RPIEasy
pitias
Re: RPIEasy
#251 Post by pitias » 11 May 2020, 21:23
Thanks for the reply.
Actually I tried to set the intervals to 300, 301, 302, ... 305 seconds, but the logs were created with no intervals set.
I'll give the new version a try tonight.
enesbcs
Re: RPIEasy
#252 Post by enesbcs » 11 May 2020, 23:20
pitias wrote:
11 May 2020, 21:23
1 second between BLE devices is not a good choice, as they sometimes needs 1-5 seconds to connect. Leave 5-10 seconds between each other for safety.
pitias
Re: RPIEasy
#253 Post by pitias » 12 May 2020, 11:34
I tried the new version tonight. Settings are like you asked them to be (checked "Connect only if BLE local device free" and intervals 91, 101, 111, ...), the effect seems to be the same. It got stuck after 15mins.
Right now I'm trying a new location with an other power supply. The one I used before was a Samsung phone charger with 2.0A, the new one is QC3.0 compatible. The new location is approx. 5m away from the router.
Let's if this makes a difference.
Is there a way to see the RSSI once a device is declared? Or can it only be seen on the hardware tab during the initial scan? I'd like to figure out, if the new location is an overall better place than the original position.
May 11 22:15:12 RPIEasy RPIEasy: Pi Zero W 40 pins
May 11 22:15:13 RPIEasy RPIEasy: Event: System#Boot
May 11 22:15:13 RPIEasy RPIEasy: Webserver starting at port 80
May 11 22:15:13 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:15
May 11 22:15:17 RPIEasy RPIEasy: Pi Zero W 40 pins
May 11 22:15:18 RPIEasy RPIEasy: Event: System#Boot
May 11 22:15:18 RPIEasy RPIEasy: Webserver starting at port 8080
May 11 22:15:19 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:15
May 11 22:15:19 RPIEasy RPIEasy: Event: Network#Connected
May 11 22:15:19 piHWRzero systemd[1]: Stopping User Manager for UID 1000...
May 11 22:15:19 piHWRzero systemd[22757]: Stopped target Default.
May 11 22:15:19 piHWRzero systemd[22757]: Stopped target Basic System.
May 11 22:15:19 piHWRzero systemd[22757]: Stopped target Sockets.
May 11 22:15:19 piHWRzero systemd[22757]: dirmngr.socket: Succeeded.
May 11 22:15:19 piHWRzero systemd[22757]: Closed GnuPG network certificate management daemon.
May 11 22:15:19 piHWRzero systemd[22757]: gpg-agent-extra.socket: Succeeded.
May 11 22:15:19 piHWRzero systemd[22757]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
May 11 22:15:19 piHWRzero systemd[22757]: gpg-agent.socket: Succeeded.
May 11 22:15:19 piHWRzero systemd[22757]: Closed GnuPG cryptographic agent and passphrase cache.
May 11 22:15:19 piHWRzero systemd[22757]: Stopped target Timers.
May 11 22:15:19 piHWRzero systemd[22757]: Stopped target Paths.
May 11 22:15:19 piHWRzero systemd[22757]: gpg-agent-browser.socket: Succeeded.
May 11 22:15:19 piHWRzero systemd[22757]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 11 22:15:19 piHWRzero systemd[22757]: gpg-agent-ssh.socket: Succeeded.
May 11 22:15:19 piHWRzero systemd[22757]: Closed GnuPG cryptographic agent (ssh-agent emulation).
May 11 22:15:19 piHWRzero systemd[22757]: Reached target Shutdown.
May 11 22:15:19 piHWRzero systemd[22757]: systemd-exit.service: Succeeded.
May 11 22:15:19 piHWRzero systemd[22757]: Started Exit the Session.
May 11 22:15:19 piHWRzero systemd[22757]: Reached target Exit the Session.
May 11 22:15:19 piHWRzero systemd[1]: user@1000.service: Succeeded.
May 11 22:15:19 piHWRzero systemd[1]: Stopped User Manager for UID 1000.
May 11 22:15:19 piHWRzero systemd[1]: Stopping User Runtime Directory /run/user/1000...
