http://www.letscontrolit.com/forum/view ... 005#p33005
Everything works fine for more than 12 hours. Then I changed its place to the plant that it should control and change the USB-device. It runs fine for about one hour. Then it stops working. Nothing seems to help, the blue LED don't lighten. Connect grn with GPIO0 to flash not, connect TX and RX for factory reset not.
But then I feel that the WeMos - exactly the voltage control (what's its english name?) beside the USB plug was very hot. And really: Disconnect the USB, connect the 3.3 V pin and ground with a 3.3 V-battery, and the WeMos works fine.
Is the voltage control so sensible? Perhapa my soil noisture sensor needs to much power? My plan is to use in summertime a small photovoltaik and a battery, so I tought the WeMos is the better device than the NodeMCU? We will se, now WeMos number 2 is running. If it also crashes I get the answer
Anyway, perhaps someone helps this if a WeMos seems to be damaged: Try the way to use the 3.3 voltage.
