Check a switch
Posted: 01 Mar 2018, 20:05
by Hutschy
Hy there,
i have a switch at the door to control the status. If the door is locked, the switch closed the contact an a led is lighting. I want to use this Signal at my NodeMCU with EspEasy and Domoticz to see the Status.
Can anyone help me pls?
Greets
Hutschy
Re: Check a switch
Posted: 01 Mar 2018, 21:22
by grovkillen
Use a multimeter and see what voltage levels are used for the led. You can then decide if that voltage is enough to monitor the status of the switch. Either digital or the voltage is 0..3.3V or analog of it is below needed 2.8V (if I remember correctly).
Re: Check a switch
Posted: 02 Mar 2018, 18:35
by Hutschy
I have build tehe Szene at a Breakoutboard with another Switch. But everytime i push the button, the status changed. But I want to hold the Status so long the switch is pushed.
And it doesn't work. tehe Cicurit is : D5 -> Switch -> Ground.
Re: Check a switch
Posted: 02 Mar 2018, 19:08
by toffel969
Please post Screenshots of the switch input device and a photo of the breadboard
Re: Check a switch
Posted: 05 Mar 2018, 15:00
by kimot
Maybe change switch type in device tab on ESPeasy.
