hi i have last build of espeasy
i set a task with a normal switch and set for example gpio0 and deselect inversed logic
when i give the command:
http://192.168.0.155/control?cmd=GPIO,0,1
i measure +3,3v on GPIO0
device page show gpio0 = 1
http://192.168.0.155/control?cmd=GPIO,0,0
i measure 0v on GPIO0
device page show gpio0 = 0
now if i select inversed logic:
i measure +3,3v on GPIO0 (same situation of not selecting inverse logic)
device page show gpio0 = 0 (opposite)
http://192.168.0.155/control?cmd=GPIO,0,0 (same situation of not selecting inverse logic)
device page show gpio0 = 1 (opposite)
so it seams that selecting inverse logic, only change what is show in device page, but the command "high" and "low" will drive is the same way of not selecting inverse logic.
it's on purpose that???
bug in switch plugin about "inversed" option?
Re: bug in switch plugin about "inversed" option?
You are using an input plugin (switch) and are switching the output using the GPIO command. For GPIO commands there is no option to inverse the output, 1 is high and 0 is low.
