[SOLVED] ESP EASY SKETCH UPLOAD ERROR
jeremiahlandi
#1 Post by jeremiahlandi » 03 Jan 2016, 05:10
It has been a while since dealing with Arduino but I decided to dive back in!
I am following the instructions from:
Tutorial Arduino Firmware Upload
http://www.esp8266.nu/index.php/Tutoria ... are_Upload
I was receiving the following message:
Arduino: 1.6.7 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600"
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP8266httpUpdate is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Hash is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Ticker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Warning: platform.txt from core 'ESP8266 Modules' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\ESPEasy.ino: In function 'void setup()':
ESPEasy:327: error: 'emergencyReset' was not declared in this scope
   emergencyReset();
ESPEasy:329: error: 'LoadSettings' was not declared in this scope
   LoadSettings();
ESPEasy:347: error: 'ResetFactory' was not declared in this scope
     ResetFactory();
ESPEasy:355: error: 'addLog' was not declared in this scope
     addLog(LOG_LEVEL_INFO, log);
ESPEasy:360: error: 'WifiAPconfig' was not declared in this scope
     WifiAPconfig();
ESPEasy:361: error: 'WifiConnect' was not declared in this scope
     WifiConnect();
ESPEasy:363: error: 'hardwareInit' was not declared in this scope
     hardwareInit();
ESPEasy:364: error: 'PluginInit' was not declared in this scope
     PluginInit();
ESPEasy:365: error: 'CPluginInit' was not declared in this scope
     CPluginInit();
ESPEasy:367: error: 'WebServerInit' was not declared in this scope
     WebServerInit();
ESPEasy:379: error: 'getProtocolIndex' was not declared in this scope
     byte ProtocolIndex = getProtocolIndex(Settings.Protocol);
ESPEasy:381: error: 'MQTTConnect' was not declared in this scope
       MQTTConnect();
ESPEasy:383: error: 'sendSysInfoUDP' was not declared in this scope
     sendSysInfoUDP(3);
ESPEasy:395: error: 'readFromRTC' was not declared in this scope
     if (readFromRTC(&bootMode))
ESPEasy:407: error: 'saveToRTC' was not declared in this scope
     saveToRTC(0);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\ESPEasy.ino: In function 'void loop()':
ESPEasy:436: error: 'PluginCall' was not declared in this scope
     if(!PluginCall(PLUGIN_SERIAL_IN, 0, dummyString))
ESPEasy:437: error: 'serial' was not declared in this scope
       serial();
ESPEasy:442: error: 'checkUDP' was not declared in this scope
     checkUDP();
ESPEasy:450: error: 'WifiDisconnect' was not declared in this scope
             WifiDisconnect();
ESPEasy:469: error: 'FreeMem' was not declared in this scope
       sprintf_P(str, PSTR("Uptime %u ConnectFailures %u FreeMem %u"), wdcounter / 2, connectionFailures, FreeMem());
ESPEasy:472: error: 'addLog' was not declared in this scope
ESPEasy:473: error: 'sendSysInfoUDP' was not declared in this scope
       sendSysInfoUDP(1);
ESPEasy:474: error: 'refreshNodeList' was not declared in this scope
       refreshNodeList();
ESPEasy:475: error: 'MQTTCheck' was not declared in this scope
       MQTTCheck();
ESPEasy:483: error: 'PluginCall' was not declared in this scope
       PluginCall(PLUGIN_TEN_PER_SECOND, 0, dummyString);
ESPEasy:491: error: 'PluginCall' was not declared in this scope
       PluginCall(PLUGIN_ONCE_A_SECOND, 0, dummyString);
ESPEasy:495: error: 'WifiCheck' was not declared in this scope
       WifiCheck();
ESPEasy:518: error: 'SensorSend' was not declared in this scope
       SensorSend();
ESPEasy:521: error: 'saveToRTC' was not declared in this scope
         saveToRTC(1);
ESPEasy:523: error: 'addLog' was not declared in this scope
ESPEasy:529: error: 'delayedReboot' was not declared in this scope
       delayedReboot(60);
ESPEasy:531: error: 'backgroundtasks' was not declared in this scope
     backgroundtasks();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\ESPEasy.ino: In function 'void SensorSend()':
ESPEasy:546: error: 'getDeviceIndex' was not declared in this scope
       byte DeviceIndex = getDeviceIndex(Settings.TaskDeviceNumber[x]);
ESPEasy:547: error: 'LoadTaskSettings' was not declared in this scope
       LoadTaskSettings(x);
ESPEasy:559: error: 'PluginCall' was not declared in this scope
       success = PluginCall(PLUGIN_READ, &TempEvent, dummyString);
ESPEasy:576: error: 'Calculate' was not declared in this scope
             byte error = Calculate(TmpStr, &result);
ESPEasy:581: error: 'sendData' was not declared in this scope
         sendData(&TempEvent);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'boolean sendData(EventStruct*)':
Controller:6: error: 'LoadTaskSettings' was not declared in this scope
   LoadTaskSettings(event->TaskIndex);
Controller:7: error: 'getProtocolIndex' was not declared in this scope
Controller:10: error: 'PluginCall' was not declared in this scope
   PluginCall(PLUGIN_EVENT_OUT, event, dummyString);
Controller:16: error: 'addLog' was not declared in this scope
