Wifi compatibility issue
jme
#1 Post by jme » 13 May 2019, 12:07
I'm using a Keraky Acces point flashed with openwrt firmware on it.
The wifi works very wel in my house.
When i try to connect the ESP8266 with espeasy on it, it can't connect to that wifi.
SSID is open, iv'e try to create a SSID with WPA 2 but i have the same issue.
Wifi is detected by esp easy but never connect.
I've set a second ap as fall back wich is a Fritzbox, and it always connect on it.
Does anyone has same kind of issues ?
Any idea if it's espeasy firmware related or something wrong in the ap setup ?
Thx
dinu_1
Re: Wifi compatibility issue
#2 Post by dinu_1 » 18 Oct 2019, 12:42
Yeah, I am facing same issue. Its not getting connected :(
#3 Post by TD-er » 18 Oct 2019, 13:16
What channel is it using?
Does it enforce some strict connectivity rules, like only 40 MHz channel bandwidth, only 802.11N etc?
