Help on rules for relay timers
Posted: 11 Nov 2019, 22:37
by _Cyber_
I am controlling with espeasy a 4-relay LC-Tech module with this plugin: viewtopic.php?f=6&t=3245
two of the 4 modules switch off an on different lamps for "dimming" the light.
I want to disable both of them after 2 hours running time, but independently.
I tried to write (my first - so please be indulgend) rules and it looks like I have a logic error anywhere, but failing in finding it.
the rules:
//Links heller
on WohnzimmerRelays#Relay1 do
  if [WohnzimmerRelays#Relay1]=1 and [Let#1] <= 0
    timerSet,1,20
    timerSet,7,1
    Let,1,20
  if [WohnzimmerRelays#Relay1]=0 and [Let#1] <= 0
    timerSet,1,0
    timerSet,7,0
    Let,1,0
on Rules#Timer=1 do
    relay,1,0
    Let,1,0
on Rules#Timer=7 do
  Let,1,[VAR#1]-1
  TimerSet,7,1
//Rechts heller
on WohnzimmerRelays#Relay2 do
  if [WohnzimmerRelays#Relay2]=1 and [Let#2] <= 0
    timerSet,2,20
    timerSet,8,1
    Let,2,20
  if [WohnzimmerRelays#Relay2]=0 and [Let#2] <= 0
    timerSet,2,0
    timerSet,8,0
    Let,2,0
on Rules#Timer=2 do
    relay,2,0
    Let,2,0
on Rules#Timer=8 do
  Let,2,[VAR#2]-1
  TimerSet,8,1
the effect: it works as long I only switch on one relay. as soon as I switch on the second the already running timer of the other one is restarted (currently at 20 instead of 7200). as soon as a timer switches one of the two relays, the other relay timer is resetted to 20.
Thank you for your time. :-)
BR
Alois
The live-log say's:
57606808: SerSW : SetSwitch r1:1
57608111: EVENT: Rules#Timer=7
57608131: ACT : Let,1,20.00-1
57608135: Command: let
57608138: ACT : TimerSet,7,1
57608141: Command: timerset
57610111: EVENT: Rules#Timer=7
57610130: ACT : Let,1,19.00-1
57610133: Command: let
57610136: ACT : TimerSet,7,1
57610139: Command: timerset
57612131: ACT : Let,1,20.00-1
57612134: Command: let
57612137: ACT : TimerSet,7,1
57612140: Command: timerset
57612157: EVENT: Rules#Timer=8
57612188: ACT : Let,2,20.00-1
57612191: Command: let
57612194: ACT : TimerSet,8,1
57612197: Command: timerset
57613112: EVENT: Clock#Time=Mon,21:27
57613143: EVENT: Rules#Timer=7
57613161: ACT : Let,1,19.00-1
57613164: Command: let
57613167: ACT : TimerSet,7,1
57613170: Command: timerset
57614111: EVENT: Rules#Timer=8
57614143: ACT : Let,2,19.00-1
57614146: Command: let
57614149: ACT : TimerSet,8,1
57614152: Command: timerset
57615130: ACT : Let,1,18.00-1
57615133: Command: let
57615136: ACT : TimerSet,7,1
57615139: Command: timerset
57615156: EVENT: Rules#Timer=8
57615186: ACT : Let,2,18.00-1
57615190: Command: let
57615193: ACT : TimerSet,8,1
57615195: Command: timerset
57617130: ACT : Let,1,17.00-1
57617133: Command: let
57617136: ACT : TimerSet,7,1
57617139: Command: timerset
57617157: EVENT: Rules#Timer=8
57617188: ACT : Let,2,17.00-1
57617191: Command: let
57617194: ACT : TimerSet,8,1
57617197: Command: timerset
57619130: ACT : Let,1,16.00-1
