About the PUYA version
I have a problem about the PUYA version, use the ESPEasy_v2.0-20180221, when flash the pre-build ESP_Easy_v2.0-20180221_dev_ESP8266PUYA_1024.bin, it is OK,but when i compile the source myself, flash the PUYA version -with or without VCC, when power on allways reset. could someone give any advices,thanks
Re: About the PUYA version
When you build it yourself, it is not able to write to SPIFF, the flash filesystem used.
This means the settings cannot be written.
I am not sure if (and if so, in what version) the patch for this has been merged into the core libraries.
Using Platform IO, it is quite hard to build a proper version yourself. (at least in Windows)
I spent lot of time trying compile for PUYA using platformIO with no success.
So I swap to Arduino on Debian, and now is much better.
I have patched esp.ccp with proper patch.
When I'll come back home I can attach a patch or esp.ccp file for 2.4.1 core
I use it witch ESP-01s and everything sims work well.
OK, thanks. waitting for that ^-^xury wrote: ↑22 Apr 2018, 17:23 I spent lot of time trying compile for PUYA using platformIO with no success.
OK, thanks. linux is OK , I am also a linux fan.TD-er wrote: ↑22 Apr 2018, 10:53 When you build it yourself, it is not able to write to SPIFF, the flash filesystem used.
Please overwrite your Esp.cpp using following file. And after you can compile binaries for PUYA flash IC.
This file should be in your core path as:
/home/yourname/.arduino15/packages/esp8266/hardware/esp8266/2.4.1/cores (if you use Arduino)
The archive contains two files:
patched and original. So you can simply restore.
Next archive is a patch that I found on github. For me it works well.
- esp8266.zip
- (8.39 KiB) Downloaded 284 times
- puya_v2.patch.zip
- (668 Bytes) Downloaded 306 times
@xuryxury wrote: ↑01 May 2018, 00:04 Please overwrite your Esp.cpp using following file. And after you can compile binaries for PUYA flash IC.
OK, I have finished with your guide, but which board do i select for PUYA 1M, thanks
Nighties releases have two bin files for PUYA already.
ESP_Easy_mega-20180507_dev_ESP8266PUYA_1024.bin
ESP_Easy_mega-20180507_dev_ESP8266PUYA_1024_VCC.bin
could you please try these for us?
Spiffs size is depending how much plugins you have. I compiled with normal and added only serial mcu controlled relay. I set 128k spiffs.
@grovkillenyes ,grovkillen wrote: ↑08 May 2018, 12:13 Nighties releases have two bin files for PUYA already.
yes I know, but my project mainly use pcf8574 and pca9685, and i want to set them output low when power up, so I have to compile myself
for pcf8574 , i add the below init code, does it ok?
and also i want to use a ESP8266's gpio to control a power after pcf8574 inital ok, where should i add the code, thanks
