Syntax for OpenHAB folder
Posted: 02 Oct 2018, 14:35
by Sasch600xt
Hello all
i try to get an folder after root.
but i am not sure how the correct syntax will be ?
i did try :
Testbereich
/Testbereich
/Testbereich/
but nothing worked so far
here is a screenshot:
- Screenshot 2018-10-02 14.30.46.png (95.5 KiB) Viewed 3339 times
thank you so much for your help
Sascha
Re: Syntax for OpenHAB folder
Posted: 02 Oct 2018, 14:39
by grovkillen
That setting got noting to do with folders or root. It's the topic settings for the MQTT protocol.
Posted: 02 Oct 2018, 14:41
by Sasch600xt
oh, ok.
then it was a missunderstood of my head
Posted: 02 Oct 2018, 14:50
by waspie
what is it you're trying to do?
if you want to see what ESP is sending to MQTT so you know how to define your items in openhab then you can sub to mqtt like:
mosquitto_sub -h IPofYOURbroker -t '#'
and then get the ESP to send something. then you'll see exactly what's happening and you can transfer that to openhab
output from mosquitto:
/UtilityRoom/Furnace_Temp/FUR_IN 71.71
/UtilityRoom/furnaceTemp/FUR_OUT 70.81
/UtilityRoom/Evaporator_Temp/EVP_TEMP 71.94
/UtilityRoom/uptime/urUptime 4238.00
/beacon/sensor/journey-signal/state -71
so an item definition in openhab would look like:
Number Evap "Furnace evap Temp [%.1f °F]" <temperature> (nestTemps1,gTemps) { mqtt="<[oh2:/UtilityRoom/Evaporator_Temp/EVP_TEMP:state:default]" }
