OpenHAB MQTT not working
poudenes
#1 Post by poudenes » 09 Nov 2019, 15:22
Hi All,
I have 2 ESP modules. 1 is working perfect with follow Piublish line in the RULE.
Publish milight/0xAAAE/rgb_cct/0,{"state":"ON", "brightness": 255}
Build 20102 - Mega
Libraries ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
Bit now i have a second one and want do same RULE but different bulb
Publish milight/0xAAAF/rgb_cct/0,{"state":"ON", "brightness": 255}
But this ESP module keeps using a OLD retain message from my Home Assistant.
Build:⋄ 20104 - Mega
System Libraries:⋄ ESP82xx Core 2.6.0-dev stage, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Tried everything but nothing will help to send the Publish line correct
When i do a publish using MQTT.fx then the brightness is working, and the publish is not using old command retained.
So it must be a problem in the ESP i guess
Re: OpenHAB MQTT not working
#2 Post by TD-er » 09 Nov 2019, 16:50
Wrap the arguments in quotes, like this:
Publish milight/0xAAAF/rgb_cct/0,'{"state":"ON", "brightness": 255}'
I will add it to the documentation, since it is the Nth time I see issues like these. (N > 10)
poudenes
#3 Post by poudenes » 09 Nov 2019, 17:12
THANKS !!!! That did the job !!!!
Wiki
#4 Post by Wiki » 11 Nov 2019, 18:31
Works for
Publish domoticz/in,'{"idx":55,"nvalue":0,"svalue":"%uptime%"}'
,too.
Before wrapping in quotes the dataline received from MQQT was cut behind
"idx":55
Sasch600xt
#5 Post by Sasch600xt » 11 Nov 2019, 18:47
"Nth time I see issues like these. (N > 10)"
Hahahaha....you even coding by your answeres :) funny ike hell :)
Users browsing this forum: Bing [Bot] and 11 guests