May 11 22:15:19 piHWRzero systemd[1]: run-user-1000.mount: Succeeded.
May 11 22:15:19 piHWRzero systemd[1]: user-runtime-dir@1000.service: Succeeded.
May 11 22:15:19 piHWRzero systemd[1]: Stopped User Runtime Directory /run/user/1000.
May 11 22:15:19 piHWRzero systemd[1]: Removed slice User Slice of UID 1000.
May 11 22:16:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:16
May 11 22:16:41 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:16:46 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:16:47 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:16:49 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:16:49 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:16:50 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:16:51 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:16:51 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:16:57 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:16:58 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.9
May 11 22:16:58 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=36.0
May 11 22:16:58 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:16:58 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:16:59 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:17:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:17
May 11 22:17:00 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:17:01 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:17:02 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:17:03 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:17:04 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:17:04 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:17:04 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:17:05 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:17:07 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:17:08 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:11 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:17:11 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:17:11 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=36.0
May 11 22:17:11 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:17:11 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:17:14 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:17:17 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:17:19 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:20 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:17:20 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:17:22 RPIEasy RPIEasy: BLE connection failed a4:c1:38:00:e8:ec
May 11 22:17:22 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:17:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:17:23 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:24 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:17:25 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:17:25 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:17:28 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:17:28 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:29 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:17:29 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:17:32 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:33 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:17:34 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:17:34 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:17:35 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:17:35 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:40 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:41 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:17:42 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:17:42 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:17:43 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:17:44 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:17:45 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:17:49 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:17:52 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:17:53 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:54 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:17:54 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:17:54 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:17:54 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:17:54 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:17:54 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:17:55 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:17:55 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:17:55 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:17:56 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:17:56 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:18:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:18
May 11 22:18:01 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:18
May 11 22:18:01 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:18:01 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:18:03 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:18:04 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:18:04 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=35.0
May 11 22:18:04 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:18:04 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:18:04 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:18:05 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:18:10 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:18:12 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:18:13 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:18:14 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:18:17 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:18:17 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=37.0
May 11 22:18:17 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:18:17 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:18:18 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:18:18 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:18:18 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:18:19 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:18:20 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:18:20 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:18:21 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:18:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:18:24 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:18:25 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:18:28 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:18:29 RPIEasy RPIEasy: Event: xi_fe#Temperature=22.5
May 11 22:18:29 RPIEasy RPIEasy: Event: xi_fe#Humidity=38.0
May 11 22:18:29 RPIEasy RPIEasy: Event: xi_fe#Battery=100.0
May 11 22:18:29 RPIEasy RPIEasy: Sending task 6 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:18:31 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:18:31 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:18:32 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:18:37 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:18:42 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:18:43 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:18:43 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:18:44 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:18:45 RPIEasy RPIEasy: BLE connected to a4:c1:38:4b:8c:5f
May 11 22:18:45 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:18:47 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:18:48 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:18:53 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:18:58 RPIEasy RPIEasy: Event: xiDach#Temperature=24.6
May 11 22:18:58 RPIEasy RPIEasy: Event: xiDach#Humidity=38.0
May 11 22:18:58 RPIEasy RPIEasy: Event: xiDach#Battery=100.0
May 11 22:18:58 RPIEasy RPIEasy: Sending task 5 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:18:59 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:18:59 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:19:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:19
May 11 22:19:01 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:19:02 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:19:03 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:19:05 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:19:05 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:19:07 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:19:07 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:19:08 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:19:09 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:19:09 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=36.0
May 11 22:19:09 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:19:10 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:19:11 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:19:12 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:19:18 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:19:22 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.8
May 11 22:19:22 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=36.0
May 11 22:19:22 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:19:22 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:19:22 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:19:42 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:19:51 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:19:52 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:19:56 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:19:56 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:20:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:20
