Hi All,
I have a Sonoff SV, which is working fine on Esp Easy build 147.
A long time ago I updated it to Mega build 2000, and that works fine as well.
This week I updated it to the latest release but then the devices comes into a boot loop.
I tried ESPEasy_mega-20180524,ESPEasy_mega-20180517 and ESPEasy_mega-20180501 all with the same result.
In the end I flashed the chip with Build 147 again and it works fine.
Just before it reboots I get an error like rst cause:3, boot mode:(3,1) Anyone a clue?
ESP Easy mega not workign on Sonoff SV
Re: ESP Easy mega not workign on Sonoff SV
Did you try to update that 1MB unit over-the-air?
https://www.letscontrolit.com/wiki/inde ... MB_modules
No, via serial.
After that I used a serial monitor to see what was going wrong
Ok, sorry for that misunderstanding.
I have a similar problem with the Sonoff SV ver. 1.0
When I flash some recent ESP8266 Mega builds on it, the Sonoff SV doesn't seem to boot and the AP doesn't show up. Before I flash the firmware, I flash it with a blank firmware.
Esp Easy build 120 doesn't work either.
Strangely the Esp Easy build 147 does work correctly on the Sonoff SV.
Ik tried the flasher provided with the ESP mega firmware, the Flash Download Tool from Espressif and the ESP Easy Flasher by Grovkillen.
Has someone got the Sonoff SV working with the MEGA firmware?
I wish I had the hardware myself. I cannot test it.