     addLog(LOG_LEVEL_DEBUG_MORE, log);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void callback(const MQTT::Publish&)':
Controller:36: error: 'addLog' was not declared in this scope
   addLog(LOG_LEVEL_DEBUG, log);
Controller:41: error: 'getProtocolIndex' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void MQTTConnect()':
Controller:66: error: 'addLog' was not declared in this scope
Controller:78: error: 'addLog' was not declared in this scope
       addLog(LOG_LEVEL_ERROR, log);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void MQTTCheck()':
Controller:91: error: 'getProtocolIndex' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'boolean nodeVariableCopy(byte, byte)':
Controller:121: error: 'addLog' was not declared in this scope
Controller:133: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void checkUDP()':
Controller:233: error: 'addLog' was not declared in this scope
       addLog(LOG_LEVEL_DEBUG, packetBuffer);
Controller:234: error: 'ExecuteCommand' was not declared in this scope
       ExecuteCommand(packetBuffer);
Controller:264: error: 'addLog' was not declared in this scope
Controller:272: error: 'PluginCall' was not declared in this scope
             PluginCall(PLUGIN_UDP_IN, &TempEvent, dummyString);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void sendSysInfoUDP(byte)':
Controller:308: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Hardware.ino: In function 'void hardwareInit()':
Hardware:11: error: 'addLog' was not declared in this scope
       addLog(LOG_LEVEL_INFO,log);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveSettings()':
Misc:167: error: 'SaveToFlash' was not declared in this scope
   SaveToFlash(0, (byte*)&Settings, sizeof(struct SettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'boolean LoadSettings()':
Misc:182: error: 'LoadFromFlash' was not declared in this scope
   LoadFromFlash(0, (byte*)&Settings, sizeof(struct SettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveTaskSettings(byte)':
Misc:196: error: 'SaveToFlash' was not declared in this scope
   SaveToFlash(4096 + (TaskIndex * 1024), (byte*)&ExtraTaskSettings, sizeof(struct ExtraTaskSettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void LoadTaskSettings(byte)':
Misc:212: error: 'LoadFromFlash' was not declared in this scope
   LoadFromFlash(4096 + (TaskIndex * 1024), (byte*)&ExtraTaskSettings, sizeof(struct ExtraTaskSettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveCustomTaskSettings(int, byte*, int)':
Misc:227: error: 'SaveToFlash' was not declared in this scope
   SaveToFlash(4096 + (TaskIndex * 1024) + 512, memAddress, datasize);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void LoadCustomTaskSettings(int, byte*, int)':
Misc:242: error: 'LoadFromFlash' was not declared in this scope
   LoadFromFlash(4096 + (TaskIndex * 1024) + 512, memAddress, datasize);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveToFlash(int, byte*, int)':
Misc:334: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void EraseFlash()':
Misc:386: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void ResetFactory()':
Misc:402: error: 'readFromRTC' was not declared in this scope
   if (readFromRTC(&bootCount))
Misc:416: error: 'saveToRTC' was not declared in this scope
   saveToRTC(bootCount);
Misc:469: error: 'WifiDisconnect' was not declared in this scope
   WifiDisconnect();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void addLog(byte, String&)':
Misc:537: error: invalid initialization of non-const reference of type 'String&' from an rvalue of type 'char*'
   addLog(loglevel, log);
Misc:533: error: in passing argument 2 of 'void addLog(byte, String&)'
 void addLog(byte loglevel, String& string)
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Serial.ino: In function 'void ExecuteCommand(char*)':
Serial:57: error: 'WifiScan' was not declared in this scope
     WifiScan();
Serial:60: error: 'WifiConnect' was not declared in this scope
     WifiConnect();
Serial:63: error: 'WifiDisconnect' was not declared in this scope
     WifiDisconnect();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void WebServerInit()':
WebServer:7: error: 'handle_root' was not declared in this scope
   WebServer.on("/", handle_root);
WebServer:8: error: 'handle_config' was not declared in this scope
   WebServer.on("/config", handle_config);
WebServer:9: error: 'handle_hardware' was not declared in this scope
   WebServer.on("/hardware", handle_hardware);
WebServer:10: error: 'handle_devices' was not declared in this scope
   WebServer.on("/devices", handle_devices);
WebServer:11: error: 'handle_log' was not declared in this scope
   WebServer.on("/log", handle_log);
WebServer:12: error: 'handle_tools' was not declared in this scope
   WebServer.on("/tools", handle_tools);
WebServer:13: error: 'handle_i2cscanner' was not declared in this scope
   WebServer.on("/i2cscanner", handle_i2cscanner);
WebServer:14: error: 'handle_wifiscanner' was not declared in this scope