May 11 22:20:04 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:20:05 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:20:05 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:20:05 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:20:05 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:20:07 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:20:08 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:20:11 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:20:14 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:20:16 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:20:16 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=36.0
May 11 22:20:16 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:20:16 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:20:17 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:20:24 RPIEasy RPIEasy: BLE connected to a4:c1:38:4b:8c:5f
May 11 22:20:26 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:20:28 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:20:28 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=37.0
May 11 22:20:28 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:20:28 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:20:38 RPIEasy RPIEasy: Event: xiDach#Temperature=24.6
May 11 22:20:38 RPIEasy RPIEasy: Event: xiDach#Humidity=38.0
May 11 22:20:38 RPIEasy RPIEasy: Event: xiDach#Battery=100.0
May 11 22:20:39 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:20:46 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:20:47 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:20:47 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:20:47 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:20:47 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:20:47 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:20:48 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:20:48 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:20:50 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:20:52 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:20:54 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:20:54 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:20:55 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:20:55 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=36.0
May 11 22:20:55 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:20:55 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:20:55 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:20:56 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:20:57 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:20:58 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:20:59 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:21
May 11 22:21:00 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:21:01 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:02 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:21:03 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:04 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:21:05 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:21:06 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:21:09 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:09 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.8
May 11 22:21:09 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=36.0
May 11 22:21:10 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:21:10 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:21:12 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:18 RPIEasy RPIEasy: BLE connected to a4:c1:38:4b:8c:5f
May 11 22:21:20 RPIEasy RPIEasy: Event: xiDach#Temperature=24.7
May 11 22:21:20 RPIEasy RPIEasy: Event: xiDach#Humidity=38.0
May 11 22:21:20 RPIEasy RPIEasy: Event: xiDach#Battery=100.0
May 11 22:21:20 RPIEasy RPIEasy: Sending task 5 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:21:21 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:22 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:21:23 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:21:23 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:25 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:21:25 RPIEasy RPIEasy: Event: xi_fe#Temperature=22.5
May 11 22:21:25 RPIEasy RPIEasy: Event: xi_fe#Humidity=37.0
May 11 22:21:25 RPIEasy RPIEasy: Event: xi_fe#Battery=100.0
May 11 22:21:25 RPIEasy RPIEasy: Sending task 6 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:21:26 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:21:30 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:21:31 RPIEasy RPIEasy: Event: xi_fe#Temperature=22.5
May 11 22:21:31 RPIEasy RPIEasy: Event: xi_fe#Humidity=37.0
May 11 22:21:31 RPIEasy RPIEasy: Event: xi_fe#Battery=100.0
May 11 22:21:31 RPIEasy RPIEasy: Sending task 6 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:21:54 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:22:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:22
May 11 22:22:12 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:22:15 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:22:15 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=36.0
May 11 22:22:15 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:22:15 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:22:16 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:22:24 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:22:28 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:22:28 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=37.0
May 11 22:22:28 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:22:28 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:22:29 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:22:33 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:22:33 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:22:34 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:22:34 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:22:34 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:22:34 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:22:44 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:22:49 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:22:49 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=35.0
May 11 22:22:49 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:22:50 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:22:56 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:22:57 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.8
May 11 22:22:57 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=36.0
May 11 22:22:57 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:22:57 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:22:58 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:23:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:23
May 11 22:23:01 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:23
May 11 22:23:03 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:23:07 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:23:07 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:23:07 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:23:07 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:23:08 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:15 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:16 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:27 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:28 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:29 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:30 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:31 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:32 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:33 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:35 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:37 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:38 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:39 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:40 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:41 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:42 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:43 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:45 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:45 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:23:46 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:53 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:23:54 RPIEasy RPIEasy: Event: xi_fe#Temperature=22.5
May 11 22:23:54 RPIEasy RPIEasy: Event: xi_fe#Humidity=37.0
May 11 22:23:54 RPIEasy RPIEasy: Event: xi_fe#Battery=100.0
May 11 22:23:55 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:23:56 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:23:58 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:00 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:01 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:24
May 11 22:24:02 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:03 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:05 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:06 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:07 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:08 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:09 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:11 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:12 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:14 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:16 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:17 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:19 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:20 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:22 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:23 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:25 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:25 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:24:28 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:24:29 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:24:35 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:24:38 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.8
