Espeasy & Domoticz
Posted: 18 Sep 2019, 19:49
by vidalv
Hello all ESP-Easy users, I'd like to know if they are special requirements to setup Data xfert from ESPEasy to Domoticz ?
My configuration is : PC under Win7, ESP8266 with DS18b20 and BME280 devices under ESPEasy Mega V2.0.0.
- Easy_Devices.JPG (70.92 KiB) Viewed 24992 times
You can see on snap I get measurements from devices.
On Domoticz devices with Idx configured :
- Domo_Dispositif.JPG (78.95 KiB) Viewed 24992 times
Unfortunately no data received from EASYESP :
- Domo_Temperature.JPG (61.8 KiB) Viewed 24992 times
Any ideas are Welcome !!!
Vince.
Re: Espeasy & Domoticz
Posted: 18 Sep 2019, 20:05
by grovkillen
IDX is 3 4 5 in the screenshot from Domoticz. So you need to change the IDX to match.
Posted: 18 Sep 2019, 20:34
by vidalv
Thanks grovkillen, I've modified to :
- Easy_Devices.JPG (69.58 KiB) Viewed 24986 times
then
- Domo_Dispositif.JPG (69.78 KiB) Viewed 24986 times
No changes .... Unfortunately.
Is there a way to check data with Mosquitto under cmd console or any broker ?
Posted: 18 Sep 2019, 23:08
You can connect with any MQTT client tool to the broker and see all the messages you subscribe to.
The thing with Domoticz is that it is really picky in what type of virtual device you created.
The most flexible is the "custom sensor", but then it doesn't show up in the right tab in Domoticz.
If you haven't got any response via MQTT to Domoticz, you can also try to use the Domoticz HTTP controller as a test to see whether it is a connection thing or not chosen the right device in Domoticz.
Also you may want to try a bit newer build.
I know we're long long overdue with declaring a new one "stable", but sadly we had some good reason for it since lots of reboots etc. were reported.
But since a few weeks now we seem to be doing a lot better regarding stability of the 'mega' builds.
Posted: 19 Sep 2019, 06:50
by vidalv
Btw, can my firewall block port 8080 or 1883?
I use MSE and how to check this?
By using a command prompt with Mosquitto to check the data sent to the broker what are the parameters that ESPEasy returns?
I use the version ESP_Easy_v2.0.0-dev13_dev_ESP8266_4096 should I switch to another?
I use French SFR provider, Do I have to setup something to authorize ESPEasy / Domoticz ? When I try to connect Mosquitto broker using MyESP IP I get on command prompt this message : No connection could be established because the target computer expressly refused it. Any idea ?
Thank you.
Posted: 19 Sep 2019, 15:21
Well if you are running Mosquitto, Domoticz and ESPeasy in the same local network, then the firewall of your router should not have any effect on it.
I am not entirely sure anymore if Domoticz needs some check in the settings somewhere to also accept data via HTTP.
I know I have it running here to accept both, but I don't remember anymore if it was configured like that out of the "box" (default setting) or not.
Posted: 20 Sep 2019, 09:53
by vidalv
Well, it seems that Domoticz is not the best tool for support and performance, at least for the many new sensors that appear or will appear, so I leave this gateway for the moment.
I would like to know how to recover the data of my sensors on an ESP (with ESPEasy V2 in) via mosquitto?
The only commands I know and need are,
To publish on the broker
- mosquitto_pub -h localhost -t "Test / Topic" -m "Hello ESP"
To subscribe to the broker
- mosquitto_sub -h localhost -v -t "Test / Topic"
Where to setup mosquitto in EasyESP?
Any help are welcome
V.V
Posted: 20 Sep 2019, 09:55
Posted: 20 Sep 2019, 10:16
by vidalv
Thanks, I've already a look on it :
- ESP_Publish.JPG (16.46 KiB) Viewed 24914 times
So where to place this ? (nothing in Devices to add Topic, Value) then on Tools as Command ?
Ok after search now new Page on ESPEasy :
- ESP_Rules.JPG (57.2 KiB) Viewed 24910 times
Any idea how to recover (in this example) under Win7 cmd prompt data send by ESP on MQTT ?
Posted: 20 Sep 2019, 11:02
by grovkillen
Posted: 01 Oct 2019, 22:32
by kimot
Use Domoticz with http.
Works perfectly with a large number of sensors too.
( cca 160 sensors in my case )
Both types - sending to Domoticz and receiving from it.
- 2019-10-01-221800_1920x1080_scrot.png (78.64 KiB) Viewed 24405 times
- 2019-10-01-223106_1920x1080_scrot.png (357.3 KiB) Viewed 24405 times
Posted: 01 Oct 2019, 23:12
by vidalv
I'm back, sorry, I was working on another topic, so in fact there are several things you need to be aware of.
In my config I use a PC / Win7, ESP8266 / ESPESAY V2.0 and sensors.
My broker is Mosquitto, so first you have to launch Mosquitto on a command window and make sure it stays active.
On the ESP the sensors are logged and declare with an Idx (Identifier) this identifier must be the same in Domoticz.
I even add switchs (As vitual sensor) that lights LEDs on the ESP.
When I have a little time I will make a document about the details of the system.
Thank you all for your support.
V.V
