Can't get On WIFI#Connected to work
- dynamicdave
I'm using mega-20190315 and can't get...
On WIFI#Connected do
in a rule-set to work.
Does anyone know if this command works?
Re: Can't get On WIFI#Connected to work
Please show me the rule you're using.
- dynamicdave
Iv'e made it as simple as I can to test it out.
publish node80/report,hello
- dynamicdave
What I'm trying to do is detect which WiFi network a Wemos D1 Mini connects to.
Then set a Gateway IP address accordingly.
One of my students has a gateway at his home of 192.168.1.254, while at our IoT Club it's 192.168.1.1
This means each week he has to manually alter the 'settings' in the 'Config' tab (then memember to change it back before he goes home).
I suspose we could detect... on System#Boot do
then trigger a timer for 'x' seconds (which should give the Wemos enough time to connect to a WiFi network) then check the %ssid% name.
- dynamicdave
I've created this rule, but for some reason the first IF test always evaluates to true.
What is the correct syntax for comparing a system variable to a text string ??
on System#Boot do
timerSet,1,5
on Rules#Timer=1 do
If %ssid% = "iotclub" <<<<<<<<<<<<
Gateway,192.168.1.1
Publish node80/report,{"GW=":192.168.1.1}
Gateway,192.168.1.254
Publish node80/report,{"GW=":192.168.1.254}
Publish node80/report,{"SSID=":%ssid%}
on System#Boot do
timerSet,1,5
on Rules#Timer=1 do
Gateway,192.168.1.1
Haven't read all your posts (on my phone), but wifi connect means just that - the wifi is connected. It doesn't mean your MQTT broker is connected. Use a LED and control it with the GPIO command and you'll see.
- dynamicdave
Thanks for you feedback.
When your have a chance - please can you look over the Rule I posted and see why the string comparison doesn't work ??
You cannot test strings (%) mathematically within the rules engine.
- dynamicdave
If anyone is interested, I've managed to get a Rule-Set working to detect which WiFi network one of my student's WeMos D1 Mini is connected to.
At home his router has a GW and DNS of 192.168.1.254, while at our IoT Club the GW and DNS is 192.168.1.1
I've flashed one of my Wemos D1s with the version of ESP Easy that includes a 'ping' device.
When the D1 boots-up it sets the GW and DNS for his home (which is the default) and starts pinging that IP address.
If I get a 'good' ping, then the ping counter is incremented otherwise it stays at ZERO.
After 60-seconds the timer times-out and the value of the ping counter is checked.
If it still ZERO then the GW and DNS settings are switched over to the school's network.
Phew - that was fun.
Hope someone finds this useful.
// Routine to check which WiFi network the WeMos D1 Mini is connected to
// Default is a PlusNet network at the student's home
on System#Boot do
Gateway,192.168.1.254 // Set GW for student's home network
DNS,192.168.1.254 // Set DNS for student's home network
Let,1,0 //zero the ping counter
timerSet,1,60
on Rules#Timer=1 do
If [VAR#1]=0 // Check for ZERO pings (looks like the student is connected to the IoT Club's router)
Gateway,192.168.1.1 // Set GW for IoT Club's router
DNS,192.168.1.1 // Set DNS for IoT Club's router
on ping#value do
if [ping#value]>0 //Check if 'good' ping received
if [VAR#1] < 5
Let,1,%v1%+1 //Increment the ping counter
Just as a note. The settings will not be written to memory of no save command is made. It'll work just fine in Dave's case since the rules right away set the gateway and DNS.
Users browsing this forum: Bing [Bot] and 101 guests
