I have sonoff basic with espeasy (mega-20180826)
every 1-2 weeks, sonoff stops responding (You can not see it over ip)
I have connected to GPIO-0 wall switch to turn on the light in the room.
When sonoff stops responding it also stops working wall switch (I can't turn light in the room) :/
Then I have to disconnect the voltage from sonoff.
I do not know what's going on
Maybe this rule would help?
If wifi disconnected then reboot espeasy
but is it possible to make this rule?
if Wifi disconnected then reboot
Re: if Wifi disconnected then reboot
Perhaps wifi is very weak at that spot or some kind of collision appear... Or if you have _more than one AP with the same SSID_, than the ESP may connected to the weaker of them, ESP is not able to connect to the strongest signal, it connects randomly(?) - the first AP it's sees - as i experienced.krystian-l wrote: ↑23 Sep 2018, 00:23 every 1-2 weeks, sonoff stops responding (You can not see it over ip)
Yes. But instant reboot will cause easily an endless loop of reboots, i think.krystian-l wrote: ↑23 Sep 2018, 00:23 Maybe this rule would help?
I am using the below rule all of my ESPEasy installations:
on System#WifiState=0 do
timerSet,1,180
On Rules#Timer=1 do
If [wifiman#Connected] = 0
reboot
"if wifi disconnected, than check again in 180 sec, if still no connection, than reboot"
But first you need to activate the P166 WifiMan plugin:
https://github.com/enesbcs/ESPEasyPlugi ... iFiMan.ino
Forum topic:
viewtopic.php?t=2846
Thank you for your help.
Users browsing this forum: Ahrefs [Bot] and 33 guests