57619133: Command: let
57619136: ACT : TimerSet,7,1
57619139: Command: timerset
57619156: EVENT: Rules#Timer=8
57619186: ACT : Let,2,16.00-1
57619190: Command: let
57619193: ACT : TimerSet,8,1
57619196: Command: timerset
57621130: ACT : Let,1,15.00-1
57621133: Command: let
57621136: ACT : TimerSet,7,1
57621140: Command: timerset
57621157: EVENT: Rules#Timer=8
57621187: ACT : Let,2,15.00-1
57621191: Command: let
57621194: ACT : TimerSet,8,1
57621197: Command: timerset
57623130: ACT : Let,1,14.00-1
57623133: Command: let
57623136: ACT : TimerSet,7,1
57623139: Command: timerset
57623156: EVENT: Rules#Timer=8
57623186: ACT : Let,2,14.00-1
57623190: Command: let
57623193: ACT : TimerSet,8,1
57623196: Command: timerset
57625130: ACT : Let,1,13.00-1
57625134: Command: let
57625137: ACT : TimerSet,7,1
57625140: Command: timerset
57625157: EVENT: Rules#Timer=8
57625187: ACT : Let,2,13.00-1
57625190: Command: let
57625193: ACT : TimerSet,8,1
57625196: Command: timerset
57627112: EVENT: Rules#Timer=7
57627130: ACT : Let,1,12.00-1
57627133: Command: let
57627136: ACT : TimerSet,7,1
57627139: Command: timerset
57627156: EVENT: Rules#Timer=8
57627212: ACT : Let,2,12.00-1
57627215: Command: let
57627218: ACT : TimerSet,8,1
57627221: Command: timerset
57629132: ACT : Let,1,11.00-1
57629135: Command: let
57629138: ACT : TimerSet,7,1
57629141: Command: timerset
57629158: EVENT: Rules#Timer=8
57629188: ACT : Let,2,11.00-1
57629191: Command: let
57629194: ACT : TimerSet,8,1
57629197: Command: timerset
57631263: ACT : timerSet,8,1
57631266: Command: timerset
57631268: ACT : Let,2,20
57631272: Command: let
57631298: EVENT: WohnzimmerRelays#Relay3=1.00
57631329: SerSW : SetSwitch r1:0
57631331: ACT : Let,1,0
57631333: Command: let
57631666: WD : Uptime 961 ConnectFailures 0 FreeMem 29704
57633111: EVENT: Rules#Timer=8
57633144: ACT : Let,2,20.00-1
57633148: Command: let
57633151: ACT : TimerSet,8,1
57633154: Command: timerset
57635111: EVENT: Rules#Timer=8
57635143: ACT : Let,2,19.00-1
57635147: Command: let
57635150: ACT : TimerSet,8,1
57635153: Command: timerset
57637118: EVENT: Rules#Timer=8
57637151: ACT : Let,2,18.00-1
57637154: Command: let
57637160: ACT : TimerSet,8,1
57637164: Command: timerset
57639111: EVENT: Rules#Timer=8
57639143: ACT : Let,2,17.00-1
57639147: Command: let
57639150: ACT : TimerSet,8,1
57639152: Command: timerset
57641111: EVENT: Rules#Timer=8
57641143: ACT : Let,2,16.00-1
57641146: Command: let
57641150: ACT : TimerSet,8,1
57641153: Command: timerset
57643114: EVENT: Rules#Timer=8
57643146: ACT : Let,2,15.00-1
57643150: Command: let
57643153: ACT : TimerSet,8,1
57643160: Command: timerset
57645111: EVENT: Rules#Timer=8
57645143: ACT : Let,2,14.00-1
57645146: Command: let
57645149: ACT : TimerSet,8,1
57645152: Command: timerset
57647112: EVENT: Rules#Timer=8
57647143: ACT : Let,2,13.00-1
57647146: Command: let
57647150: ACT : TimerSet,8,1