   WebServer.on("/wifiscanner", handle_wifiscanner);
WebServer:15: error: 'handle_login' was not declared in this scope
   WebServer.on("/login", handle_login);
WebServer:16: error: 'handle_control' was not declared in this scope
   WebServer.on("/control", handle_control);
WebServer:17: error: 'handle_download' was not declared in this scope
   WebServer.on("/download", handle_download);
WebServer:18: error: 'handle_upload' was not declared in this scope
   WebServer.on("/upload", handle_upload);
WebServer:19: error: 'handleFileUpload' was not declared in this scope
   WebServer.onFileUpload(handleFileUpload);
WebServer:24: error: 'handle_css' was not declared in this scope
   WebServer.on("/esp.css", handle_css);
WebServer:26: error: 'handle_advanced' was not declared in this scope
   WebServer.on("/advanced", handle_advanced);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_root()':
WebServer:113: error: 'isLoggedIn' was not declared in this scope
   if (!isLoggedIn()) return;
WebServer:120: error: 'urlDecode' was not declared in this scope
   urlDecode(command);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_config()':
WebServer:232: error: 'isLoggedIn' was not declared in this scope
WebServer:256: error: 'urlDecode' was not declared in this scope
     urlDecode(tmpString);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_hardware()':
WebServer:392: error: 'isLoggedIn' was not declared in this scope
WebServer:409: error: 'addPinSelect' was not declared in this scope
   addPinSelect(true, reply, "pini2csda", Settings.Pin_i2c_sda);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_devices()':
WebServer:425: error: 'isLoggedIn' was not declared in this scope
WebServer:493: error: 'urlDecode' was not declared in this scope
WebServer:532: error: 'PluginCall' was not declared in this scope
       PluginCall(PLUGIN_WEBFORM_SAVE, &TempEvent, dummyString);
WebServer:569: error: 'PluginCall' was not declared in this scope
       PluginCall(PLUGIN_GET_DEVICEVALUENAMES, &TempEvent, dummyString);
WebServer:591: error: 'PluginCall' was not declared in this scope
     customConfig = PluginCall(PLUGIN_WEBFORM_SHOW_CONFIG, &TempEvent, reply);
WebServer:655: error: 'PluginCall' was not declared in this scope
WebServer:660: error: 'addDeviceSelect' was not declared in this scope
     addDeviceSelect(reply, "taskdevicenumber", Settings.TaskDeviceNumber[index - 1]);
WebServer:687: error: 'addPinSelect' was not declared in this scope
           addPinSelect(false, reply, "taskdevicepin1", Settings.TaskDevicePin1[index - 1]);
WebServer:692: error: 'addPinSelect' was not declared in this scope
           addPinSelect(false, reply, "taskdevicepin2", Settings.TaskDevicePin2[index - 1]);
WebServer:714: error: 'PluginCall' was not declared in this scope
       PluginCall(PLUGIN_WEBFORM_LOAD, &TempEvent, reply);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void addDeviceSelect(String&, String, int)':
WebServer:770: error: 'sortDeviceArray' was not declared in this scope
   sortDeviceArray();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_log()':
WebServer:1003: error: 'isLoggedIn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_tools()':
WebServer:1040: error: 'isLoggedIn' was not declared in this scope
WebServer:1046: error: 'urlDecode' was not declared in this scope
   urlDecode(command);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_i2cscanner()':
WebServer:1090: error: 'isLoggedIn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_wifiscanner()':
WebServer:1167: error: 'isLoggedIn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_login()':
WebServer:1206: error: 'urlDecode' was not declared in this scope
   urlDecode(command);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_control()':
WebServer:1246: error: 'urlDecode' was not declared in this scope
   urlDecode(command);
WebServer:1267: error: 'PluginCall' was not declared in this scope
   if (!PluginCall(PLUGIN_WRITE, &TempEvent, webrequest))
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_advanced()':
WebServer:1282: error: 'isLoggedIn' was not declared in this scope
WebServer:1304: error: 'urlDecode' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_C005.ino: In function 'boolean CPlugin_005(byte, EventStruct*)':
_C005:52: error: 'PluginCall' was not declared in this scope
         PluginCall(PLUGIN_WRITE, &TempEvent, cmd);
_C005:62: error: 'PluginCall' was not declared in this scope
           PluginCall(PLUGIN_GET_DEVICEVALUENAMES, event, dummyString);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_C006.ino: In function 'boolean CPlugin_006(byte, EventStruct*)':
_C006:63: error: 'PluginCall' was not declared in this scope
_C006:73: error: 'PluginCall' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P003_Pulse.ino: In function 'boolean Plugin_003(byte, EventStruct*, String&)':
_P003_Pulse:87: error: 'Plugin_003_pulseinit' was not declared in this scope
