On System#Boot do
delay,2000
7dn,----
delay,500
On System#Boot do
delay,2000
7dn,----
delay,500
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
�U99 :
INIT : Booting version: mega-20190107 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
100 : INIT : Warm boot #4 - Restart Reason: Software/System restart
102 : FS : Mounting...
127 : FS : Mount successful, used 78312 bytes of 957314
528 : CRC : program checksum ...OK
rules1.txt 1
rules2.txt 1
rules3.txt 1
rules4.txt 1
RuleDebug Processing:rules1.txt
flags CMI parse output:
RuleDebug Processing:rules2.txt
RuleDebug Processing:rules3.txt
RuleDebug Processing:rules4.txt
state: 3 -> 5 (10)
add 0
aid 4
cnt
connected with maciek24, channel 1
ip:192.168.0.29,mask:255.255.255.0,gw:192.168.0.1
ip:192.161
t
pm open,type:2 0
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U66 :
INIT : Booting version: mega-20190630 (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
67 : INIT : Free RAM:30584
68 : INIT : Warm boot #12 - Restart Reason: Exception
70 : FS : Mounting...
95 : FS : Mount successful, used 78312 bytes of 957314
559 : CRC : program checksum ...OK
65 : INIT : Free RAM:30584
66 : INIT : Warm boot #1 - Restart Reason: Software/System restart
69 : FS : Mounting...
93 : FS : Mount successful, used 78312 bytes of 957314
558 : CRC : program checksum ...OK
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U65 :
66 : INIT : Free RAM:30584
67 : INIT : Warm boot #1 - Restart Reason: Software/System restart
94 : FS : Mount successful, used 78312 bytes of 957314
I really dont know. Simply it stops output.Does it stop adding serial output after those 500+ ms?
6365 : Domoticz Controller: Not yet implemented sensor type: 0 idx: 100
6366 : Domoticz: Sensortype: 0 idx: 100 values:
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U65 :
596 : CRC : SecuritySettings CRC ...OK
692 : INIT : Free RAM:27472
694 : INIT : SPI not enabled
1562 : INFO : Plugins: 80 [Normal] [Testing] (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
1564 : EVENT: System#Wake
1760 : mode : sta(84:f3:eb:b7:45:42)
add if0
WIFI : Set WiFi to STA
1796 : WIFI : Connecting maciek24 attempt #0
1798 : ip:192.168.0.29,mask:255.255.255.0,gw:192.168.0.1
IP : Static IP : 192.168.0.29 GW: 192.168.0.1 SN: 255.255.255.0 DN1
1801 : WIFI : Not configured in Station Mode!!: maciek24
1816 : EVENT: System#Boot
1838 : ACT : GPIO,0,0
1841 : SW : GPIO 0 Set to 0
1844 : ACT : GPIO,12,0
1847 : SW : GPIO 12 Set to 0
1851 : ACT : GPIO,13,0
1854 : SW : GPIO 13 Set to 0
1859 : ACT : delay,2000
1872 : Command: delay
3875 : ACT : 7dn,----
3888 : Command: 7dn
3889 : Command unknown: "7dn"
3892 : ACT : delay,500
3901 : Command: delay
4404 : ACT : GPIO,14,0
4407 : SW : GPIO 14 Set to 0
4410 : ACT : timerSet,1,3000
4420 : Command: timerset
4424 : ACT : timerSet,2,3
4433 : Command: timerset
4437 : ACT : timerSet,4,420
4446 : Command: timerset
4561 : ACT : TimerSet,5,5
4571 : Command: timerset
4575 : ACT : Let,1,0
4584 : Command: let
4680 : scandone
state: 0 -> 2 (b0)
DS : Temperature: 19.62 (28-ff-f6-ba-33-18-1-6)
5570 : state: 2 -> 3 (0)
EVENT: Temp-in#Temperatura-Salon=19.62
state: 3 -> 5 (10)
add 0
aid 4
cnt
5790 : D2
5897 : WIFI : Connected! AP: maciek24 (74:DA:38:72:B0:D9) Ch: 1 Duration: 3804 ms
5899 : EVENT: WiFi#ChangedAccesspoint
6110 : IP : Static IP : 192.168.0.29 GW: 192.168.0.1 SN: 255.255.255.0 DNS: 192.168.0.201
