[SOLVED] 7 segment display (4 digit)
Posted: 12 Jul 2019, 18:42
by mackowiakp
7 segment, 4 digit display TM1637 based, does not working after SW ver 20190107 test. After installing the newest version of SW, display is shown in device list as disabled. It is possible to enable one manually but it still display nothing and after reboot is again shown as disabled. I wite content of display manually and after reboot should be displayed four minus signs according to rule:
On System#Boot do
delay,2000
7dn,----
delay,500
But nothing is display. Is it bug? Any workaround?
Re: 7 segment display (4 digit)
Posted: 12 Jul 2019, 21:24
by grovkillen
If you type the command in the tools window, does it work then?
Posted: 13 Jul 2019, 04:54
by mackowiakp
No, because after boot device is marked in device list as "X" and "Enable" option is not checked. So probably it was not properly initiated during boot time.
Posted: 13 Jul 2019, 08:27
by grovkillen
Have you re-saved the settings for the plugin after you updated the unit?
Posted: 13 Jul 2019, 11:09
by mackowiakp
Yes, of course. It was necessary because - as I wrote - display was disabled aftre reboot. So I click "Edit" on appropriate line in device list, check setup parameters like GPIO`s assignment, mode as manual etc, etc. All setup parameter were ok except that device was disabled. So I mark "Enabled" checkbox and click on "Submit". Pup-up window shows "Submitted" and device was enabled in device list. But nothing was possible to display. So I rebooted device and display was disabled again.
Posted: 13 Jul 2019, 13:10
by grovkillen
Then it must be something causing the OS to disable the plugin. Can you monitor the serial log?
Posted: 13 Jul 2019, 13:52
by mackowiakp
I think yes. Will send You both working SW boot logs and not-working. But can You pass me link how to do it? I have 3,3V UART to USB converter.
Posted: 13 Jul 2019, 14:39
by grovkillen
You simply plug it in the computer and use a serial monitor. Of you're on Windows you can use the one provided with the Flasher.
Posted: 14 Jul 2019, 10:14
by mackowiakp
OK. So You have logs from working and not-working versions of SW. Debug level was set to "dev". Notice that after installing 20190630 the unit reboots itself 12 times and after that it seams to not work. For example no rules run.
Working ver 20190107
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
�U99 :
INIT : Booting version: mega-20190107 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
100 : INIT : Warm boot #4 - Restart Reason: Software/System restart
102 : FS : Mounting...
127 : FS : Mount successful, used 78312 bytes of 957314
528 : CRC : program checksum ...OK
rules1.txt 1
rules2.txt 1
rules3.txt 1
rules4.txt 1
RuleDebug Processing:rules1.txt
flags CMI parse output:
RuleDebug Processing:rules2.txt
RuleDebug Processing:rules3.txt
RuleDebug Processing:rules4.txt
state: 3 -> 5 (10)
add 0
aid 4
cnt
connected with maciek24, channel 1
ip:192.168.0.29,mask:255.255.255.0,gw:192.168.0.1
ip:192.161
t
pm open,type:2 0
Not working ver 20190630
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U66 :
INIT : Booting version: mega-20190630 (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
67 : INIT : Free RAM:30584
68 : INIT : Warm boot #12 - Restart Reason: Exception
70 : FS : Mounting...
95 : FS : Mount successful, used 78312 bytes of 957314
559 : CRC : program checksum ...OK
Posted: 14 Jul 2019, 10:29
by grovkillen
Looks like the log level is set to "none" for the latest version. And the fact that the unit is rebooting 12 times suggest that it's not liking one or more plugins. Could you make sure that the latest version is set to show serial log?
Posted: 14 Jul 2019, 11:07
by mackowiakp
After several power reboots, it does not reboot itself 12 times.
65 : INIT : Free RAM:30584
66 : INIT : Warm boot #1 - Restart Reason: Software/System restart
69 : FS : Mounting...
93 : FS : Mount successful, used 78312 bytes of 957314
558 : CRC : program checksum ...OK
And my debug setup.