         Plugin_003_pulseinit(Settings.TaskDevicePin1[event->TaskIndex], event->TaskIndex);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'boolean Plugin_004(byte, EventStruct*, String&)':
_P004_Dallas:52: error: 'Plugin_004_DS_scan' was not declared in this scope
         byte devCount = Plugin_004_DS_scan(choice, addr);
_P004_Dallas:86: error: 'Plugin_004_DS_scan' was not declared in this scope
         byte devCount = Plugin_004_DS_scan(Settings.TaskDevicePluginConfig[event->TaskIndex][0], addr);
_P004_Dallas:117: error: 'Plugin_004_DS_readTemp' was not declared in this scope
         if (Plugin_004_DS_readTemp(addr, &value))
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'byte Plugin_004_DS_scan(byte, uint8_t*)':
_P004_Dallas:152: error: 'Plugin_004_DS_reset' was not declared in this scope
   Plugin_004_DS_reset();
_P004_Dallas:154: error: 'Plugin_004_DS_reset_search' was not declared in this scope
   Plugin_004_DS_reset_search();
_P004_Dallas:155: error: 'Plugin_004_DS_search' was not declared in this scope
   while (Plugin_004_DS_search(tmpaddr))
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'boolean Plugin_004_DS_readTemp(uint8_t*, float*)':
_P004_Dallas:174: error: 'Plugin_004_DS_reset' was not declared in this scope
_P004_Dallas:175: error: 'Plugin_004_DS_write' was not declared in this scope
   Plugin_004_DS_write(0x55);           // Choose ROM
_P004_Dallas:189: error: 'Plugin_004_DS_read' was not declared in this scope
     ScratchPad[i] = Plugin_004_DS_read();
_P004_Dallas:191: error: 'Plugin_004_DS_crc8' was not declared in this scope
   if (Plugin_004_DS_crc8(ScratchPad, 8) != ScratchPad[8])
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'uint8_t Plugin_004_DS_search(uint8_t*)':
_P004_Dallas:282: error: 'Plugin_004_DS_write' was not declared in this scope
     Plugin_004_DS_write(0xF0);
_P004_Dallas:288: error: 'Plugin_004_DS_read_bit' was not declared in this scope
       id_bit = Plugin_004_DS_read_bit();
_P004_Dallas:328: error: 'Plugin_004_DS_write_bit' was not declared in this scope
         Plugin_004_DS_write_bit(search_direction);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'uint8_t Plugin_004_DS_read()':
_P004_Dallas:380: error: 'Plugin_004_DS_read_bit' was not declared in this scope
     if (Plugin_004_DS_read_bit())
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'void Plugin_004_DS_write(uint8_t)':
_P004_Dallas:394: error: 'Plugin_004_DS_write_bit' was not declared in this scope
     Plugin_004_DS_write_bit( (bitMask & ByteToWrite)?1:0);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P005_DHT.ino: In function 'boolean Plugin_005(byte, EventStruct*, String&)':
_P005_DHT:110: error: 'Plugin_005_read_dht_dat' was not declared in this scope
               byte data = Plugin_005_read_dht_dat();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'boolean Plugin_006(byte, EventStruct*, String&)':
_P006_BMP085:50: error: 'Plugin_006_bmp085_begin' was not declared in this scope
           Plugin_006_bmp085_begin();
_P006_BMP085:52: error: 'Plugin_006_bmp085_readTemperature' was not declared in this scope
         UserVar[event->BaseVarIndex] = Plugin_006_bmp085_readTemperature();
_P006_BMP085:53: error: 'Plugin_006_bmp085_readPressure' was not declared in this scope
         UserVar[event->BaseVarIndex + 1] = ((float)Plugin_006_bmp085_readPressure()) / 100;
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'boolean Plugin_006_bmp085_begin()':
_P006_BMP085:95: error: 'Plugin_006_bmp085_read8' was not declared in this scope
   if (Plugin_006_bmp085_read8(0xD0) != 0x55) return false;
_P006_BMP085:98: error: 'Plugin_006_bmp085_read16' was not declared in this scope
   ac1 = Plugin_006_bmp085_read16(BMP085_CAL_AC1);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'uint16_t Plugin_006_bmp085_readRawTemperature()':
_P006_BMP085:117: error: 'Plugin_006_bmp085_write8' was not declared in this scope
   Plugin_006_bmp085_write8(BMP085_CONTROL, BMP085_READTEMPCMD);
_P006_BMP085:119: error: 'Plugin_006_bmp085_read16' was not declared in this scope
   return Plugin_006_bmp085_read16(BMP085_TEMPDATA);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'uint32_t Plugin_006_bmp085_readRawPressure()':
_P006_BMP085:128: error: 'Plugin_006_bmp085_write8' was not declared in this scope
   Plugin_006_bmp085_write8(BMP085_CONTROL, BMP085_READPRESSURECMD + (oversampling << 6));
_P006_BMP085:132: error: 'Plugin_006_bmp085_read16' was not declared in this scope
   raw = Plugin_006_bmp085_read16(BMP085_PRESSUREDATA);
_P006_BMP085:134: error: 'Plugin_006_bmp085_read8' was not declared in this scope
   raw |= Plugin_006_bmp085_read8(BMP085_PRESSUREDATA + 2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P008_RFID.ino: In function 'boolean Plugin_008(byte, EventStruct*, String&)':
_P008_RFID:66: error: 'Plugin_008_interrupt1' was not declared in this scope
         attachInterrupt(Settings.TaskDevicePin1[event->TaskIndex], Plugin_008_interrupt1, FALLING);
