(solved)rules define own variable within rules
riker1
#1 Post by riker1 » 16 Mar 2019, 18:57
is it possible to define a variabe
- like : %ruleversion% = "version"
which can be used later in publish command?
I know the workaround to set a generic dummy device with event and eventvalue, but it would be easier to have a variable within rules to be used after flashing the rules .
thanks T
Re: rules define own variable within rules
#2 Post by grovkillen » 16 Mar 2019, 19:07
As of the last 2-3 months you can define up to 16 internal variables.
Let,16,123
The rule above will set variable 16 to the value 123. You can use the variables in either using this syntax:
%v16%
Or
[VAR#16]
How you want to publish the version number is then up to you.
riker1
#3 Post by riker1 » 16 Mar 2019, 19:18
ok, that is perfect.
thanks
riker1
Re: (solved)rules define own variable within rules
#4 Post by riker1 » 16 Mar 2019, 19:20
also alphanumeric once?
#5 Post by grovkillen » 16 Mar 2019, 20:43
riker1 wrote: 16 Mar 2019, 19:20 also alphanumeric once?
No, only floats.
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
