Sleeptime
M*I*B
Sleeptime
#1 Post by M*I*B » 07 Jul 2019, 17:36
Hello there again...
... meanwhile I have ready my prototype for testing. It's simple a ESP-07 with a BME280 and BH1750 to catch temperature, humidity, pressure and light. For testing I have glow the BME on the BH and wireed it free. I also have fire it all by two AAA and use the Sleepmode- function. The ESP send it via MQTT to FHEM...
Here I have set the wakeup-time to 15sec and the sleeptime to 285 to get 300sec = 5min in result... But that does'n work well...
After 8:4 sec the ESP have send it to FHEM, but they goes to sleep much to late after 24:5sec and not after 15sec I have set...
Why ?
Two other things...
1. Will it be possible to fire up the BME and BM via a GPIO-pin? At the moment both are under fire the whole time... Not a good idea for battery use. Will the GPIO can handle enough power (nominal arround 8µA with some jumps up to 1,3mA)? If yes (I believe) what I have to do to switch the used GPIO to HIGH after power up resp. if awake and shut it down to LOW before the ESP takes a nap?
2. Two AAA with nominal 3,1V works at the moment but I think not a long time. Better I use 3 AAA with nominal ~4,5V... But that's too much for that... A normal regulator (i.e. 7833) takes too much power for battery use... Have anybody an idea to solve that?
proto 1, test 1.jpg (147.67 KiB) Viewed 1780 times
DLzG
Micha
Re: Sleeptime
#2 Post by grovkillen » 07 Jul 2019, 17:56
Quick answer, use 18650 batteries, same as in Powerbanks.
M*I*B
Re: Sleeptime
#3 Post by M*I*B » 07 Jul 2019, 18:01
... quick reply: Not a good idea :D
Why? If you use rechargeable you will often need new ones if you don't take attention about deep discharge ...
DLzG
Micha
Re: Sleeptime
#4 Post by grovkillen » 07 Jul 2019, 18:07
You would of course monitor them?
M*I*B
Re: Sleeptime
#5 Post by M*I*B » 07 Jul 2019, 18:29
Does the ESP resp. ESPeasy a function to monitor the operating voltage and send to FHEM? I did not find anything like that ....
QUARK :roll: I have forget the ADC... works well (100k/20k). Next I will try 1M/200k... :lol:
DLzG
Micha
M*I*B
Re: Sleeptime
#6 Post by M*I*B » 08 Jul 2019, 11:07
Ok, meanwhile I have follow your idea with the LiION; I have many of them for my E-Shisha...
I set the ESP to sleep 295 seconds and stay awaked for 5 seconds. I Also have figure out how to swith on a port while booting and switch it of before it goes back to sleep. For that it seems to be important that you buffer the port with an small condenser to let the switched sensors working stable. I use a 4µ7 and it works well now.
Last night at ~23:00 I have install it in a small transparent box (from screws) under my roof outside to test WLAN- communication and test how long the battery will work.