_P008_RFID:67: error: 'Plugin_008_interrupt2' was not declared in this scope
         attachInterrupt(Settings.TaskDevicePin2[event->TaskIndex], Plugin_008_interrupt2, FALLING);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P009_MCP.ino: In function 'boolean Plugin_009(byte, EventStruct*, String&)':
_P009_MCP:46: error: 'Plugin_009_Read' was not declared in this scope
         switchstate[event->TaskIndex] = Plugin_009_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P009_MCP:48: error: 'Plugin_009_Config' was not declared in this scope
         Plugin_009_Config(Settings.TaskDevicePort[event->TaskIndex], 1);
_P009_MCP:55: error: 'Plugin_009_Read' was not declared in this scope
         int state = Plugin_009_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P009_MCP:82: error: 'Plugin_009_Write' was not declared in this scope
           Plugin_009_Write(event->Par1, event->Par2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P013_HCSR04.ino: In function 'boolean Plugin_013(byte, EventStruct*, String&)':
_P013_HCSR04:101: error: 'Plugin_013_interrupt' was not declared in this scope
         attachInterrupt(Settings.TaskDevicePin2[event->TaskIndex], Plugin_013_interrupt, CHANGE);
_P013_HCSR04:111: error: 'Plugin_013_read' was not declared in this scope
           float value = Plugin_013_read();
_P013_HCSR04:133: error: 'Plugin_013_read' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P014_SI7021.ino: In function 'boolean Plugin_014(byte, EventStruct*, String&)':
_P014_SI7021:118: error: 'Plugin_014_si7021_begin' was not declared in this scope
           Plugin_014_init = Plugin_014_si7021_begin(res);
_P014_SI7021:122: error: 'Plugin_014_si7021_readValues' was not declared in this scope
         if (Plugin_014_init && Plugin_014_si7021_readValues(res) == 0) {
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P014_SI7021.ino: In function 'boolean Plugin_014_si7021_begin(uint8_t)':
_P014_SI7021:158: error: 'Plugin_014_si7021_setResolution' was not declared in this scope
   ret = Plugin_014_si7021_setResolution(resolution);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P015_TLS2561.ino: In function 'boolean Plugin_015(byte, EventStruct*, String&)':
_P015_TLS2561:157: error: 'Plugin_015_tls2561_begin' was not declared in this scope
           Plugin_015_init = Plugin_015_tls2561_begin(integration);
_P015_TLS2561:162: error: 'Plugin_015_tsl2561_calcLux' was not declared in this scope
           ret = Plugin_015_tsl2561_calcLux(integration);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P015_TLS2561.ino: In function 'boolean Plugin_015_tls2561_begin(uint8_t)':
_P015_TLS2561:194: error: 'Plugin_015_tsl2561_writeRegister' was not declared in this scope
   ret = Plugin_015_tsl2561_writeRegister(TSL2561_CONTROL, TSL2561_POWER_UP);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'boolean Plugin_017(byte, EventStruct*, String&)':
_P017_PN532:85: error: 'getFirmwareVersion' was not declared in this scope
           uint32_t versiondata = getFirmwareVersion();
_P017_PN532:101: error: 'writeCommand' was not declared in this scope
           if (writeCommand(Plugin_017_pn532_packetbuffer, 4))
_P017_PN532:107: error: 'readPassiveTargetID' was not declared in this scope
         success = readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'uint32_t getFirmwareVersion()':
_P017_PN532:139: error: 'writeCommand' was not declared in this scope
   if (writeCommand(Plugin_017_pn532_packetbuffer, 1)) {
_P017_PN532:144: error: 'readResponse' was not declared in this scope
   int16_t status = readResponse(Plugin_017_pn532_packetbuffer, sizeof(Plugin_017_pn532_packetbuffer),10);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'bool readPassiveTargetID(uint8_t, uint8_t*, uint8_t*)':
_P017_PN532:171: error: 'writeCommand' was not declared in this scope
   if (writeCommand(Plugin_017_pn532_packetbuffer, 3)) {
_P017_PN532:176: error: 'readResponse' was not declared in this scope
   if (readResponse(Plugin_017_pn532_packetbuffer, sizeof(Plugin_017_pn532_packetbuffer), timeout) < 0) {
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'int8_t writeCommand(const uint8_t*, uint8_t)':
_P017_PN532:231: error: 'readAckFrame' was not declared in this scope
   return readAckFrame();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P019_PCF8574.ino: In function 'boolean Plugin_019(byte, EventStruct*, String&)':
_P019_PCF8574:46: error: 'Plugin_019_Read' was not declared in this scope
         switchstate[event->TaskIndex] = Plugin_019_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P019_PCF8574:53: error: 'Plugin_019_Read' was not declared in this scope
         int state = Plugin_019_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P019_PCF8574:80: error: 'Plugin_019_Write' was not declared in this scope
           Plugin_019_Write(event->Par1, event->Par2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P022_PCA9685.ino: In function 'boolean Plugin_022(byte, EventStruct*, String&)':