- Screenshot_20190714_105834.png (80.52 KiB) Viewed 13748 times
Posted: 14 Jul 2019, 11:27
by grovkillen
Does it stop adding serial output after those 500+ ms?
Could you please set the log level to normal/info and try?
Posted: 14 Jul 2019, 11:47
by mackowiakp
Log leve set to "Info"
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U65 :
66 : INIT : Free RAM:30584
67 : INIT : Warm boot #1 - Restart Reason: Software/System restart
94 : FS : Mount successful, used 78312 bytes of 957314
I really dont know. Simply it stops output.
Additional infos.
It seams to rules starting with "On System#Boot do" does not run with 7 segment display connected.
When unit boot, it is possible to run rule from Domoticz (blinking LED) and it is possible to turn on/off connected relays both using GPIO,13,1 (example) command from "Tools" menu and remotely from Domoticz. Connected temperature sensor sends properly values to Domoticz.
7 segment display is disabled after reboot. But when I enable one manually and enter command "7dn,----" from "Tools" menu, nodeMCU reboots.
Posted: 14 Jul 2019, 11:54
by mackowiakp
UPDATE
Running rule remotely (like blinking LED) and GPIO command from "Tools" menu, is not logged both in "Info" and "Dev" mode.
Posted: 14 Jul 2019, 19:51
by grovkillen
You haven't got the serial port/communication enabled.
Posted: 15 Jul 2019, 08:02
by mackowiakp
OK. You are right. My fault.
Below boot log in "dev" mode. Do not look at the lines:
6365 : Domoticz Controller: Not yet implemented sensor type: 0 idx: 100
6366 : Domoticz: Sensortype: 0 idx: 100 values:
It is generic sensor sending uptime to Domoticz. I simply re-setup this sensor and it start work properly.
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U65 :
596 : CRC : SecuritySettings CRC ...OK
692 : INIT : Free RAM:27472
694 : INIT : SPI not enabled
1562 : INFO : Plugins: 80 [Normal] [Testing] (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
1564 : EVENT: System#Wake
1760 : mode : sta(84:f3:eb:b7:45:42)
add if0
WIFI : Set WiFi to STA
1796 : WIFI : Connecting maciek24 attempt #0
1798 : ip:192.168.0.29,mask:255.255.255.0,gw:192.168.0.1
IP : Static IP : 192.168.0.29 GW: 192.168.0.1 SN: 255.255.255.0 DN1
1801 : WIFI : Not configured in Station Mode!!: maciek24
1816 : EVENT: System#Boot
1838 : ACT : GPIO,0,0
1841 : SW : GPIO 0 Set to 0
1844 : ACT : GPIO,12,0
1847 : SW : GPIO 12 Set to 0
1851 : ACT : GPIO,13,0
1854 : SW : GPIO 13 Set to 0
1859 : ACT : delay,2000
1872 : Command: delay
3875 : ACT : 7dn,----
3888 : Command: 7dn
3889 : Command unknown: "7dn"
3892 : ACT : delay,500
3901 : Command: delay
4404 : ACT : GPIO,14,0
4407 : SW : GPIO 14 Set to 0
4410 : ACT : timerSet,1,3000
4420 : Command: timerset
4424 : ACT : timerSet,2,3
4433 : Command: timerset
4437 : ACT : timerSet,4,420
4446 : Command: timerset
4561 : ACT : TimerSet,5,5