One thing I have find this morning in the logfile inside FHEM. Many of the Data are more then twice, sometimes only one value, ... It's every 5 minutes different... I.e. here a received block to show what I mean:
2019-07-08_00:20:15 ESPEasy_ESP_test presence: present
2019-07-08_00:20:15 ESPEasy_ESP_test B: 0.23 H: 64.52 P: 1012.55 T: 13.40 V: 4.44
2019-07-08_00:20:39 ESPEasy_ESP_test B: 0.11
2019-07-08_00:20:39 ESPEasy_ESP_test B: 0.11 H: 64.52 P: 1012.55 T: 13.40 V: 4.44
2019-07-08_00:20:39 ESPEasy_ESP_test V: 4.45
2019-07-08_00:20:39 ESPEasy_ESP_test B: 0.11 H: 64.52 P: 1012.55 T: 13.40 V: 4.45
2019-07-08_00:20:39 ESPEasy_ESP_test T: 13.27
2019-07-08_00:20:39 ESPEasy_ESP_test P: 1012.57
2019-07-08_00:20:39 ESPEasy_ESP_test H: 64.79
2019-07-08_00:20:39 ESPEasy_ESP_test B: 0.11 H: 64.79 P: 1012.57 T: 13.27 V: 4.45
2019-07-08_00:20:40 ESPEasy_ESP_test B: 0.23
2019-07-08_00:20:40 ESPEasy_ESP_test B: 0.23 H: 64.79 P: 1012.57 T: 13.27 V: 4.45
2019-07-08_00:20:40 ESPEasy_ESP_test V: 4.44
2019-07-08_00:20:40 ESPEasy_ESP_test B: 0.23 H: 64.79 P: 1012.57 T: 13.27 V: 4.44
2019-07-08_00:20:43 ESPEasy_ESP_test B: 0.23 H: 64.79 P: 1012.57 T: 13.27 V: 4.44
2019-07-08_00:20:44 ESPEasy_ESP_test B: 0.23 H: 64.79 P: 1012.57 T: 13.27 V: 4.44
B = Brightness in LUX
H = Humidity in %
P = Pressure in mBar
T= Temperature in °C
V = Cell- Voltage in V
What I realy need is the line offered in the "state" like "B: 0.23 H: 64.79 P: 1012.57 T: 13.27 V: 4.44". But if I set a filter for "state" in FHEM for the logfile I get nothing.
Question is why are there so much data sending in that singe block every time the ESP wake up?
DLzG
Micha
M*I*B
Re: Sleeptime
#7 Post by M*I*B » 09 Jul 2019, 12:46
BTW:
There is an BUG in the "Generic Dummy Device". It is not possible to choose anything other than "single" or "quad" here. Any other selection is ignored and replaced by "single"
Concerns...
ESP_Easy_mega-20190630_normal_ESP8266_4M
... and ...
ESP_Easy_mega-20190630_normal_ESP8266_1M
DLzG
Micha
Re: Sleeptime
#8 Post by TD-er » 09 Jul 2019, 14:20
@M*I*B
Have you also saved in between?
Anyways the way the selector works now is not optimal, so it is definitely worth an issue @GitHub to look at.
M*I*B
Re: Sleeptime
#9 Post by M*I*B » 09 Jul 2019, 14:45
... yes, shure. I have try many things, also flash and empty ROM and flash it new... It's not possible in this version ...
In this context, I think it would be better to allow a free input of the required data fields. So just the selection "X fields" and an input field for the really required amount. I just had the situation that I needed 5 fields and forcibly had to open two dummies.
What is also missing is the option to be able to assemble a string in a single field, e.g. ...
LUM: [Sensor # LUM] - TMP: [Sensor # T] - ... a.s.o.
DLzG
Micha
Re: Sleeptime
#10 Post by TD-er » 09 Jul 2019, 15:04
More than 4 values is not going to happen anytime soon.
That would require a lot of changes and/or rendering existing settings useless.
There was already some similar setting like this for the Dummy plugin, which is needed for controllers like Domoticz that need some types of data formatted differently. (e.g. Temp/Hum/Baro is different from CO2 in formatting)
For the same reason I had pull some tricks to make the output selectable in number of values. (e.g. the recent change of systeminfo plugin to output 4 values did change behavior on Domoticz)
A plugin currently can only output up-to 4 floating point values, or one larger integer (needed for RF-id scanner for example).
There is no support for strings.
For the parts that allow strings (e.g. publish to a HTTP url) you can use that syntax in rules.
For example:
on bme#T do
  SendToHTTP example.com,80,api/add/single?id=%mac_int%&long=[gps#lon]&lat=[gps#lat]&T=[bme#T]&P=[bme#P]&H=[bme#H]
M*I*B
Re: Sleeptime
#11 Post by M*I*B » 09 Jul 2019, 15:10
... ahh ok, I understand ...
Ty for the hint with the URL.. I will give it a try ...
