Command unknown: 'blynkget'
Posted: 07 Aug 2018, 20:20
by TFD
Hi!
I downloaded the latest firmware (ESP_Easy_mega-20180804_test_ESP8266_1024.bin) and trying to connect to Blynk.
My Rules:
On System#Boot do
BlynkGet update/V30?value=0
timerSet,1,3
On Rules#Timer=1 do
BlynkGet update/V30?value=7
timerSet,1,3
It doesn't work.
In logs I see this:
1408378: ACT : BlynkGet update/V30?value=7
1408386: Command: blynkget
1408386: Command unknown: 'blynkget'
What am I doing wrong? In Controllers I activated Blynk HTTP [TESTING] with blynk-cloud.com and my token.
http://blynk-cloud.com/<MY_TOKEN>/update/V30?value=7 - works fine in browser.
Re: Command unknown: 'blynkget'
Posted: 07 Aug 2018, 22:30
by TD-er
Can you test with this latest test build I just made? https://www.dropbox.com/s/nxats6wfgdasj ... 4.zip?dl=0
It outputs a bit more information when you run the command from the Tools page in the webinterface.
Just use the single line from the rules regarding the Blynk
Posted: 08 Aug 2018, 07:15
by TFD
Done. Binary filename - ESP_Easy_mega-20180804-11-g7783cf4_test_ESP8266_1024.bin
Command: BlynkGet update/V30?value=0
Command output: Unknown command!
Posted: 08 Aug 2018, 19:43
by TD-er
TFD wrote: 08 Aug 2018, 07:15 Done. Binary filename - ESP_Easy_mega-20180804-11-g7783cf4_test_ESP8266_1024.bin
Found the bug and made a fix for it: https://github.com/letscontrolit/ESPEasy/pull/1634
When the Travis tests are ready, I will merge it.
Posted: 09 Aug 2018, 20:25
by TFD
Thank you! Now Blynk works.
Another question:
when I use command
BlynkGet 10,1,get/V30
I always get in logs
4205141: Command: blynkget
4206334: Timeout while reading input data!
And I only get the value of the V30 variable from Blynk on every third or fourth attempt. That is, if I have a timer set for 3 seconds to get the V30, then I will get the value only 9-10 seconds after changing it to Blynk. And if you make the same request in the browser, I get the changed value instantly.
Posted: 09 Aug 2018, 22:08
by TD-er
Does the browser do the update via HTTPS?
Also try in the command line if the DNS hostname resolves to a different hostname, or always the same.
ESPeasy doesn't handle often changing DNS lookups very well.
Posted: 10 Aug 2018, 06:55
by TFD
via HTTP
Always the same.
Posted: 10 Aug 2018, 22:00
by TD-er
OK, thanks for checking.
I am currently looking into handling of controllers, so I will also look into these HTTP-like controllers and what may be wrong here.
Other HTTP senders like the Generic and Advanced HTTP controllers have a number of issue reports.
Posted: 14 Sep 2018, 20:26
by TFD
Today.
Build 20102 - Mega
Libraries ESP82xx Core 00000000, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version mega-20180914
Plugins 72 [Normal] [Testing]
Build Md5 74a3821da965285ae42477c68c3fd9a6
Md5 check passed.
Build time Sep 14 2018 02:21:24
Binary filename ESP_Easy_mega-20180914_test_ESP8266_4096.bin
65582: Command: blynkget
75611: HTTP : C012 connection failed
75872: ADC : Analog value: 173
75874: EVENT: ADC#Analog=173.00
75899: ADC : Analog value: 173
75902: EVENT: ADC#Analog=173.00
75920: ADC : Analog value: 171
75922: EVENT: ADC#Analog=171.00
75938: Command: timerset
79926: ACT :
79939: ACT : Pulse,15,1,100
80042: SW : GPIO 15 Pulsed for 100 mS
80051: ACT : BlynkGet update/V2?value=171.00
80065: ACT : timerSet,1,3
80087: Command:
80087: Command unknown: ''
80087: Command: blynkget
90113: HTTP : C012 connection failed
90149: ADC : Analog value: 169
90151: EVENT: ADC#Analog=169.00
90175: ADC : Analog value: 176
90178: EVENT: ADC#Analog=176.00
90198: Command: timerset
90738: ADC : Analog value: 168
90741: EVENT: ADC#Analog=168.00
92073: WD : Uptime 2 ConnectFailures 6 FreeMem 18424
94200: SW : GPIO 12 Set to 0
94203: ACT :
94220: ACT : Pulse,15,1,100
94325: SW : GPIO 15 Pulsed for 100 mS
94334: ACT : BlynkGet update/V2?value=168.00
94348: ACT : timerSet,1,3
94369: Command:
94369: Command unknown: ''
94370: Command: blynkget
95572: Timeout while reading input data!
