Power Socket EV1527 based recognized as doorbell !
Post here about devices that are not yet or not fully supported
Jay74
#1 Post by Jay74 » 16 May 2018, 22:33
Hi all,
I'm trying to use RFLink (R48) with Domoticz, first steps with 433 Mhz.
So far RFLink have been able to recognize few elements (two PIR sensors and a garage remote controller), but I'm struggling with a remote controller for power socket that I found out is based on EV1527.
This remote has 4 buttons and manage two sockets, so each socket has a ON button and a OFF button.
This is the serial printout of RFLink for all the buttons:
Socket 1 ON: 20;9C;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
Socket 1 OFF: 20;9D;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
Socket 2 ON: 20;9E;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
Socket 2 OFF: 20;9F;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
I have the same printout even if I set RF Signal Learning on:
10;rffind=on;
20;11;RFFIND=ON;
20;12;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
They all looks the same ! :shock:
I've been trying doing some debugging using another Arduino with RCSwitch libraries
And these are the output for the different buttons:
Socket 1 ON: Binary: 10011100 10001010 00001100 PulseLength: 140 microseconds Protocol: 1
Socket 1 OFF:Binary: 10011100 10001010 00000100 PulseLength: 140 microseconds Protocol: 1
Socket 2 ON: Binary: 10011100 10001010 00001010 PulseLength: 140 microseconds Protocol: 1
Socket 2 OFF:Binary: 10011100 10001010 00000010 PulseLength: 140 microseconds Protocol: 1
How can I tell RF Link to use those binary values ? If I use Arduino with RCSwitch lib they works.
Looks like the same problem in this topic:
http://www.letscontrolit.com/forum/view ... =10&t=1831
Any help or suggestion is appreciated
Here is the debug info:
Socket 1 ON:
20;2C;DEBUG;Pulses=511;Pulses(uSec)=60,1620,30,4350,300,60,30,360,30,360,300,60,300,60,300,60,30,360,30,330,300,60,30,360,30,360,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,330,30,360,300,60,300,60,30,360,30,330,30,4320,300,60,30,360,30,330,330,60,300,60,330,60,30,360,30,330,300,60,30,360,30,360,30,330,300,60,30,360,300,60,30,360,30,360,30,360,30,330,30,360,300,60,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,330,60,30,330,30,360,300,60,30,360,30,360,30,330,300,60,30,360,300,60,30,360,30,360,30,330,30,360,30,360,300,60,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,300,60,330,60,300,60,30,360,30,360,300,60,30,360,30,360,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,360,30,330,300,60,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,360,30,330,330,60,30,360,30,360,30,360,330,60,30,360,300,60,30,360,30,330,30,360,30,330,30,360,300,60,330,60,30,360,30,330,30,4320,330,60,30,330,30,330,330,60,300,60,330,60,0,360,30,330,300,60,30,330,30,360,30,330,330,60,30,360,300,60,30,360,30,330,30,360,30,330,30,360,300,60,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,300,60,330,60,300,60,30,330,30,360,300,60,30,360,30,360,30,330,300,60,30,360,300,60,30,330,30,360,30,360,30,360,30,330,300,60,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,300,60,330,60,300,60,30,360,30,360,300,60,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,360,30,330,300,60,300,60,30,360,30,330,30,4320,300,60,30,330,30,330,330,60,330,60,300,60,30,360,30,330,300,60,30,330,30,360,30,360,330,60,30,360,300,60,30,360,30,360,30,360,30,360,30,360,300,60,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,330,60,300,60,330,60,30,360,30,330,300,60,30,330,30,360,30,330,300,60,30,330,300,60,0,360,30,330,30,360,30,330,30,360,300,60,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,330;
20;2D;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
Socket 1 OFF:
20;2E;DEBUG;Pulses=511;Pulses(uSec)=0,2880,30,4320,300,60,30,360,30,360,300,60,300,60,300,60,30,360,30,360,300,60,30,360,30,360,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,360,30,360,30,360,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,360,30,330,300,60,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,360,30,330,30,360,300,60,30,360,30,330,30,4320,330,60,30,360,30,330,330,60,300,60,300,60,30,360,30,330,300,60,30,330,30,360,30,330,330,60,30,360,300,60,30,360,30,330,30,360,30,360,30,360,30,330,330,60,0,360,30,360,30,4320,330,60,30,330,30,330,330,60,300,60,330,60,30,330,30,360,300,60,30,360,30,360,30,330,330,60,30,330,300,60,30,360,30,360,30,330,30,360,30,360,30,330,330,60,30,360,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,330,30,360,300,60,30,360,30,330,30,360,300,60,30,360,300,60,30,330,30,360,30,360,30,360,30,330,30,360,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,360,30,330,330,60,30,360,30,360,30,360,300,60,30,360,300,60,