Timers and Delays, less then 1 second.
Posted: 07 Jul 2018, 17:19
by vandalon
I'm trying to configure a switch button (push button) to do 3 things:
1: short press (sends out "1" via mqtt)
2: long press (sends out "2" via mqtt)
3: double press (sends out "3" via mqtt)
now, this is all not to difficult to build with a timer. But timers are not configurable less then 1 second. And I don't want to wait a second before something happens. Also I'm not sending commands to local gpio ports but rather to mqtt, which makes the pulse option also unusable in my case. so I'm left with using delay. The thing with delay is that when I press a button shortly when the delay is running , espeasy is not noticing. So, Does anyone have a good hint on how to work around this?
For reference, this is how I do it with a 1 second timer (double click is instant, sw1#Switch, value 0 is pressed, 1 not pressed):
On sw1#Switch=0 do
  timerSet,1,1
  if [swClick#1] = 1
    timerSet,1,0
    TaskValueSet,6,1,0
    Publish home/%sysname%/sw1,3
    TaskValueSet,6,1,1
On Rules#Timer=1 do
  TaskValueSet,6,1,0
  if [sw1#Switch]=0 and [swClick#1]=0
    Publish home/%sysname%/sw1,2
    Publish home/%sysname%/sw1,1
Cheers,
Joris