96573: Timeout while reading input data!
97574: Timeout while reading input data!
98575: Timeout while reading input data!
99576: Timeout while reading input data!
100577: Timeout while reading input data!
101578: Timeout while reading input data!
102579: Timeout while reading input data!
103580: Timeout while reading input data!
104581: Timeout while reading input data!
105582: Timeout while reading input data!
106583: Timeout while reading input data!
107584: Timeout while reading input data!
108585: Timeout while reading input data!
109586: Timeout while reading input data!
110587: Timeout while reading input data!
111588: Timeout while reading input data!
112589: Timeout while reading input data!
113590: Timeout while reading input data!
114591: Timeout while reading input data!
115592: Timeout while reading input data!
116593: Timeout while reading input data!
117594: Timeout while reading input data!
118595: Timeout while reading input data!
119596: Timeout while reading input data!
120597: Timeout while reading input data!
121598: Timeout while reading input data!
122599: Timeout while reading input data!
123600: Timeout while reading input data!
124601: Timeout while reading input data!
125602: Timeout while reading input data!
126603: Timeout while reading input data!
127604: Timeout while reading input data!
128605: Timeout while reading input data!
129606: Timeout while reading input data!
130607: Timeout while reading input data!
131608: Timeout while reading input data!
132609: Timeout while reading input data!
133610: Timeout while reading input data!
134611: Timeout while reading input data!
135612: Timeout while reading input data!
136613: Timeout while reading input data!
137614: Timeout while reading input data!
138615: Timeout while reading input data!
139616: Timeout while reading input data!
140617: Timeout while reading input data!
141618: Timeout while reading input data!
142619: Timeout while reading input data!
143620: Timeout while reading input data!
144621: Timeout while reading input data!
145636: Timeout while reading input data!
146637: Timeout while reading input data!
147638: Timeout while reading input data!
148639: Timeout while reading input data!
149640: Timeout while reading input data!
150641: Timeout while reading input data!
151642: Timeout while reading input data!
152643: Timeout while reading input data!
153644: Timeout while reading input data!
154645: Timeout while reading input data!
155646: Timeout while reading input data!
156661: Timeout while reading input data!
157661: Timeout while reading input data!
158662: Timeout while reading input data!
159663: Timeout while reading input data!
160664: Timeout while reading input data!
161665: Timeout while reading input data!
162666: Timeout while reading input data!
163667: Timeout while reading input data!
164668: Timeout while reading input data!
165669: Timeout while reading input data!
166670: Timeout while reading input data!
167671: Timeout while reading input data!
168672: Timeout while reading input data!
169673: Timeout while reading input data!
170674: Timeout while reading input data!
171675: Timeout while reading input data!
172676: Timeout while reading input data!
173677: Timeout while reading input data!
174678: Timeout while reading input data!
175679: Timeout while reading input data!
Command at 94334 passed.
MQTT Import - broken, HTTP requests - broken, Blynk - broken... Sad...
Posted: 15 Sep 2018, 21:47
by sasso
The same error is now present also on nextion plugin, rules (unknown command) and http cmd (Unknown or restricted command!) gives error, but on the plugin page all works as it should
Posted: 16 Sep 2018, 11:06
by TD-er
sasso wrote: 15 Sep 2018, 21:47 The same error is now present also on nextion plugin, rules (unknown command) and http cmd (Unknown or restricted command!) gives error, but on the plugin page all works as it should
I already had prepared some change to how the commands are being handled.
In short: The last few weeks, the commands were sent to a queue to process them asynchronously, but that means the reply will be delayed.
I did not anticipate these issues, so I will revert the command queue.
This will be fixed very soon.
