It is a basic question but I went through the forum and I didn't find any answer. The keywords are maybe too simple.
I would like to use the sonoff S20 in my bedroom, so I would like ALL the lights(circle green, blue) to be switched off, but I need the sonoff to remain "active"( button, switch) because I have a light connected to it.
Is there a way to switch off all the lights without changing the behaviour?
Gilles
SONOFF S20 : Disable the blue and circle green lights
Re: SONOFF S20 : Disable the blue and circle green lights
GPIO 13
When I set the GPIO13 to 0, the blue light is switched off, but the green circle is switched on. I need both to be switched off to sleep .
Is there a way to switch off the green one and the blue one?
Nevertheless, I need the sonoff internal switch to be up because I have a lamp connected to the sonoff.
The green LED is physically connected together with the relay to GPIO12. So remove the LED or put something black over it.
