KAKU AWST-8802
About receivers, transmitters, transceivers, connections, antennas etc.
Paulbat
KAKU AWST-8802
#1 Post by Paulbat » 21 Dec 2018, 15:41
Hi All,
I have an KAKU AWST-8802 switch, which I want to use to trigger scene's/groups in Domoticz. It works fine untill I push the buttons further away from the RFlink.
Already like 4 meters away from the RFlink, the signals often don't get received. Is there something i can do about this?
I added debug info (unhandled) beneath (close to RFLINK -> further away)
10;rfudebug=on;
20;3F;RFUDEBUG=ON;
20;40;NewKaku;ID=0195ec9a;SWITCH=c;CMD=OFF;
20;41;NewKaku;ID=0195ec9a;SWITCH=c;CMD=ON;
20;42;NewKaku;ID=0195ec9a;SWITCH=c;CMD=OFF;
20;43;NewKaku;ID=0195ec9a;SWITCH=c;CMD=ON;
20;44;NewKaku;ID=0195ec9a;SWITCH=c;CMD=OFF;
20;45;NewKaku;ID=0195ec9a;SWITCH=c;CMD=ON;
20;46;NewKaku;ID=0195ec9a;SWITCH=c;CMD=OFF;
20;47;NewKaku;ID=0195ec9a;SWITCH=c;CMD=ON;
20;48;NewKaku;ID=0195ec9a;SWITCH=c;CMD=OFF;
20;49;DEBUG;Pulses=50;Pulses(uSec)=240,210,150,1200,150,180,150,210,150,1200,150,180,150,1200,150,1200,150,210,150,210,150,1200,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,630;
20;4A;NewKaku;ID=0195ec9a;SWITCH=c;CMD=ON;
20;4B;DEBUG;Pulses=60;Pulses(uSec)=240,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1200,150,1200,150,210,150,180,150,1230,150,180,150,1200,150,1200,150,210,150,1200,150,180,150,180,150,660;
20;4C;DEBUG;Pulses=108;Pulses(uSec)=210,180,120,180,150,1140,150,1140,150,210,120,180,150,1170,120,1140,150,180,150,1200,150,210,150,1200,150,180,150,1200,150,180,150,180,150,1200,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1200,150,1200,150,210,150,180,150,1230,150,180,150,1200,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,180,150,1200,150,180,150,1200,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,180,150,6990;
20;4D;NewKaku;ID=0195ec9a;SWITCH=c;CMD=OFF;
20;4E;DEBUG;Pulses=40;Pulses(uSec)=210,210,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,1230,120,210,150,210,150,1230,150,210,150,810;
20;4F;DEBUG;Pulses=45;Pulses(uSec)=210,1230,150,240,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,210,150,1230,150;
20;50;DEBUG;Pulses=48;Pulses(uSec)=180,240,150,1230,150,1200,150,210,150,180,150,1200,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,180,150,690;
20;51;DEBUG;Pulses=48;Pulses(uSec)=210,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1200,150,180,150,30;
20;52;DEBUG;Pulses=49;Pulses(uSec)=210,1200,150,210,150,180,150,1200,150,1200,150,210,150,210,150,1200,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1200,180;
20;53;DEBUG;Pulses=41;Pulses(uSec)=210,2580,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,1200,150,210,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150;
20;54;DEBUG;Pulses=40;Pulses(uSec)=210,2610,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,180,150,1200,150,750;
20;55;DEBUG;Pulses=39;Pulses(uSec)=240,2580,150,210,150,1200,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,180,150,1230,150;
20;56;DEBUG;Pulses=28;Pulses(uSec)=210,180,120,1140,120,180,150,180,150,1170,150,1140,150,180,120,180,120,1170,150,180,150,1230,150,180,150,1230,150,0;
20;57;DEBUG;Pulses=38;Pulses(uSec)=210,2460,120,180,150,1140,150,1140,150,180,120,1170,150,210,150,210,150,1230,150,210,150,1230,150,1200,150,210,150,210,150,1200,150,1200,150,210,150,210,150,780;
20;58;DEBUG;Pulses=28;Pulses(uSec)=210,1140,150,180,120,1140,120,180,150,180,150,1170,120,1140,150,180,120,180,150,1230,150,210,150,1230,150,210,150,810;
20;59;DEBUG;Pulses=37;Pulses(uSec)=210,2460,150,180,120,1140,120,1140,120,210,120,1200,150,210,150,210,150,1230,150,210,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,180,150;
20;5A;DEBUG;Pulses=30;Pulses(uSec)=210,1140,150,1140,120,180,120,1170,120,180,150,180,120,1170,150,1170,150,210,150,210,150,1230,150,180,150,1230,150,180,150,30;
20;5B;DEBUG;Pulses=44;Pulses(uSec)=210,1230,120,240,120,1230,150,1200,150,210,150,210,150,1230,150,1230,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,1020;
20;5C;DEBUG;Pulses=48;Pulses(uSec)=210,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1200,150,210;
20;5D;DEBUG;Pulses=44;Pulses(uSec)=90,1200,150,210,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,330;
20;5E;DEBUG;Pulses=48;Pulses(uSec)=210,210,150,180,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,1230,150,210,150,1200,150,210,150,180,150,1200,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,60;