DLzG
Micha
M*I*B
Re: Sleeptime
#12 Post by M*I*B » 10 Jul 2019, 12:54
Is there any way to disable that for testing? It is extremely annoying to put the ladder to the house in this case, to take the thing off the roof, unscrew it, unsolder the battery and get everything started again :evil: :evil: :evil:
FS : Daily flash write rate exceeded! (powercycle to reset this)
DLzG
Micha
Re: Sleeptime
#13 Post by grovkillen » 10 Jul 2019, 17:29
I would imagine it being less time consuming to read the manual:
https://espeasy.readthedocs.io/en/lates ... mmand.html
:twisted: :evil: ;)
Re: Sleeptime
#14 Post by Shardan » 10 Jul 2019, 19:13
M*I*B wrote:
08 Jul 2019, 11:07
H = Humidity in %
After wake up ESPEasy sends all data to a home control server.
The "state" is a summarize of the actual values generated by FHEM, not by ESPEasy.
I've never tried that but it should be possible to write a few lines perl code to either cut off the "state" part
from that line or add the separate values to one string. FHEM can do this with a separate Perl modul or inside some functions.
M*I*B
Re: Sleeptime
#15 Post by M*I*B » 10 Jul 2019, 22:32
@grovkillen: I have read it but there is no option to switch that off. There is just an option to reset the counter. That only works sometimes if the ESP online. The most time you can send it many times and it was ignored due the ESP have much to do in the time they is online / not in DeepSleep.
@Shardan: You have misunderstand me, maybe about my ugly english... The question is, why the ESP send it more then once and also in different ways... Near the same happens if you don't let the Task send it, create a Rule and let the Dummy's send it...
An other thing... I figure out some "funny" things while checking out some different ways...
As base for the funny things take a look at the following:
on System#Boot do
  GPIO,12,1   // works well
on WiFi#Connected do  // the following lines don't work resp. don't work well
//on Clock#Time=All,**:** do  // the following lines work well!
  delay,5000
  SendToHTTP 192.168.1.10,8083,fhem?cmd=setreading%20ESP_20%20state%20VCC%20[VCC#VCC]%20TMP%20[THP#TMP]%20HUM%20[THP#HUM]%20BRI%20[LUM#BRI]%20PRS%20[THP#PRS]%20RSSI%20[SYS#RSSI] // Ok on Clock, nothing on WiFi
  TaskValueSet 10,1,[THP#TMP]  // most well
  TaskValueSet 10,2,[THP#HUM]  // most well
  TaskValueSet 10,3,[THP#PRS]  // often zero except Clock
  TaskValueSet 10,4,[LUM#BRI]  // often zero except Clock
  TaskValueSet 11,1,[VCC#VCC]  // most well
  TaskValueSet 11,2,[SYS#RSSI*-1] // ever zero on WiFi, well on Clock
on System#Sleep do
  GPIO,12,0   // works well
1.: DeepSleep
If I use it as it shown I have believed that it must work this way... But it doesn't. The HTTP will never been send to the Dummy at FHEM, the ESP- dummys are often not filled with the data and at FHEM often some or all data are "0"
2.: By Time
If I use the Clock for testing (no sleep) the HTTP will send without errors to the FHEM- Dummy, the ESP- Dummys will send also well...
The question is, what is going wrong while I use "on WiFi#Connected do" ???
DLzG
Micha
M*I*B
Re: Sleeptime
#16 Post by M*I*B » 11 Jul 2019, 00:48
... and the next Joke before bedtime ...
on System#Boot do
  GPIO,12,1
on System#Sleep do
  GPIO,12,0
That work's perfect! I have delete all dummy-devices and all controller. Also I have set the "Sleep awake time" to 1 second and "Sleep time" to 300sec. It looks like that the one second is only needed to wakeup. They need longer to connect to the WiFi but I believe they don't go sleep before finnish all jobs. So the running time is now the shortest possible and the battery live the longest possible. They go to sleep right now after sending the HTTP... And also don't hassle with the logfile; the logfile is perfect now without drops and doublettes...
With two words: That's it!
Good N8 all :roll:
DLzG
Micha