6112 : WIFI : Static IP: 192.168.0.29 (Salon-1) GW: 192.168.0.1 SN: 255.255.255.0 duration: 507 ms
6127 : EVENT: WiFi#Connected
6338 : Webserver: start
6360 : SYS :
6379 : SW : GPIO=14 State=0 Output value=0
6389 : EVENT: Switch-1#Zwarcie_DIO_wy�ietlaczy=0.00
7574 : EVENT: Rules#Timer=2
7728 : WD : Uptime 0 ConnectFailures 0 FreeMem 17992 WiFiStatus 3
10429 : EVENT: Rules#Timer=5
10544 : ACT : Let,1,1
10556 : Command: let
10560 : ACT : Event,UpdateDisplay
10573 : Command: event
10575 : EVENT: UpdateDisplay
fpm close 3
pm open,type:2 0
26440 : NTP : NTP replied: delay 10 mSec Accuracy increased by 0.953 seconds
26442 : Time adjusted by -1563166022525.78 msec. Wander: -434212784.03 msec/second
26444 : Current Time Zone: DST time start: 2019-03-31 02:00:00 offset: 120 minSTD time start: 2019-10-27 03:00:00 offset: 6n
26447 : EVENT: Time#Initialized
26600 : EVENT: Clock#Time=Mon,06:47
26720 : ACT : Event,UpdateDisplay
26732 : Command: event
26733 : EVENT: UpdateDisplay
26850 : ACT : Let,1,0
26861 : Command: let
26867 : ACT : 7dst,6,47
26879 : Command: 7dst
26880 : Command unknown: "7dst"
26883 : ACT : Let,1,1
26893 : Command: let
35982 : WD : Uptime 1 ConnectFailures 0 FreeMem 17616 WiFiStatus 3
58430 : EVENT: Clock#Time=Mon,06:48
58548 : ACT : Event,UpdateDisplay
58560 : Command: event
58561 : EVENT: UpdateDisplay
58679 : ACT : Let,1,0
58690 : Command: let
58697 : ACT : 7dst,6,48
58708 : Command: 7dst
58709 : Command unknown: "7dst"
58712 : ACT : Let,1,1
58722 : Command: let
64917 : DS: SP: 3a,1,4b,46,7f,ff,c,10,a5,OK,7
64927 : DS : Temperature: 19.62 (28-ff-f6-ba-33-18-1-6)
64933 : EVENT: Temp-in#Temperatura-Salon=19.62
65098 : Domoticz: Sensortype: 1 idx: 106 values: 19.62
65982 : WD : Uptime 1 ConnectFailures 0 FreeMem 17616 WiFiStatus 3
74697 : HTTP: event,set_temp=11.6
74719 : EVENT: set_temp=11.6
74779 : ACT : GPIO,0,1
74782 : SW : GPIO 0 Set to 1
74786 : ACT : 7dt,11.6
74797 : Command: 7dt
74798 : Command unknown: "7dt"
74802 : ACT : GPIO,0,0
74805 : SW : GPIO 0 Set to 0
74810 : ACT : timerSet,4,420
74821 : Command: timerset
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U64 :
66 : INIT : Warm boot #6 - Restart Reason: Exception
68 : FS : Mounting...
595 : CRC : SecuritySettings CRC ...OK
691 : INIT : Free RAM:27488
693 : INIT : SPI not enabled
1570 : INFO : Plugins: 80 [Normal] [Testing] (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
1572 : EVENT: System#Wake
1767 : mode : sta(84:f3:eb:b7:45:42)
add if0
1803 : WIFI : Connecting maciek24 attempt #0
1804 : ip:192.168.0.29,mask:255.255.255.0,gw:192.168.0.1
1808 : WIFI : Not configured in Station Mode!!: maciek24
1823 : EVENT: System#Boot
1844 : ACT : GPIO,0,0
1847 : SW : GPIO 0 Set to 0
1850 : ACT : GPIO,12,0
1854 : SW : GPIO 12 Set to 0
1859 : ACT : GPIO,13,0
1862 : SW : GPIO 13 Set to 0
1867 : ACT : delay,2000
1881 : Command: delay
3887 : ACT : 7dn,----
3890 : Fatal exception 3(LoadStoreErrorCause):
epc1=0x4022d6c5, epc2=0x00000000, epc3=0x00000000, excvaddr=0x402e482e, depc=00
0
That's true.mackowiakp wrote: ↑16 Jul 2019, 12:22 Today build (test) couse that after reboot only Wi-Fi led blinking once per 4-5 sec and there is no connection to my home AP. It was necessary download old SW via USB.
Just to make sure...mackowiakp wrote: ↑16 Jul 2019, 12:22 Today build (test) couse that after reboot only Wi-Fi led blinking once per 4-5 sec and there is no connection to my home AP. It was necessary download old SW via USB.
That's also what I'm seeing here.