57647153: Command: timerset
57649116: EVENT: Rules#Timer=8
57649148: ACT : Let,2,12.00-1
57649151: Command: let
57649157: ACT : TimerSet,8,1
57649161: Command: timerset
57651111: EVENT: Rules#Timer=8
57651143: ACT : Let,2,11.00-1
57651147: Command: let
57651150: ACT : TimerSet,8,1
57651153: Command: timerset
57652287: Command: timerset
57652290: ACT : timerSet,8,0
57652292: Command: timerset
57652294: ACT : Let,2,0
57652297: Command: let
57652311: EVENT: WohnzimmerRelays#Relay3=1.00
57652341: SerSW : SetSwitch r2:0
57652343: ACT : Let,2,0
57652346: Command: let
Re: Help on rules for relay timers
Posted: 17 Nov 2019, 10:15
by _Cyber_
anybody? :roll:
Posted: 17 Nov 2019, 15:07
by grovkillen
//Links heller
    timerSet,1,20
    timerSet,7,1
    Let,1,20
    Let,11,1
    timerSet,1,0
    timerSet,7,0
    Let,11,0
on Rules#Timer=1 do
    relay,1,0
    Let,11,0
on Rules#Timer=7 do
 If [VAR#11]=1
  Let,1,[VAR#1]-1
  TimerSet,7,1
 EndIf
//Rechts heller
    timerSet,2,20
    timerSet,8,1
    Let,2,20
    Let,12,1
    timerSet,2,0
    timerSet,8,0
    Let,12,0
on Rules#Timer=2 do
    relay,2,0
    Let,12,0
on Rules#Timer=8 do
If [VAR#12]=1
  Let,2,[VAR#2]-1
  TimerSet,8,1
  EndIf
Posted: 11 Dec 2019, 23:09
by _Cyber_
hi grovkillen,
thanks, but regrettably exact the same issue. on switching first relay 1 and after a few seconds relay 2 I can see in the log the timer of relay 1 beeing resetted to 20 .
2651339426: ACT : Let,12,0
2651339428: Command: let
2651339441: EVENT: WohnzimmerRelays#Relay3=0.00
2651339470: SerSW : SetSwitch r1:1
2651341111: EVENT: Rules#Timer=7
2651341133: ACT : Let,1,20.00-1
2651341136: Command: let
2651341140: ACT : TimerSet,7,1
2651341143: Command: timerset
2651341666: WD : Uptime 44189 ConnectFailures 0 FreeMem 29704
2651343112: EVENT: Rules#Timer=7
2651343133: ACT : Let,1,19.00-1
2651343136: Command: let
2651343140: ACT : TimerSet,7,1
2651343143: Command: timerset
2651345112: EVENT: Rules#Timer=7
2651345134: ACT : Let,1,18.00-1
2651345137: Command: let
2651345141: ACT : TimerSet,7,1
2651345145: Command: timerset
2651347111: EVENT: Rules#Timer=7
2651347133: ACT : Let,1,17.00-1
2651347136: Command: let
2651347140: ACT : TimerSet,7,1
2651347143: Command: timerset
2651349111: EVENT: Rules#Timer=7
2651349133: ACT : Let,1,16.00-1
2651349137: Command: let
2651349141: ACT : TimerSet,7,1
2651349144: Command: timerset
2651351112: EVENT: Rules#Timer=7
2651351133: ACT : Let,1,15.00-1
2651351136: Command: let
2651351140: ACT : TimerSet,7,1
2651351143: Command: timerset
2651353112: EVENT: Rules#Timer=7
2651353134: ACT : Let,1,14.00-1
2651353137: Command: let
2651353141: ACT : TimerSet,7,1
2651353144: Command: timerset
2651355112: EVENT: Rules#Timer=7
2651355133: ACT : Let,1,13.00-1
2651355136: Command: let
2651355140: ACT : TimerSet,7,1
2651355143: Command: timerset
2651357111: EVENT: Rules#Timer=7
2651357134: ACT : Let,1,12.00-1
2651357137: Command: let
