Flashed device - lost admin password
linker3000
#1 Post by linker3000 » 07 Apr 2019, 17:22
I've just done an OTA upgrade from a Mega January build to mega-20190406. The update worked OK, except that the Web admin password was then refused. I tried the default - same problem.
I fixed this by removing the Wemos D1 mini from its relay control box and changing the password back to what it was via the USB interface.
I checked back through the release notes and couldn't see anything directly relating to this. is this a known issue or was I unlucky?
Re: Flashed device - lost admin password
#2 Post by grovkillen » 07 Apr 2019, 17:35
Shouldn't be a problem... Hmm
linker3000
#3 Post by linker3000 » 07 Apr 2019, 17:37
Maybe I was unlucky - I have just repeated the exercise with another, identical, unit that was on the same firmware and it worked fine.