4571 : Command: timerset
4575 : ACT : Let,1,0
4584 : Command: let
4680 : scandone
state: 0 -> 2 (b0)
DS : Temperature: 19.62 (28-ff-f6-ba-33-18-1-6)
5570 : state: 2 -> 3 (0)
EVENT: Temp-in#Temperatura-Salon=19.62
state: 3 -> 5 (10)
add 0
aid 4
cnt
5790 : D2
5897 : WIFI : Connected! AP: maciek24 (74:DA:38:72:B0:D9) Ch: 1 Duration: 3804 ms
5899 : EVENT: WiFi#ChangedAccesspoint
6110 : IP : Static IP : 192.168.0.29 GW: 192.168.0.1 SN: 255.255.255.0 DNS: 192.168.0.201
6112 : WIFI : Static IP: 192.168.0.29 (Salon-1) GW: 192.168.0.1 SN: 255.255.255.0 duration: 507 ms
6127 : EVENT: WiFi#Connected
6338 : Webserver: start
6360 : SYS :
6379 : SW : GPIO=14 State=0 Output value=0
6389 : EVENT: Switch-1#Zwarcie_DIO_wy�ietlaczy=0.00
7574 : EVENT: Rules#Timer=2
7728 : WD : Uptime 0 ConnectFailures 0 FreeMem 17992 WiFiStatus 3
10429 : EVENT: Rules#Timer=5
10544 : ACT : Let,1,1
10556 : Command: let
10560 : ACT : Event,UpdateDisplay
10573 : Command: event
10575 : EVENT: UpdateDisplay
fpm close 3
pm open,type:2 0
26440 : NTP : NTP replied: delay 10 mSec Accuracy increased by 0.953 seconds
26442 : Time adjusted by -1563166022525.78 msec. Wander: -434212784.03 msec/second
26444 : Current Time Zone: DST time start: 2019-03-31 02:00:00 offset: 120 minSTD time start: 2019-10-27 03:00:00 offset: 6n
26447 : EVENT: Time#Initialized
26600 : EVENT: Clock#Time=Mon,06:47
26720 : ACT : Event,UpdateDisplay
26732 : Command: event
26733 : EVENT: UpdateDisplay
26850 : ACT : Let,1,0
26861 : Command: let
26867 : ACT : 7dst,6,47
26879 : Command: 7dst
26880 : Command unknown: "7dst"
26883 : ACT : Let,1,1
26893 : Command: let
35982 : WD : Uptime 1 ConnectFailures 0 FreeMem 17616 WiFiStatus 3
58430 : EVENT: Clock#Time=Mon,06:48
58548 : ACT : Event,UpdateDisplay
58560 : Command: event
58561 : EVENT: UpdateDisplay
58679 : ACT : Let,1,0
58690 : Command: let
58697 : ACT : 7dst,6,48
58708 : Command: 7dst
58709 : Command unknown: "7dst"
58712 : ACT : Let,1,1
58722 : Command: let
64917 : DS: SP: 3a,1,4b,46,7f,ff,c,10,a5,OK,7
64927 : DS : Temperature: 19.62 (28-ff-f6-ba-33-18-1-6)
64933 : EVENT: Temp-in#Temperatura-Salon=19.62
65098 : Domoticz: Sensortype: 1 idx: 106 values: 19.62
65982 : WD : Uptime 1 ConnectFailures 0 FreeMem 17616 WiFiStatus 3
74697 : HTTP: event,set_temp=11.6
74719 : EVENT: set_temp=11.6
74779 : ACT : GPIO,0,1
74782 : SW : GPIO 0 Set to 1
74786 : ACT : 7dt,11.6
74797 : Command: 7dt
74798 : Command unknown: "7dt"
74802 : ACT : GPIO,0,0
74805 : SW : GPIO 0 Set to 0
74810 : ACT : timerSet,4,420
74821 : Command: timerset
Because 7 segment display device was disabled after reboot, I enabled one manually. It reboots and during next boot the error is display and nodeMCU stops oututs logs. See below:
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
�U64 :
66 : INIT : Warm boot #6 - Restart Reason: Exception
68 : FS : Mounting...
