bit/pulse pattern recognition
Posted: 03 Feb 2019, 13:13
by pitrio
dear all,
I have one wind direction sensor (meteo station) tha take out a 8 pulses burst with digital signal. In particolar first 4 pulses are a sort of syncronize pattern, after, there are other 4 bit that characterize the real signal... 4 bit -> 16 position... that corrispond to 16 wind directions.
The pulses are 0.5 msec or 1 msec duration...high or low... like picture belove.
wind direction code.jpg (83.72 KiB) Viewed 2983 times
Can someone tell me if there are some possibility to use espeasy to build a sort of "pattern recognition"?
thank you in advance.
ricc
Re: bit/pulse pattern recognition
Posted: 03 Feb 2019, 16:51
by grovkillen
You could build a plugin.
Posted: 03 Feb 2019, 17:48
by pitrio
Can I use pulseIn() and interrupt ISR function or there are incompatibility with ESPeasy?
Some hint?
thank yuo!
ricc
Posted: 03 Feb 2019, 18:41
by grovkillen
All communication use square signals so yes you could interpret them using ESP Easy (in a plugin).
