Dear forum members,
I'm trying to get a ventus weather station working. The hardware is no problem, but I'm not successful in building the correct FW version for a wemos D1. There is a toutorial on the theme, but I'm struggling with the Atom compiler.
I need a ESPeasy version with the correct plug-in activated:
[platformio]
env_default = hard_Ventus_W266
I started on serveral days, but I'm struggling from one error to the next. Now I hope for a friendly forum member who can build a version for me.
Rgds Jan
ESP Easy build for Ventus weather station
Re: ESP Easy build for Ventus weather station
you can use arduino ide.
someday i will migrate to plataformio, but for now, it‘s simply to complicated.
Yes, too complicated . Arduino IDE is much more accessible.
I'm still struggeling. Compilation aborts with: lwip/etharp.h: No such file or directory
I can't find this library anywhere. I'm thankful for hints.
Rgds Jan
Rgds Jan
Easiest is to just download the entire project as a zip file (from the code page of our GitHub page) and then open that within Platformio.
ok, I have it running. I can (sometimes) build normal versions which run.
When building: PIO build (hard_Ventus_266), it works
Uploading doesn't: PIO upload (hard_Ventus_266)
Result:
Environment hard_Ventus_W266 [ERROR]
[ERROR] Took 37.82 seconds
I'm running out of ideas.
Result:
You should use the BUILD switch instead of UPLOAD. And then manually flash it.
Yes - Done! Good that I don't have to earn my money with coding. Thank you for the support
