Problems with Sonoff S20 and Basic
Posted: 08 Sep 2018, 12:59
Hi!
I have massive WIFI-problems with Sonoff s20 and Basic. I tested several sonoffs, all have the same problems: very Slow, boot loops, often losing temprary Wifi connection, losing complete WIFI-connection, after configure with the setup-AP the sonoff often crashes, if I got it running I got boot loops on changing WIFI. I wondered why you don't fix this problems, till I had the idea that you are testing on other devices
So I flashed a ESP8266 dev-board with the 20180904 (this version don't run on my sonoffs) and it works like a charme. YESSS!!! The last version that runs with fewer problems on my Sonoffs is 20180804.
Do you have any idea what I have to do to get ESPeasy running on this Sonoff devices? Is it possible that the USB to Serial/TTL Adapter causes that kind of problems? The dev-bord has its own USB-port and to flash the Sonoffs I use a USB to Serial/TTL Adapter.
Heiko
PS.: With ESPeasy you are doing a very great job. If I can help with testing or something else, please let me know. My programming skills are very very low, but I have experience in testing and some ESP device here (ESP8266, ESP32, diffent boards).
Heiko