May 11 22:24:38 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=36.0
May 11 22:24:38 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:24:39 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:24:40 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:24:41 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:24:45 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:24:50 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:24:50 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=36.0
May 11 22:24:50 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:24:50 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:24:51 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:24:57 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:24:58 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:24:58 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=37.0
May 11 22:24:58 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:24:58 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:24:59 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:25:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:25
May 11 22:25:07 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:25:07 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:25:21 RPIEasy RPIEasy: BLE connection failed a4:c1:38:00:e8:ec
May 11 22:25:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:25:29 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:25:31 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:25:31 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:25:31 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:25:32 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:25:38 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:25:39 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:25:41 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:25:41 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:25:45 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:25:50 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:25:50 RPIEasy RPIEasy: Event: xiBad#Temperature=23.4
May 11 22:25:50 RPIEasy RPIEasy: Event: xiBad#Humidity=44.0
May 11 22:25:50 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:25:50 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:25:51 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:25:51 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:25:57 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:25:58 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:25:58 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=35.0
May 11 22:25:58 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:25:58 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:25:59 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:26
May 11 22:26:01 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:01 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:26:03 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:26:09 RPIEasy RPIEasy: Event: xi_fe#Temperature=22.6
May 11 22:26:09 RPIEasy RPIEasy: Event: xi_fe#Humidity=37.0
May 11 22:26:09 RPIEasy RPIEasy: Event: xi_fe#Battery=100.0
May 11 22:26:09 RPIEasy RPIEasy: Sending task 6 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:26:10 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:11 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:12 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:12 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:13 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:26:15 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:26:16 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.8
May 11 22:26:16 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=36.0
May 11 22:26:16 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:26:17 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:18 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:18 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:26:24 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:26:27 RPIEasy RPIEasy: Event: xi_fe#Temperature=22.5
May 11 22:26:27 RPIEasy RPIEasy: Event: xi_fe#Humidity=37.0
May 11 22:26:27 RPIEasy RPIEasy: Event: xi_fe#Battery=100.0
May 11 22:26:27 RPIEasy RPIEasy: Sending task 6 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:26:28 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:26:33 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.4
May 11 22:26:33 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=35.0
May 11 22:26:33 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:26:33 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:26:33 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:26:33 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:35 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:37 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:37 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:39 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:40 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:41 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:42 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:43 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:44 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:44 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:26:50 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:52 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:26:55 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:26:57 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.7
May 11 22:26:57 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=36.0
May 11 22:26:57 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:26:57 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:26:58 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:26:58 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:26:59 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:27:00 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:27
May 11 22:27:01 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:27:01 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=37.0
May 11 22:27:02 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:27:02 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:27:03 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:03 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:04 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:05 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:07 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:07 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:09 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:09 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:10 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:10 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:27:11 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:14 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:27:14 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:15 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:18 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:27:18 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=37.0
May 11 22:27:18 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:27:18 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:27:19 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:21 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:24 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:25 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:27 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:28 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:29 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:30 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:27:32 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:33 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:39 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:27:41 RPIEasy RPIEasy: Event: xiBad#Temperature=23.2
May 11 22:27:41 RPIEasy RPIEasy: Event: xiBad#Humidity=42.0
May 11 22:27:41 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:27:41 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:27:43 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:27:44 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:45 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:27:49 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:27:50 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:27:55 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:27:56 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.3
May 11 22:27:56 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=34.0
May 11 22:27:56 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:27:56 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:27:57 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:27:59 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:28:00 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:28:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:28
May 11 22:28:03 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:28:09 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:28:09 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:28:10 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:28:11 RPIEasy RPIEasy: BLE connection failed a4:c1:38:00:e8:ec
May 11 22:28:12 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:28:12 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:28:12 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:28:20 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:28:20 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:28:36 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:28:36 piHWRzero dhcpcd[418]: wlan0: carrier lost
May 11 22:28:36 piHWRzero avahi-daemon[253]: Withdrawing address record for 192.168.2.19 on wlan0.
