I have 2 ESP modules. 1 is working perfect with follow Piublish line in the RULE.
Publish milight/0xAAAE/rgb_cct/0,{"state":"ON", "brightness": 255}
Libraries ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
Bit now i have a second one and want do same RULE but different bulb
Publish milight/0xAAAF/rgb_cct/0,{"state":"ON", "brightness": 255}
Build:⋄ 20104 - Mega
System Libraries:⋄ ESP82xx Core 2.6.0-dev stage, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Tried everything but nothing will help to send the Publish line correct
When i do a publish using MQTT.fx then the brightness is working, and the publish is not using old command retained.
So it must be a problem in the ESP i guess