20;5F;DEBUG;Pulses=46;Pulses(uSec)=210,210,150,210,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,840;
20;60;DEBUG;Pulses=42;Pulses(uSec)=210,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,210,150,1200,150,1200,150,210,150,180,150,1200,150,1200,150,210,150,210,150,1200,150,1200,150,210,150,600;
20;61;DEBUG;Pulses=44;Pulses(uSec)=210,2580,150,210,150,1200,150,1200,150,210,150,1200,150,210,150,180,150,1200,150,180,150,1230,150,1200,150,210,150,180,150,1200,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,120;
20;62;DEBUG;Pulses=43;Pulses(uSec)=210,2580,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1200,150,180,150,1200,150,1200,150,210,150,180,150,1200,150,1200,150,210,150,210,150,1230,150,1170,210,180,180;
20;63;DEBUG;Pulses=40;Pulses(uSec)=240,2580,150,180,150,1200,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,180,150,1200,150,1200,150,210,150,210,150,1200,150,360;
20;64;DEBUG;Pulses=40;Pulses(uSec)=210,2580,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1200,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,180,150,1140,210,150;
20;65;DEBUG;Pulses=46;Pulses(uSec)=210,1200,150,210,150,1200,150,210,150,210,150,1200,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,840;
20;66;DEBUG;Pulses=46;Pulses(uSec)=210,1200,150,210,150,1200,150,210,150,180,150,1200,150,210,150,1200,150,1200,150,210,150,180,150,1200,150,1200,150,210,150,210,150,1200,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,60;
20;67;DEBUG;Pulses=44;Pulses(uSec)=240,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,1200,120,30;
20;68;DEBUG;Pulses=46;Pulses(uSec)=210,210,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,1200,150,210,150,1230,150,1200,150,210,150,210,150,1200,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,600;
20;69;DEBUG;Pulses=42;Pulses(uSec)=180,240,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,750;
20;6A;DEBUG;Pulses=44;Pulses(uSec)=60,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,180,150,1230,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,240;
20;6B;DEBUG;Pulses=46;Pulses(uSec)=210,210,150,210,150,1200,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,210,150,1200,150,1200,150,210,150,210,150,1230,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1020;
20;6C;DEBUG;Pulses=48;Pulses(uSec)=210,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,210,150,1230,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,270;
20;6D;DEBUG;Pulses=48;Pulses(uSec)=210,210,150,1200,150,210,150,210,150,1200,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,210,150,1230,150,1200,150,210,150,210,150,1230,150,210,150,1230,150,1200,150,210,150,1200,150,210,150,0;
20;6E;DEBUG;Pulses=41;Pulses(uSec)=60,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,210,150,1230,150,1200,150,210,150,210,150,1170,180;
20;6F;DEBUG;Pulses=48;Pulses(uSec)=60,210,150,1200,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,210,150,1230,150,180,150,1230,150,1200,150,210,150,180,150,420;
20;70;DEBUG;Pulses=38;Pulses(uSec)=210,2580,150,180,150,1230,150,1200,150,210,150,1200,150,210,150,180,150,1230,150,180,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150,210,150,210,150,180;
20;71;DEBUG;Pulses=26;Pulses(uSec)=210,1140,120,180,150,1140,150,180,150,180,120,1170,120,1140,150,180,150,210,150,1230,150,180,150,1230,150,750;
20;72;DEBUG;Pulses=35;Pulses(uSec)=210,2460,120,180,120,1140,150,1170,150,210,150,1200,150,210,150,180,150,1230,150,210,150,1230,150,1230,150,210,150,210,150,1230,150,1200,150,210,150;
20;73;DEBUG;Pulses=32;Pulses(uSec)=210,1140,150,180,150,1140,120,1140,120,180,150,1140,150,180,150,180,150,1200,150,1200,150,210,150,210,150,1230,150,180,150,1230,150,30;
20;74;DEBUG;Pulses=31;Pulses(uSec)=210,180,150,1140,150,1140,150,180,120,1140,150,180,150,210,150,1230,150,210,150,1230,150,1200,150,210,150,210,150,1230,150,1200,150;
20;75;DEBUG;Pulses=36;Pulses(uSec)=210,1140,150,180,150,180,150,1140,150,180,120,1170,120,1140,120,210,150,1200,150,210,150,180,150,1230,150,1200,150,210,150,210,150,1230,150,210,150,750;
20;76;DEBUG;Pulses=30;Pulses(uSec)=210,1200,150,210,90,270,150,1230,150,210,150,1200,150,1230,150,210,150,210,150,1200,150,210,150,1200,150,1200,150,210,150,1110;
Do others issue the same?
Thanks a lot,
Paul
