Hello all
I have problen with relay (I can't control it) I add switch in espeasy but I cant make it work. below I add my config hope someone help me find solution.
in my router I see device name "czujkap-1" maybe I miss that number "1" ?
https://ibb.co/tKPFVk4
https://ibb.co/NnsWJ70
https://ibb.co/hWN5kqL
https://ibb.co/hmLyxSc
https://ibb.co/pnm2w9q
mega-20190116 + relay (openhab)
Re: mega-20190116 + relay (openhab)
I manage to get it work but…
I use:
MQTT Command: “/czujkap/gpio/12”
ON Command set to 1
OFF Command set to 0
When I turn switch on in paper ui OH relay turn on but When I switch to off relay stay ON (red light still on)
What is the proper way to read status of relay/switch I use now:
“/czujkap/gpio/12/state” But I’m sure its wrong can someone help me to get it work ?
I think when I set gpio to 1 it change state to output and when I try gpio,0 nothing happens because gpio is still on output can someone explain me how can I turn off that relay ?
after use command in browser:
http://192.168.1.6/control?cmd=status,GPIO,12
I get:
“log”: “”,
“plugin”: 1,
“pin”: 12,
“mode”: “output”,
“state”: 0
I use:
ON Command set to 1
I get:
“log”: “”,
“plugin”: 1,
“pin”: 12,
“mode”: “output”,
“state”: 0