May 11 22:28:36 piHWRzero avahi-daemon[253]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.2.19.
May 11 22:28:46 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:28:47 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:28:54 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:28:55 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:28:58 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:29:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:29
May 11 22:29:04 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:29:06 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.3
May 11 22:29:06 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=34.0
May 11 22:29:06 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:29:06 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:29
May 11 22:29:07 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:29:08 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:29:10 RPIEasy RPIEasy: Event: xiBad#Temperature=23.0
May 11 22:29:10 RPIEasy RPIEasy: Event: xiBad#Humidity=43.0
May 11 22:29:10 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:29:10 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:29:11 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:29:12 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:29:13 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:29:14 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:29:15 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:29:16 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:29:16 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:29:18 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:29:19 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:29:20 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:29:21 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.7
May 11 22:29:21 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=34.0
May 11 22:29:21 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:29:21 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:29:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:29:23 RPIEasy RPIEasy: BLE connection failed a4:c1:38:18:ba:41
May 11 22:29:23 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:29:23 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:29:27 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:29:27 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=36.0
May 11 22:29:27 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:29:27 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:29:28 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:29:32 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:29:32 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:29:34 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:29:34 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.7
May 11 22:29:34 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=35.0
May 11 22:29:34 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:29:34 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:29:36 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:29:36 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:29:37 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:29:39 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:29:39 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:29:42 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:29:43 RPIEasy RPIEasy: Event: xi_fe#Temperature=22.5
May 11 22:29:43 RPIEasy RPIEasy: Event: xi_fe#Humidity=37.0
May 11 22:29:43 RPIEasy RPIEasy: Event: xi_fe#Battery=100.0
May 11 22:29:44 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:29:46 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:29:46 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:29:51 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:29:55 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:29:55 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=36.0
May 11 22:29:55 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:29:55 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:29:56 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:29:57 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:30:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:30
May 11 22:30:01 piHWRzero rsyslogd: action 'action-13-builtin:omfwd' resumed (module 'builtin:omfwd') [v8.1901.0 try https://www.rsyslog.com/e/2359 ]
May 11 22:30:01 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:30:01 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:02 RPIEasy RPIEasy: Event: xiBad#Temperature=23.0
May 11 22:30:02 RPIEasy RPIEasy: Event: xiBad#Humidity=43.0
May 11 22:30:02 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:30:02 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:30:03 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:05 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:06 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:08 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:08 RPIEasy RPIEasy: Event: xiSchlafzimmer#Temperature=22.2
May 11 22:30:08 RPIEasy RPIEasy: Event: xiSchlafzimmer#Humidity=34.0
May 11 22:30:08 RPIEasy RPIEasy: Event: xiSchlafzimmer#Battery=100.0
May 11 22:30:08 RPIEasy RPIEasy: Sending task 2 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:30:10 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:10 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:11 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:30:17 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:30:23 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:24 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:26 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:27 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:28 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:29 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:30 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:31 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:33 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:35 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:36 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:38 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:40 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:40 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:40 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:30:42 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:30:43 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:30:44 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:30:45 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:30:50 RPIEasy RPIEasy: BLE connected to a4:c1:38:fd:9b:fe
May 11 22:30:56 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:31:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:31
