time.
The ESP will be fast enough, but I don't think ESPeasy is the right base to start from.
TL;DR
I allready have code (arduino sketch). But i thought that if it was through the EspaEasy interface with its ready-made solutions (in the part of HTTP protocols, mqtt), it would be more interesting..)
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <SoftwareSerial.h>
unsigned long counter_code, counter_times, counter_init;
byte incomingBytes[4];//was 4
int i;
int serial_enable=1;
int match1=0;
int match2=0;
const char* iii="time";
char charArray[11];
char charArrayResult[11];
long lastMsg = 0;
//char code[6];
const char* ssid = "xxx"; // cannot be longer than 32 characters!
const char* password = "xxx"; // WiFi password
const char* mqtt_server = "xx.cloudmqtt.com";
const char* mqtt_login="xxx";
const char* mqtt_pass="xxx";
*extern "C" {
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
///#include "mem.h"
#include "user_interface.h"
#include "cont.h"
WiFiClient espClient;
PubSubClient client(espClient);
SoftwareSerial swSer(14,15, false, 128); // RX, TX
SoftwareSerial swSer2(9,10, false, 128); // RX, TX
void setup_wifi() {
delay(4);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("RF", mqtt_login,mqtt_pass)) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("yyy/outTopic", iii);
// ... and resubscribe
client.subscribe("inTopic");
else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 2 seconds");
// Wait 5 seconds before retrying
delay(2000);
void ICACHE_FLASH_ATTR delays(int delay_duration) {
counter_code=0;
counter_times=0;
counter_init=millis();
do {
counter_code=millis()-counter_init;
swSer.flush();
} while (counter_code<delay_duration) ;
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived ");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
void setup() {
swSer.setTimeout(30);
Serial.begin(250000);
swSer.begin(9600);
Serial.println("\nSoftware serial test started");
setup_wifi();
client.setServer(mqtt_server, 23456);
client.setCallback(callback);
int io =0;
void loop() {
if (swSer.available() > 0 ) {
swSer.readBytes(incomingBytes, 5); //was 6
for(int i = 0; i < 5; i++) //was 6
if (i) Serial.write(':');
if (incomingBytes[i] < 16) Serial.write('0');
Serial.print(incomingBytes[i],HEX);
charArray[i]=incomingBytes[i];
Serial.println();
char charArray[5]; //was 6
char time_from_start[9];
int j;
char* jj ;
i=1;
j=sprintf(charArray,"0x%X",incomingBytes[i]);
while (i<5){ //was 5
j+=sprintf(charArray+j,"%X",incomingBytes[i+1]);
i++;
snprintf(charArrayResult,5,"%X",charArray); //was 6
client.publish("rrr/rf_code", charArray);
dtostrf((millis()/1000),9,0,time_from_start);
// delay(10); //was 75
client.publish("rrr/time_s", time_from_start);
delay(170); //was 75
i=0;
Serial.println("All MQTT topics publish!");
Serial.print("Time from starting: ");
Serial.print(millis());
Serial.println(" ms");
Serial.print("Free memory in bytes: ");
Serial.println(ESP.getFreeHeap());
Serial.println("");
delays(1700);
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 15000) mqtt_publish();
ESPeasy does run a loop like any other Arduino project.
The thing is, it has to do a lot more, like keeping WiFi connected, keeping MQTT connected, process sensor data, etc.
The SoftwareSerial will react on interrupts on the pins defined as serial port, and store it into a buffer.
ESPeasy can trigger certain loops of plugins at "ten-per-second" interval when needed.
But there is no hard guarantee it will service every 0.1 sec. Worst-case scenario may be way longer if something else is keeping the module busy.
No idea at what speed you're trying to read, but you'll have to read from the buffer before it is full and you're loosing data.
So there are quite some tricky parts to take into account.
I guess it can be used, but when combining it with other plugins, there is almost a guarantee it will cause issues.
And also there may be quite some dev-time involved.
OK I understood. Thanks for the explanation.
Users browsing this forum: Ahrefs [Bot] and 36 guests
