Rules triggering on startup
chevrolux
#1 Post by chevrolux » 17 Sep 2018, 00:08
Mods - apologies if I have put this in the wrong place.
Have one very small issue I just can't seem to work out. I am wondering if I should just be doing this automation in Node-RED, but that seems kind of counter-intuitive when there is a whole rules
The set up is a Sonoff Basic switch, and then the existing light switches wired in to GPIO 14 & 13 (I took the LED off to use the PIN) so people can still use the wall switches.
My rules section currently looks like this (under 'Rules Set 1')
on ext_sw#Switch do
if [relay#state]=1
event switchoff
event switchon
on ext_sw2#Switch do
if [relay#state]=1
event switchoff
event switchon
on switchon do
gpio 12,1
on switchoff do
gpio 12,0
But I've come across one really annoying thing. When the Sonoff reboots, it triggers this rule, and toggles the relay meaning that lighting circuit will turn on for a few seconds and turn off again.
This makes sense as the switch state has "changed" so the rule should trigger, but still really annoying. But I am seriously struggling to do this sort of basic logic.
I've tried setting GPIO 12 to low under the hardware section, but it still gets toggled because the switch event runs at boot.
So some more googling, and I find the there is an event called 'System#Boot' & System#Wake you can run rules on. So I've tried simple delay rules, but they don't fix my issue either:
on System#Wake do
Delay 5000
on System#Boot do
Delay 5000
I assume I am not the first person to come across this, but my google-fu is seriously failing me here to find any fix to the issue. I did come across using 'Timers' in my rules, but I don't think they work how I need them to work for this scenario.
kenkoknz
Re: Rules triggering on startup
#2 Post by kenkoknz » 17 Sep 2018, 03:47
Depending on which FW ver u use, the delay may not work.
chevrolux
#3 Post by chevrolux » 17 Sep 2018, 03:53
Interesting. So here is what is on the info page under firmware:
Build 20102 - Mega
Libraries ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version mega-20180809
Plugins 48 [Normal]
Build Md5 4bcbad21e4eb40a8354487ca57cab72
Md5 check passed.
Build time Aug 9 2018 02:15:47
Binary filename ESP_Easy_mega-20180809_normal_ESP8266_1024.bin
So if delay is not an option, is there another way to fix this?
#4 Post by grovkillen » 17 Sep 2018, 06:57
Use a month old release and try. We're doing a lot of changes to how commands are being processed and some of them are not working 100%.
We're fixing it ;)