_P022_PCA9685:56: error: 'Plugin_022_writeRegister' was not declared in this scope
           Plugin_022_writeRegister(PCA9685_MODE1, (byte)0x01); // reset the device
_P022_PCA9685:69: error: 'Plugin_022_Write' was not declared in this scope
           Plugin_022_Write(event->Par1, event->Par2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'boolean Plugin_023(byte, EventStruct*, String&)':
_P023_OLED:92: error: 'Plugin_023_StartUp_OLED' was not declared in this scope
         Plugin_023_StartUp_OLED();
_P023_OLED:93: error: 'Plugin_023_clear_display' was not declared in this scope
         Plugin_023_clear_display();
_P023_OLED:94: error: 'Plugin_023_sendStrXY' was not declared in this scope
         Plugin_023_sendStrXY((char*)"ESP Easy ", 0, 0);
_P023_OLED:166: error: 'Plugin_023_sendStrXY' was not declared in this scope
             Plugin_023_sendStrXY(tmp, x, 0);
_P023_OLED:186: error: 'Plugin_023_sendStrXY' was not declared in this scope
           Plugin_023_sendStrXY(tmp, event->Par1 - 1, event->Par2 - 1);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_reset_display()':
_P023_OLED:298: error: 'Plugin_023_displayOff' was not declared in this scope
   Plugin_023_displayOff();
_P023_OLED:299: error: 'Plugin_023_clear_display' was not declared in this scope
_P023_OLED:300: error: 'Plugin_023_displayOn' was not declared in this scope
   Plugin_023_displayOn();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_StartUp_OLED()':
_P023_OLED:306: error: 'Plugin_023_init_OLED' was not declared in this scope
   Plugin_023_init_OLED();
_P023_OLED:308: error: 'Plugin_023_displayOff' was not declared in this scope
_P023_OLED:309: error: 'Plugin_023_setXY' was not declared in this scope
   Plugin_023_setXY(0, 0);
_P023_OLED:310: error: 'Plugin_023_clear_display' was not declared in this scope
_P023_OLED:311: error: 'Plugin_023_displayOn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_displayOn()':
_P023_OLED:317: error: 'Plugin_023_sendcommand' was not declared in this scope
   Plugin_023_sendcommand(0xaf);        //display on
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_displayOff()':
_P023_OLED:323: error: 'Plugin_023_sendcommand' was not declared in this scope
   Plugin_023_sendcommand(0xae);    //display off
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_clear_display()':
_P023_OLED:332: error: 'Plugin_023_setXY' was not declared in this scope
     Plugin_023_setXY(k, 0);
_P023_OLED:336: error: 'Plugin_023_SendChar' was not declared in this scope
         Plugin_023_SendChar(0);         //clear all COL
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_sendCharXY(unsigned char, int, int)':
_P023_OLED:357: error: 'Plugin_023_setXY' was not declared in this scope
   Plugin_023_setXY(X, Y);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P090_Event.ino: In function 'boolean Plugin_090(byte, EventStruct*, String&)':
_P090_Event:257: error: 'Plugin_090_Action' was not declared in this scope
           Plugin_090_Action(event->TaskIndex, ExtraTaskSettings.TaskDevicePluginConfigLong[0], ExtraTaskSettings.TaskDevicePluginConfigLong[1], ExtraTaskSettings.TaskDevicePluginConfigLong[2]);
_P090_Event:275: error: 'Plugin_090_Action' was not declared in this scope
_P090_Event:292: error: 'Plugin_090_Action' was not declared in this scope
_P090_Event:359: error: 'Plugin_090_Action' was not declared in this scope
_P090_Event:361: error: 'Plugin_090_Action' was not declared in this scope
               Plugin_090_Action(event->TaskIndex, ExtraTaskSettings.TaskDevicePluginConfigLong[4], ExtraTaskSettings.TaskDevicePluginConfigLong[5], ExtraTaskSettings.TaskDevicePluginConfigLong[6]);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\__CPlugin.ino: In function 'void CPluginInit()':
__CPlugin:118: error: 'CPluginCall' was not declared in this scope
   CPluginCall(CPLUGIN_PROTOCOL_ADD, 0);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\__Plugin.ino: In function 'void PluginInit()':
__Plugin:442: error: 'PluginCall' was not declared in this scope
   PluginCall(PLUGIN_DEVICE_ADD, 0, dummyString);
exit status 1
Invalid library found in C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1084-ga39ce29\libraries\esp8266: C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1084-ga39ce29\libraries\esp8266
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
I then updated the libraries and I am getting a new error:
Board nodemcuv2 (platform esp8266, package esp8266) is unknown
Error compiling.
Invalid library found in C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\esp8266: C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\esp8266
I am x-posting this from the ESP8266 Forums (http://www.esp8266.com/viewtopic.php?f=32&t=7424). Any help is appreciated. Thank you!
costo
Re: ESP EASY SKETCH UPLOAD ERROR
#2 Post by costo » 03 Jan 2016, 10:59
1. It looks like you are using an old ESP8266 library in the boardmanager you can check the version. Your's is 1.6.5-947-g39819f0.