30,360,30,330,30,360,30,360,30,330,30,360,330,60,30,360,30,330,30,4320,330,60,30,330,30,330,330,60,300,60,300,60,30,360,30,330,330,60,30,330,30,360,30,360,300,60,30,330,330,60,30,360,30,330,30,360,30,330,30,360,30,330,330,60,30,360,30,360,30,4320,330,60,30,360,30,330,330,60,330,60,330,60,30,330,30,360,300,60,30,360,30,360,30,330,300,60,30,330,300,60,30,330,30,360,30,330,30,360,30,360,30,330,300,60,30,360,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,330,30,360,300,60,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,360,30,330,30,360,30,330,30,360,300,60,30,360,30,330,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,360,30,330,300,60,30,330,30,360,30,360,330,60,30,360,300,60,30,360,30,360,30,360,30,330,30,360,30,360,300,60,30,360,30,330,30,4320,330,60,30,330,30,330,330;
20;2F;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
Socket 2 ON:
20;30;DEBUG;Pulses=511;Pulses(uSec)=120,4350,300,60,30,330,30,360,300,60,300,60,300,60,30,360,30,360,300,60,0,360,30,360,30,360,300,60,30,360,300,60,30,360,30,360,30,360,0,360,30,360,300,60,30,330,300,60,30,360,30,4320,300,60,30,330,30,330,330,60,300,60,300,60,30,360,30,330,300,60,30,330,30,360,30,330,330,60,30,330,300,60,30,360,30,360,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,300,60,300,60,30,330,30,360,300,60,30,360,30,360,30,360,300,60,30,330,300,60,30,360,30,360,30,360,30,360,30,360,330,60,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,330,30,360,300,60,30,360,30,330,30,360,300,60,30,360,300,60,30,330,30,360,30,330,30,360,30,330,330,60,30,330,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,360,30,330,300,60,30,330,30,360,30,360,300,60,30,360,300,60,30,360,30,330,30,360,30,330,30,360,300,60,30,330,330,60,30,360,30,4320,330,60,30,330,30,330,330,60,300,60,300,60,30,360,30,330,300,60,30,330,30,360,30,330,330,60,30,360,300,60,30,360,30,330,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,330,60,30,330,30,330,300,60,30,360,30,360,30,330,300,60,30,360,300,60,30,360,30,360,30,330,30,360,30,360,330,60,30,360,330,60,30,360,30,4320,330,60,30,330,30,330,300,60,300,60,300,60,30,330,30,360,330,60,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,360,30,330,30,360,30,330,300,60,30,330,330,60,30,360,30,4320,330,60,30,330,30,360,330,60,330,60,300,60,30,360,30,330,330,60,30,330,30,360,30,360,300,60,30,360,300,60,30,360,30,330,30,360,30,330,30,360,300,60,30,330,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,300,60,300,60,30,360,30,330,300,60,30,330,30,360,30,330,330,60,30,330,330,60,30,360,30,360,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,330;
20;31;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
Socket 2 OFF:
20;32;DEBUG;Pulses=511;Pulses(uSec)=0,2700,30,4350,300,60,30,360,30,360,300,60,300,60,300,60,30,360,30,360,300,60,30,360,30,360,30,360,300,60,0,360,300,60,0,360,30,360,30,360,30,360,30,360,30,330,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,300,60,330,60,30,330,30,360,300,60,30,360,30,360,30,330,300,60,30,360,300,60,30,360,30,360,30,360,30,360,30,360,30,330,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,300,60,330,60,300,60,30,330,30,360,300,60,30,360,30,360,30,360,300,60,30,360,300,60,30,360,30,360,30,330,30,360,30,330,30,360,30,330,330,60,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,360,30,360,300,60,30,360,30,360,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,330,30,360,30,360,30,330,300,60,30,330,30,4320,300,60,30,330,30,330,330,60,300,60,300,60,30,360,30,360,300,60,30,330,30,360,30,330,300,60,30,330,300,60,0,360,30,330,30,360,30,330,30,360,30,330,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,330,60,330,60,330,60,30,330,30,360,300,60,30,360,30,360,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,360,30,360,30,330,30,360,330,60,30,360,30,4320,330,60,30,330,30,330,300,60,330,60,300,60,30,360,30,360,330,60,30,360,30,330,30,360,300,60,30,360,300,60,30,360,0,360,30,330,30,360,30,330,30,360,30,330,300,60,30,330,30,4320,330,60,30,330,30,330,330,60,330,60,300,60,30,360,30,330,330,60,30,330,30,360,30,360,300,60,30,360,300,60,30,360,30,330,30,360,30,330,30,360,30,360,30,360,300,60,30,330,30,4320,330,60,30,330,30,330,330,60,300,60,330,60,30,360,30,330,300,60,30,330,30,360,30,330,330,60,30,330,300,60,30,360,30,360,30,360,30,330,30,360,30,330,30,360,300,60,30,360,30,4320,330,60,30,330,30,330,300,60,330,60,330,60,30,360,30,360,300,60,30,360,30,330,30,360,300,60,30,360,300,60,30,360,30,360,30,360,30,360,30,330,30,360,30,360,330,60,30,360,30,4320,330,60,30,330,30,330,330;
20;33;Doorbell;ID=e450;SWITCH=1;CMD=ON;CHIME=01;
Jay74
Re: Power Socket EV1527 based recognized as doorbell !
#2 Post by Jay74 » 24 May 2018, 18:16
No news, bad news :(
Is there any possibilities to have a look to this problem ?
