Connection problems with ESP Easy Mega V2.0
ManS-H
#1 Post by ManS-H » 28 Jun 2018, 21:00
Situation:
Six several ESP devices, three with ESP Easy 145 firmware en three with ESP Easy Mega V2.0 firmware.
All six connected with a modem/router of my provider (Ziggo in my case).
With the three with 145 firmware i have never a problem, working now 260, 248 and 75 days.
The three with the ESP Easy Mega firmware they loose after some time the connection with the modem/router.
The first time i saw that problem was resetting the Mega modules, but that wasn't the solution.
What i do now is reset the modem/router, after that the Mega version are online again.
What i don't understand is why the 145 firmware doesn't have this problems.
Part of three ESP Easy 145 modules
3943932166 : EVENT: Clock#Time=Thu,19:51
3943958687 : WD : Uptime 357460 ConnectFailures 0 FreeMem 26344
2134425262 : EVENT: Clock#Time=Thu,19:53
2134451528 : WD : Uptime 107479 ConnectFailures 0 FreeMem 26376
411912215 : EVENT: Clock#Time=Thu,19:54
411914285 : WD : Uptime 374228 ConnectFailures 0 FreeMem 25752
Parts of log files of two ESP Easy Mega modules, and yes i see a lot of connect failures
1442747005 : BME : Address: 0x76
1442747005 : BME : Temperature: 25.83
1442747005 : BME : Humidity: 40.03
1442747005 : BME : Barometric Pressure: 1019.07
1442747007 : EVENT: Slaapkamer#Temperature=22.86
1442747088 : EVENT: Slaapkamer#Humidity=43.31
1442747169 : EVENT: Slaapkamer#Pressure=1020.75
1442747686 : EVENT: Clock#Time=Thu,19:48
1442747794 : WD : Uptime 95558 ConnectFailures 797 FreeMem 22112
2483162928 : BME : Humidity: 29.27
2483162928 : BME : Barometric Pressure: 1017.92
2483162930 : EVENT: T1#Temperature=26.45
2483163061 : EVENT: T1#Humidity=43.07
2483163195 : EVENT: T1#Pressure=1020.06
2483163467 : Domoticz: Sensortype: 4 idx: 3268 values: 26.5;43;1;1020.1;0
2483165276 : WD : Uptime 112892 ConnectFailures 804 FreeMem 14808
I hope someone can explain this to me.
Re: Connection problems with ESP Easy Mega V2.0
#2 Post by grovkillen » 28 Jun 2018, 21:04
Did the mega versions reboot or how did you first start to see the problem? And what versions are they running exactly?
ManS-H
#3 Post by ManS-H » 28 Jun 2018, 21:22
grovkillen wrote:
28 Jun 2018, 21:04
The first time i didnt see the temperature is Domoticz, then i reboot 'the ESP's. But it's strange that all the three ESP's are not visible.
Now i reset the modem/router and then the three Mega's are visible again, so yesterday i did that trick again.
My ESP Easy Mega versions:
GIT version: v2.0-20180228
GIT version: v2.0.0-dev12
GIT version: mega-20180428
#4 Post by grovkillen » 28 Jun 2018, 21:47
Could you update one of the misbehaving units to latest nightly?
ManS-H
#5 Post by ManS-H » 28 Jun 2018, 21:52
grovkillen wrote:
28 Jun 2018, 21:47
Yes, i will do that tomorrow, and then i wil check every the log files.
#6 Post by TD-er » 29 Jun 2018, 00:15
Also don't forget to do a reset by pressing the reset button (or power cycle) after flashing.
If the node tries to reboot for whatever reason, it will hang if you did not reset the node after flashing.
Since the end of march, I have changed the way the wifi works. It now starts almost immediately and handles the wifi connection afterwards.
This means it does all the wifi steps by itself and maybe there is still some issue in there.
Also try to set the Message Delay to a lower value (e.g. 100 instead of 1000).
ManS-H
#7 Post by ManS-H » 29 Jun 2018, 11:36
grovkillen wrote:
28 Jun 2018, 21:47
@ grovkillen and TD-er,
I have all the three units updated to ESP_Easy_mega-20180625_normal_ESP8266_4096, and did a power cycle after flashing.
I will control ever day the state of the units. I keep in touch.
#8 Post by grovkillen » 29 Jun 2018, 11:49
ManS-H wrote:
29 Jun 2018, 11:36
grovkillen wrote:
28 Jun 2018, 21:47
ManS-H
#9 Post by ManS-H » 04 Jul 2018, 12:26
After 5 days three of the ESP's lost the connection.
This was the situation of yesterday.
The attachment ESP Easy-normal.JPG is no longer available
ESP Easy-normal.JPG (47.17 KiB) Viewed 1323 times
ManS-H
#10 Post by ManS-H » 04 Jul 2018, 12:31
This the situation of this morning.
The attachment ESP Easy-fail.JPG is no longer available
Situation this morning
ESP Easy-fail.JPG (27.43 KiB) Viewed 1320 times
ManS-H
#11 Post by ManS-H » 04 Jul 2018, 12:32
The last report was at around 5 o clock this morning.
ESP Easy-Domoticz.JPG (29.57 KiB) Viewed 1166 times
I have no idea what i can do to solve this problem.
maconly34
#12 Post by maconly34 » 11 May 2019, 00:37
same problem for me!
Have you find a solution?
Thank's
Bruno
dirk_k
#13 Post by dirk_k » 11 May 2019, 10:41
For my environment i build a watchdog.
Send uptime to MQTT. receive this data again. Compare uptime and watchdog and reboot if difference is too big.
i use my own MQTT server ... reacheble over GSM from ESPEasy-sensor.
Currently i get a uptime of max 5 days ... but seems the watchdog is'nt the reboot reason mostly.
(Firmware: Mar 15 2019)
