Dear friends! Can i write some data -strings (from rules or sensors for example) to eeprom or spiffs...
I know about about limited rewriting cycles...
Can i write some string to spiffs or flash?
Re: Can i write some string to spiffs or flash?
You need to use a SD card for that.. it's not covered by the wiki but if you search the forum you will find some topics about it.
I read about sd-card. But I was hoping that you can still use internal flash memory..(
No not at this time no. We will not implement it either, external EEPROM will be supported but time frame is not known to us now.
