Analog soil sensor
marktn
Analog soil sensor
#1 Post by marktn » 28 Oct 2019, 20:17
I have connected a Soil moisture sensor to my analog input.
It works in the ESP 8266, but the value that it sends to domoticz stays 0.
What to do?
Re: Analog soil sensor
#2 Post by TD-er » 28 Oct 2019, 22:25
What type of sensor did you define in Domoticz?
When in doubt, define a "custom" sensor in Domoticz.
marktn
#3 Post by marktn » 29 Oct 2019, 19:41
Auuww.. that was easy. I used Soil moisture, that didn’t work.
Now with the custom sensor it works perfect!
Is there a way to invert the analog value? 0 is the sensor under water, 100 is dry.
#4 Post by TD-er » 29 Oct 2019, 20:43
You can use the formula on the device configuration page.
I guess something like this would do:
100-%value%
marktn
#5 Post by marktn » 30 Oct 2019, 18:40
That doesn't work. Als no info the wiki.
#6 Post by TD-er » 30 Oct 2019, 22:40
marktn wrote:
30 Oct 2019, 18:40
Where do you enter the formula and what exactly do you enter there?
Have you also read this part? https://www.letscontrolit.com/wiki/inde ... asyFormula
I have to admit it isn't the best documentation, but if you look for "formula" on the wiki, you do find a number of examples.
marktn
#7 Post by marktn » 31 Oct 2019, 21:11
[/quote]
[/quote]
I have read that part of the wiki. I think a formula isn't possible to invert the analog signal.
Mark
Drum
#8 Post by Drum » 02 Nov 2019, 15:03
I could be wrong here, if the value is 100 for dry and 0 for water, could the formula not do something like 100 - value? 100 become 0 and 0 becomes 100
By the way which sensor is it? I am always looking for a better soil moisture sensor.
dynamicdave
#9 Post by dynamicdave » 02 Nov 2019, 15:08
I use the formula (1024-%value%)/100 in my soil monitor.
Here's a link to the tutorial guide.
http://resources-area.co.uk/node-red-fl ... sensor.pdf
On my set-up I'm using a small-signal transistor to switch the +3V3 rail on/off to the soil sensor (to reduce the effects of corrosion).
