Access Admin of S20 / TH16 ?
Posted: 06 Apr 2018, 13:13
by cy80rg
Morning all,
Some time ago, I flashed EasyEsp on to two Sonoff devices - an S20 socket and a TH16 thermal relay doodah...
All worked fine at the time - flashing went ok, and I know I could access the admin of each of them.
Of course, connected via the "own-wifi", then setup with my main wifi - both devices can be seen on my main wifi.
I cant for the life of me get to the EasyEsp admin screen for either of them!
Trying to get to the IP of each, I just get "Connection Refused".
From what I read online, the admin page - or at least the login - should be on that IP?
Is there a port or something I'm missing?
Using Fing (network mapping tool), it finds both devices, but says neither of them are broadcasting any available services?
Re: Access Admin of S20 / TH16 ?
Posted: 06 Apr 2018, 13:16
by grovkillen
What version?
And you could try to look if they are publishing on the serial output if you have the possibility to connect to them physically.