2. You are using Arduino 1.6.7. and version 1.6.5 is the version which is advised for using with the esp8266 library.
So my advice is to go back to IDE 1.6.5 , then go into preferences and verify/change the 'Additional Boards Manager URL's' to
http://arduino.esp8266.com/stable/packa ... index.json
Then go into the boards Manager in Tools and install ESP8266 libraries Version 2.0.0
That should fix the problems
edit: The URL is: http ://arduino.esp8266.com/stable/package_esp8266com_index.json (without the space between http and : )
jeremiahlandi
#3 Post by jeremiahlandi » 03 Jan 2016, 21:10
costo,
I switched to the 1.6.5 version and everything started to work! Thank you for the help.
MonkeyTown
#4 Post by MonkeyTown » 08 May 2016, 02:43
costo wrote:1. It looks like you are using an old ESP8266 library in the boardmanager you can check the version. Your's is 1.6.5-947-g39819f0.
THANK YOU!! I was about to pull the last few remaining hair from my poor head...and your post has finally allowed me to upload the sketch.
From my current trial and error I conclude this:
A) Running Arduino 1.6.4 / 1.6.5 / 1.6.8 - NO DIFFERENCE
B) MQTT Library - ANYTHING ELSE THAN 1.9.1 (as bundled with stable R_78 of EASYESP) WILL NOT COMPILE WITH MQTT LIB RELATED ERRORS - sad as the latest version is 2.6!
C) BOARD MANAGER - ESP 8266 2.0 - WORKS, 2.1 or 2.2 DOESN'T - resulting in compile errors "invalid conversion from 'byte ...."
D) LIQUID_CRYSTAL_I2C library bundled in R_78 WORKS without warnings, updated version has warning about library specifies support for AVR based devices, might not work with current board...
Is there any reason why only MQTT 1.9.1 works and why the latest stable release uses such an outdated version? I mean it in a very sincere way, I am a newbie when it comes to NodeMcu/ESP and MQTT, but is seems weird to use library that is several versions outdated... same with Board manager package for ESP....
THANKS for any info on this and also for the help provided already..much appreciated!!
zuzalite
Re: [SOLVED] ESP EASY SKETCH UPLOAD ERROR
#5 Post by zuzalite » 19 Jul 2016, 20:58
This guy(pspranav7) was solved this problem, NOT NEED to GO BACK to IDE 1.6.5!!!!!!!
Works fine in IDE 1.6.9 and the newest (2.3.0) Esp board.txt!!!!!!!!!!!!!!!!!
http://www.instructables.com/id/Program ... /?ALLSTEPS
MonkeyTown
#6 Post by MonkeyTown » 20 Jul 2016, 02:12
The ONLY way I managed to compile and upload the latest build 110:
IDE 1.6.8 (presume it would work with latest)
Boards manager 2.3.0
PubSubClient by Nick O'Leary version 2.4.0. (actually worked with 2.3.0, but not higher)
Short of digging through the code and changing stuff, the only way it would compile for me without PubSub MQTT errors on compile is with this combo. Just thought someone can have similar problems...
Olivier
#7 Post by Olivier » 21 Jul 2016, 22:42
+1 helping me a lot
Arduino IDE 1.6.9
ESP8266 2.3.0
PubSubClient 2.6 (seemingly CHANGES.TXT doesn't mention the 2.6 updates and remain @ 2.4).
thks
PeteK
#8 Post by PeteK » 31 Jul 2016, 17:41
Not quite sure this problem is actually solved!
My environment:
Arduino IDE 1.6.9
ESP8266 2.3.0 which includes PubSubClient 2.6
ESP Easy R108 which includes PubSubClient 1.9
At least one example from PubSubClient 2.6 (mqtt_esp8266 which is not in the 1.9 examples) will not compile with version 1.9 and ESP Easy will not compile with 2.6.
Hopefully the ESP Easy package can be altered to use the more up to date PubSubClient.
Drum
#9 Post by Drum » 01 Aug 2016, 05:50
For R108 read the tutorial. The configuration you are using does not work corrctly until R114, which is stated in the ESPEasy realeses thread. Reading the instructions and searching the forum will answer most questions.
PeteK
#10 Post by PeteK » 01 Aug 2016, 18:49
Thank you for pointing me in the right direction (and doing so politely) - now working fine.
Pete
piokuc
#11 Post by piokuc » 14 Mar 2017, 09:57
I try upload sketch and i have a problem.
