Sorry I have an other question. I'm trying to power on a switch and turn it off on a specific time. I've created a device and a rule but it is not working. Is it only possible to change it by using a webbrowser?
If I use this command: http://<Dev IP>/control?cmd=GPIO,12,1
it works fine
Thanks for the help
Hans
Time power on
Time power on
- Device
- pict1.jpg (74.24 KiB) Viewed 4233 times
- Rule
- pict2.jpg (57.29 KiB) Viewed 4233 times
Re: Time power on
have you configured NTP (in the Advanced page) and are you getting the time correctly?
Re: Time power on
In your rule you wrote "if [relay#switch]=0".
But none of your devices has a name "relay" !? [devicename#valuename] e.g. [GPIO12#Sw12]
Re: Time power on
Hi Hans,
For GPIO toggle, you might find helpful this thread: viewtopic.php?f=6&t=2039&start=40 (messages 41-43).
Since you try to control GPIO12 it should not be defined as "Switch input".
And per NTP: in EspEasy 2.0 the NTP does not work quite well, explained as failing ping to the NTP server. This thread viewtopic.php?f=6&t=3884 proposes establishing NTP server @your premises. I did that on Raspberry PI and it works with EspEasy 2.0.Good guide for NTP is: http://raspberrypi.tomasgreno.cz/ntp-cl ... erver.html -> Just remember to add 'sudo' to commands
Re: Time power on
Thanks for the help, works fine now
Hans
Hans
Users browsing this forum: miki8989 and 15 guests
