Weird issue with Nexa LMST-606
Posted: 01 Mar 2018, 21:58
I'm having a weird issue with LMST-606 door switch - RFlink only sees the OFF - message (closing) unless I open it soon after closing! If I keep opening and closing it at around 1Hz RFlink sees all the messages, but if I keep it closed for several seconds the ON-message is not seen at all. I have verified with RF sniffer (SDR) that it is sending it (well, sending something that looks about right). I thought this is so weird that it must be broken so I went and got another one, but it does the same.
Outlets EYCR-2300 and remote NEYCT-705 work fine. Running latest r48 and using SRX887 like receiver.
first opening and closing fast, then keeping it closed for 5 sec or so:
20;02;NewKaku;ID=01036dee;SWITCH=a;CMD=ON;
20;03;NewKaku;ID=01036dee;SWITCH=a;CMD=OFF;
20;04;NewKaku;ID=01036dee;SWITCH=a;CMD=ON;
20;05;NewKaku;ID=01036dee;SWITCH=a;CMD=OFF;
20;06;NewKaku;ID=01036dee;SWITCH=a;CMD=ON;
20;07;NewKaku;ID=01036dee;SWITCH=a;CMD=OFF;
20;08;NewKaku;ID=01036dee;SWITCH=a;CMD=OFF;
20;09;NewKaku;ID=01036dee;SWITCH=a;CMD=OFF;
I did order a few different receivers to try (will take weeks to arrive), but has someone else seen this?
This quite likely is not a range issue, looks the same at 5cm ... 10m