On Arduino ISE 1.6.9 i have an error downloading http://arduino.esp8266.com/stable/packa ... index.json
But on other PC on arduino IDE 1.6.5 i have this error:
ESPEasy:610: error: 'FreeMem' was not declared in this scope
ESPEasy:614: error: 'initLog' was not declared in this scope
ESPEasy:617: error: 'SpiffsSectors' was not declared in this scope
ESPEasy:624: error: 'emergencyReset' was not declared in this scope
ESPEasy:628: error: 'addLog' was not declared in this scope
ESPEasy:630: error: 'fileSystemCheck' was not declared in this scope
ESPEasy:631: error: 'LoadSettings' was not declared in this scope
ESPEasy:649: error: 'ResetFactory' was not declared in this scope
ESPEasy:656: error: 'BuildFixes' was not declared in this scope
ESPEasy:666: error: 'hardwareInit' was not declared in this scope
ESPEasy:669: error: 'WifiAPconfig' was not declared in this scope
ESPEasy:670: error: 'WifiConnect' was not declared in this scope
ESPEasy:685: error: 'PluginInit' was not declared in this scope
ESPEasy:686: error: 'CPluginInit' was not declared in this scope
ESPEasy:687: error: 'NPluginInit' was not declared in this scope
ESPEasy:689: error: 'WebServerInit' was not declared in this scope
ESPEasy:700: error: 'getProtocolIndex' was not declared in this scope
ESPEasy:702: error: 'MQTTConnect' was not declared in this scope
ESPEasy:704: error: 'sendSysInfoUDP' was not declared in this scope
ESPEasy:707: error: 'readFromRTC' was not declared in this scope
ESPEasy:709: error: 'readUserVarFromRTC' was not declared in this scope
ESPEasy:726: error: 'saveToRTC' was not declared in this scope
ESPEasy:738: error: 'initTime' was not declared in this scope
ESPEasy:753: error: 'rulesProcessing' was not declared in this scope
ESPEasy:757: error: 'saveToRTC' was not declared in this scope
ESPEasy:772: error: 'WifiConnect' was not declared in this scope
ESPEasy:778: error: 'PluginCall' was not declared in this scope
ESPEasy:779: error: 'serial' was not declared in this scope
ESPEasy:788: error: 'deepSleep' was not declared in this scope
ESPEasy.ino: In function 'void run50TimesPerSecond()':
ESPEasy:820: error: 'PluginCall' was not declared in this scope
ESPEasy.ino: In function 'void run10TimesPerSecond()':
ESPEasy:830: error: 'PluginCall' was not declared in this scope
ESPEasy:831: error: 'checkUDP' was not declared in this scope
ESPEasy:834: error: 'rulesProcessing' was not declared in this scope
ESPEasy.ino: In function 'void runOncePerSecond()':
ESPEasy:850: error: 'saveToRTC' was not declared in this scope
ESPEasy:853: error: 'addLog' was not declared in this scope
ESPEasy:862: error: 'delayedReboot' was not declared in this scope
ESPEasy:870: error: 'WifiDisconnect' was not declared in this scope
ESPEasy:884: error: 'checkTime' was not declared in this scope
ESPEasy:887: error: 'PluginCall' was not declared in this scope
ESPEasy:892: error: 'rulesTimers' was not declared in this scope
ESPEasy.ino: In function 'void runEach30Seconds()':
ESPEasy:930: error: 'FreeMem' was not declared in this scope
ESPEasy:933: error: 'addLog' was not declared in this scope
ESPEasy:934: error: 'sendSysInfoUDP' was not declared in this scope
ESPEasy:935: error: 'refreshNodeList' was not declared in this scope
ESPEasy:936: error: 'MQTTCheck' was not declared in this scope
ESPEasy:938: error: 'SSDP_update' was not declared in this scope
ESPEasy:947: error: 'WifiCheck' was not declared in this scope
ESPEasy.ino: In function 'void checkSensors()':
ESPEasy:971: error: 'saveUserVarToRTC' was not declared in this scope
ESPEasy.ino: In function 'void SensorSendTask(byte)':
ESPEasy:997: error: 'getDeviceIndex' was not declared in this scope
ESPEasy:998: error: 'LoadTaskSettings' was not declared in this scope
ESPEasy:1011: error: 'PluginCall' was not declared in this scope
ESPEasy:1028: error: 'Calculate' was not declared in this scope
ESPEasy:1033: error: 'sendData' was not declared in this scope
ESPEasy.ino: In function 'boolean checkSystemTimers()':
ESPEasy:1098: error: 'timeOut' was not declared in this scope
ESPEasy:1113: error: 'timeOut' was not declared in this scope
ESPEasy:1116: error: 'parseCommandString' was not declared in this scope
ESPEasy:1117: error: 'PluginCall' was not declared in this scope
ESPEasy:1118: error: 'ExecuteCommand' was not declared in this scope
ESPEasy.ino: In function 'void backgroundtasks()':
ESPEasy:1136: error: 'statusLED' was not declared in this scope
ESPEasy:1137: error: 'checkUDP' was not declared in this scope
Multiple libraries were found for "Servo.h"
 Used: C:\Users\pkuchciak\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Servo
 Not used: C:\Users\pkuchciak\Desktop\arduino-1.6.5-r5-windows\arduino-1.6.5-r5\libraries\Servo
Multiple libraries were found for "SD.h"
 Used: C:\Users\pkuchciak\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
 Not used: C:\Users\pkuchciak\Desktop\arduino-1.6.5-r5-windows\arduino-1.6.5-r5\libraries\SD
Please help me...
