Hello gurus,
I just bought myself an electric candlestick and I want to control it with a LUX sensor and a relay. The hardware is working and ESP Easy is up and running.
I basically want a rule that turns the relay on if it's dark and off if its daylight. However, how can I make sure that the relay is also off when I'm sleeping?
I can't figure out the syntax, but I want a rule like this:
If clock is between 06:00 and 22:30 and it is dark turn the relay on
If it is daylight, turn the relay off
If clock is between 22:30 and 06:00 turn the relay off
(My device is called lux#value and the relay turns on with gpio,12,1)
Any advice?
Best regards,
/David
Rule for LUX combined with CLOCK
Re: Rule for LUX combined with CLOCK
Think I solved it.
Used a dummy device to disable the lux sensor when I'm sleeping during the night.
Added 'Setpoint' so I can trigger the dummy manually via http
on Setpoint do
TaskValueSet 2,1,%eventvalue%
On Clock#Time=All,06:00 do
Taskvalueset,2,1,1
On Clock#Time=Sat,22:30 do
Taskvalueset,2,1,0
on lux#value<10 do
if [candlestick#dummy]=1
GPIO,12,1
GPIO,12,0
You can also use the sunrise and sunset calculations in rules.
For this you have to enter the GPS coordinates in the Advanced Settings. (do not have to be very accurate)
Here is my solution for turning the backyard light on and off without an LDR sensor using sunset and sunrise features with up-to-date startup checking. I use ESP-1s relay
on Time#Initialized do
GPIO,0,0
timerSet,1,5
On Rules#Timer=1 do
If %systm_hm% > %sunset+25m%
Gpio,0,1
timerSet,1,0
timerSet,2,1
Endif
On Rules#Timer=2 do
If %systm_hm% < %sunrise-25m%
Gpio,0,1
timerSet,2,0
timerSet,3,1
Endif
On Rules#Timer=3 do
If %systm_hm% > %sunrise-25m%
Gpio,0,0
timerSet,4,1
timerSet,1,1
Endif
On Rules#Timer=4 do
If %systm_hm% < %sunset+25m%
Gpio,0,0
timerSet,4,0
timerSet,1,1
Endif
On Clock#Time=All,%sunrise-25m% do
Gpio,0,0
On Clock#Time=All,%sunset+25m% do
Gpio,0,1
Users browsing this forum: Google [Bot] and 58 guests