595 : CRC : SecuritySettings CRC ...OK
691 : INIT : Free RAM:27488
693 : INIT : SPI not enabled
1570 : INFO : Plugins: 80 [Normal] [Testing] (ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support)
1572 : EVENT: System#Wake
1767 : mode : sta(84:f3:eb:b7:45:42)
add if0
1803 : WIFI : Connecting maciek24 attempt #0
1804 : ip:192.168.0.29,mask:255.255.255.0,gw:192.168.0.1
1808 : WIFI : Not configured in Station Mode!!: maciek24
1823 : EVENT: System#Boot
1844 : ACT : GPIO,0,0
1847 : SW : GPIO 0 Set to 0
1850 : ACT : GPIO,12,0
1854 : SW : GPIO 12 Set to 0
1859 : ACT : GPIO,13,0
1862 : SW : GPIO 13 Set to 0
1867 : ACT : delay,2000
1881 : Command: delay
3887 : ACT : 7dn,----
3890 : Fatal exception 3(LoadStoreErrorCause):
epc1=0x4022d6c5, epc2=0x00000000, epc3=0x00000000, excvaddr=0x402e482e, depc=00
0
So maybe You have more infos I hope.
Posted: 16 Jul 2019, 10:50
Jimmy was spamming me a lot via Slack about this issue.
See also this issue here:
https://github.com/letscontrolit/ESPEasy/issues/2380
My trigger was the "LoadStoreError".
So it should work in the builds with "SDK3.0"
The error given by Domoticz suggests the settings were not saved again for the system info plugin (is a known bug I need to fix)
I made a test build, where the 7dgt plugin should be included in the "normal" list.
https://www.dropbox.com/s/jwl75yx14c9jp ... 9.bin?dl=0
It is based on core 2.5.2 (which should not work according to other reports)
The things I changed is that I removed the F() macro from short strings used to compare commands and the PROGMEM declaration for the "font"
Posted: 16 Jul 2019, 12:12
by mackowiakp
Yep. Your test build works properly! Will rapport after several hours too.
Posted: 16 Jul 2019, 12:15
OK, I will also make one built in Linux.
The last nightly build seems to have issues (again) since the normal build is causing crashes.
Posted: 16 Jul 2019, 12:22
by mackowiakp
Today build (test) couse that after reboot only Wi-Fi led blinking once per 4-5 sec and there is no connection to my home AP. It was necessary download old SW via USB.
Posted: 16 Jul 2019, 14:24
mackowiakp wrote: ↑16 Jul 2019, 12:22
That's true.
I already removed today's build from the releases after testing myself.
There's something wrong with the builds, since they work fine if I build them myself in Windows.
Posted: 16 Jul 2019, 14:54
by mackowiakp
OK, so good luck !
Posted: 17 Jul 2019, 01:55
Just to make sure...
Was the test build (download via Dropbox link) failing after a reboot, or did you mean the nightly build ?
Posted: 17 Jul 2019, 06:52
by mackowiakp
Dropbox build works properly in the meaning of 7 segment display. Bootloop accrues using the nightly build (You remove one of course).
But with Dropbox taken build is another problem. That is watchdog reboots. Look to the chart of uptime of nodeMCU taken from Domoticz.
- Uptime.png (477.05 KiB) Viewed 13416 times
Using 20190630 (test, 2.4.2), watchdog also causes reboots, but very rarely (about once a day). Maybe it will take place, because I do reconnect WiFi every 50 minutes from the rule.
Posted: 17 Jul 2019, 14:34
Watchdog reboots are a known issue and I'm working on it.
And indeed the watchdog reboot has a very close relation to WiFi reconnects.
But at least the plugin now does seem to work with another core, other than 2.6.0 SDK3.
So at least that does seem to be tackled now.
Posted: 17 Jul 2019, 14:43
by mackowiakp
Yes I know about watchdog issue. I revert my unit to ver ESP_Easy_mega-20190107_test_ESP8266_4096.bin which is the best working for me with this specific configuration of HW.
Posted: 01 Aug 2019, 06:33
by mackowiakp
Fixed in release mega-20190731
Re: [SOLVED] 7 segment display (4 digit)
Posted: 03 Aug 2019, 01:35
And how about the WDT reboots?
Are they occurring less often now?
Posted: 03 Aug 2019, 06:16
by mackowiakp
Yes. Much less often. But still occurs.
Posted: 03 Aug 2019, 13:03
mackowiakp wrote: ↑03 Aug 2019, 06:16
That's also what I'm seeing here.
Still a WDT reboot on some nodes, but the main cause of them was when the WiFi reconnects.
That bug is now fixed.