May 11 22:31:00 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:31:01 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:31:06 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:31:10 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:31:10 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:31:11 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.7
May 11 22:31:11 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=35.0
May 11 22:31:11 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:31:11 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:31:12 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:31:12 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:31:17 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.7
May 11 22:31:17 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=35.0
May 11 22:31:17 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:31:18 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:31:19 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:31:23 RPIEasy RPIEasy: Event: xiBad#Temperature=23.0
May 11 22:31:23 RPIEasy RPIEasy: Event: xiBad#Humidity=43.0
May 11 22:31:23 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:31:23 RPIEasy RPIEasy: Sending task 4 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:31:24 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:31:25 RPIEasy RPIEasy: BLE connected to a4:c1:38:74:a3:28
May 11 22:31:32 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:31:36 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:31:36 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:31:37 RPIEasy RPIEasy: BLE connection failed a4:c1:38:fd:9b:fe
May 11 22:31:37 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:31:39 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:31:40 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:31:40 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=36.0
May 11 22:31:40 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:31:40 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:31:41 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:31:43 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:31:44 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:31:45 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:31:46 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:31:55 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:31:56 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:31:56 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:31:57 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:18:ba:41
May 11 22:32:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:32
May 11 22:32:02 RPIEasy RPIEasy: BLE connected to a4:c1:38:18:ba:41
May 11 22:32:07 RPIEasy RPIEasy: Event: xiWohnzimmer#Temperature=22.1
May 11 22:32:07 RPIEasy RPIEasy: Event: xiWohnzimmer#Humidity=36.0
May 11 22:32:07 RPIEasy RPIEasy: Event: xiWohnzimmer#Battery=100.0
May 11 22:32:07 RPIEasy RPIEasy: Sending task 3 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:32:08 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:32:08 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:32:09 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:32:19 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:32:20 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:32:21 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:32:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:32:27 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:32:28 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:32:32 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:32:33 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:32:34 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:32:34 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:32:39 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:32:39 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:00:e8:ec
May 11 22:32:44 RPIEasy RPIEasy: BLE connected to a4:c1:38:00:e8:ec
May 11 22:32:49 RPIEasy RPIEasy: Event: xiBad#Temperature=23.0
May 11 22:32:49 RPIEasy RPIEasy: Event: xiBad#Humidity=43.0
May 11 22:32:49 RPIEasy RPIEasy: Event: xiBad#Battery=10.0
May 11 22:32:50 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:32:57 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:32:58 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:33:00 RPIEasy RPIEasy: Event: Clock#Time=Mon,22:33
May 11 22:33:02 RPIEasy RPIEasy: BLE connection failed a4:c1:38:4b:8c:5f
May 11 22:33:03 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:33:04 RPIEasy RPIEasy: BLE connection failed a4:c1:38:d8:e8:7c
May 11 22:33:05 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:33:15 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:33:16 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.7
May 11 22:33:16 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=35.0
May 11 22:33:16 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:33:16 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
May 11 22:33:17 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:74:a3:28
May 11 22:33:19 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:33:19 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:4b:8c:5f
May 11 22:33:21 RPIEasy RPIEasy: BLE connection failed a4:c1:38:74:a3:28
May 11 22:33:22 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:d8:e8:7c
May 11 22:33:32 RPIEasy RPIEasy: BLE connected to a4:c1:38:d8:e8:7c
May 11 22:33:37 RPIEasy RPIEasy: Event: xiArbeitszimmer#Temperature=23.7
May 11 22:33:37 RPIEasy RPIEasy: BLE connection initiated to a4:c1:38:fd:9b:fe
May 11 22:33:37 RPIEasy RPIEasy: Event: xiArbeitszimmer#Humidity=35.0
May 11 22:33:37 RPIEasy RPIEasy: Event: xiArbeitszimmer#Battery=100.0
May 11 22:33:37 RPIEasy RPIEasy: Sending task 1 data to FHEM at http://192.168.2.43:8383/ESPEasy
enesbcs
Re: RPIEasy
#254 Post by enesbcs » 12 May 2020, 17:04
pitias wrote:
12 May 2020, 11:34
There are a BLE scan device which can scan for online BLE devices - with RSSI... but scan mode can only be active when noone else using BLE dongle.
pitias
Re: RPIEasy
#255 Post by pitias » 12 May 2020, 17:24
I'll give it a shot, once it's stuck again ;)
Right now it has been running smoothly for last 6 hours.
pitias
Re: RPIEasy
#256 Post by pitias » 14 May 2020, 08:13
As RPIEasy has been running smoothly for the last two days, I'm going to change the power supply in order to check the influence.
Something I observed is that there are periods when data is received quite frequently, temperatures are received more often than humidities. On the other hand, tonight there was a period of four hours with no new temperature for a sensor which shows changes pretty often during the day.
Does RPIEasy only show changed values?
BertrandP
Re: RPIEasy
#257 Post by BertrandP » 21 May 2020, 17:45
Hi.
I try to install RPIEasy, but I have those error :
root@RPi0Jardin:/home/pi/rpieasy# ./RPIEasy.py
Init hardware...
Load network settings...
Load GPIO settings...
RPi.GPIO not installed!
I2C smbus not installed!
GPIO init failed
Creating new pinout
Load devices from file
Load controllers from file
Load notifiers from file
17:40:28: Event: System#Boot
17:40:28: Event: Clock#Time=Thu,17:40
17:40:28: Event: Network#Connected
17:40:28: !Webserver can not be started, no available port found!
How install RPI.GPIO ans I2C ?
Do I need to install apach or another things ?
enesbcs
Re: RPIEasy
#258 Post by enesbcs » 22 May 2020, 07:07
BertrandP wrote:
21 May 2020, 17:45
Every dependency can be installed from inside the RPIEasy plugins&dependencies page.
Webserver is provided by the minimal Perver python web server, using only base python libraries. (threading, asyncio, urllib)
BertrandP wrote:
21 May 2020, 17:45
This error message tells, that either you are running multiple http servers/rpieasy already in the background and there are no more free ports found, or there are network library problem as socket.socket() / socket.gethostname() call failed on you installation.
Can yo try to run the following python code to see if any errors written on the linux console?
nettest.py content:
import socket
servers = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
servers.bind((socket.gethostname(), 8080))
servers.close()
BertrandP
Re: RPIEasy
#259 Post by BertrandP » 23 May 2020, 18:30
I got this :
root@RPi0Jardin:/home/pi# python nettest.py
File "nettest.py", line 3, in <module>
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
socket.gaierror: [Errno -2] Name or service not known
enesbcs
Re: RPIEasy
#260 Post by enesbcs » 23 May 2020, 20:40
BertrandP wrote:
23 May 2020, 18:30
You are somehow using a system that is unable to resolve its own name. I've never seen similar before.
https://github.com/pahaz/sshtunnel/issues/56
https://github.com/alessandromaggio/pyt ... /issues/28
Can you use internet on this machine? Is the DNS server is your local router?
update: i've tried to workaround it in todays commit, please download fresh version from github
pitias
Re: RPIEasy
#261 Post by pitias » 28 May 2020, 08:38
I'm having a little trouble with my wifi connection and therefore I'm pinging my router every 15min as a sudo cron-job. If there is no answer, the machine will reboot.
Using the brutal method with a reboot is working, RPIEasy starts up as wanted with all devices and the controller.
#!/bin/bash
ROUTER=192.168.2.8
if ! ping -c 1 -W 3 -I wlan0 -q $ROUTER;
then
  /sbin/reboot
fi
When I try to keep the machine alive and restart the wifi only, I figured out that I have to restart RPIEasy as well. (Do I have to restart bluetooth as well? If yes, how do I do this?)
But after killing and restarting the machine the devices and the controller are not loaded in RPIEasy. I have to reload them using the tools menu.
Is there a more gracefull way of telling RPIEasy to restart rather than using the system reboot?
#!/bin/bash
ROUTER=192.168.2.8
then
  /etc/init.d/networking restart
  /sbin/mii-tool -F 10baseT-HD
# kill RPIEasy and restart it
  /usr/bin/pkill -f Easy
  /usr/bin/python3 /home/pi/tools/rpieasy/RPIEasy.py
  echo Netzwerk und RPIEasy sollten neu gestartet sein
fi
enesbcs
Re: RPIEasy
#262 Post by enesbcs » 28 May 2020, 09:35
pitias wrote:
28 May 2020, 08:38
Yes, for example something like that will work (from a bash script), if you are using the default startup run.sh to autostart RPIEasy:
curl http://localhost/?cmd=exit
If you are using run.sh and killing it, it also autostarts itself, and if you forcing to start another instance than the Tasks and Controllers may be empty, as 2 instance try to use 1 data directory. I have to implement some self-defence against multiple instancing in the future.
Otherwise RPIEasy has its own ping plugin, and simple logic also can be added to Rules.