2651357141: ACT : TimerSet,7,1
2651357144: Command: timerset
2651362133: ACT : Let,1,20.00-1
2651362136: Command: let
2651362140: ACT : TimerSet,7,1
2651362144: Command: timerset
2651362163: EVENT: Rules#Timer=8
2651362197: ACT : Let,2,20.00-1
2651362200: Command: let
2651362203: ACT : TimerSet,8,1
2651362206: Command: timerset
2651364134: ACT : Let,1,19.00-1
2651364137: Command: let
2651364141: ACT : TimerSet,7,1
2651364144: Command: timerset
2651364163: EVENT: Rules#Timer=8
2651364197: ACT : Let,2,19.00-1
2651364201: Command: let
2651364204: ACT : TimerSet,8,1
2651364206: Command: timerset
2651366112: EVENT: Rules#Timer=7
2651366133: ACT : Let,1,18.00-1
2651366139: Command: let
2651366146: ACT : TimerSet,7,1
2651366151: Command: timerset
2651366188: EVENT: Rules#Timer=8
2651366229: ACT : Let,2,18.00-1
2651366232: Command: let
2651366235: ACT : TimerSet,8,1
2651366239: Command: timerset
2651368165: ACT : Let,1,17.00-1
2651368168: Command: let
2651368172: ACT : TimerSet,7,1
2651368175: Command: timerset
2651368195: EVENT: Rules#Timer=8
2651368229: ACT : Let,2,17.00-1
2651368232: Command: let
2651368235: ACT : TimerSet,8,1
2651368238: Command: timerset
2651370133: ACT : Let,1,16.00-1
2651370137: Command: let
2651370141: ACT : TimerSet,7,1
2651370144: Command: timerset
2651370163: EVENT: Rules#Timer=8
2651370197: ACT : Let,2,16.00-1
2651370200: Command: let
2651370203: ACT : TimerSet,8,1
2651370206: Command: timerset
2651372133: ACT : Let,1,15.00-1
2651372136: Command: let
2651372140: ACT : TimerSet,7,1
2651372143: Command: timerset
2651372162: EVENT: Rules#Timer=8
2651372197: ACT : Let,2,15.00-1
2651372200: Command: let
2651372203: ACT : TimerSet,8,1
2651372206: Command: timerset
2651374134: ACT : Let,1,14.00-1
2651374137: Command: let
2651374141: ACT : TimerSet,7,1
2651374144: Command: timerset
2651374163: EVENT: Rules#Timer=8
2651374197: ACT : Let,2,14.00-1
2651374200: Command: let
2651374203: ACT : TimerSet,8,1
2651374206: Command: timerset
2651376133: ACT : Let,1,13.00-1
2651376136: Command: let
2651376140: ACT : TimerSet,7,1
2651376143: Command: timerset
2651376162: EVENT: Rules#Timer=8
2651376197: ACT : Let,2,13.00-1
2651376200: Command: let
2651376203: ACT : TimerSet,8,1
2651376206: Command: timerset
2651378134: ACT : Let,1,12.00-1
2651378138: Command: let
2651378142: ACT : TimerSet,7,1
2651378145: Command: timerset
2651378163: EVENT: Rules#Timer=8
2651378198: ACT : Let,2,12.00-1
2651378201: Command: let
2651378204: ACT : TimerSet,8,1
2651378206: Command: timerset
2651380133: ACT : Let,1,11.00-1
2651380137: Command: let
2651380141: ACT : TimerSet,7,1
2651380144: Command: timerset
2651380163: EVENT: Rules#Timer=8
2651380198: ACT : Let,2,11.00-1
2651380201: Command: let
2651380204: ACT : TimerSet,8,1
2651380207: Command: timerset
2651381272: Command: timerset
2651381274: ACT : Let,2,20
2651381277: Command: let
2651381280: ACT : Let,12,1
2651381283: Command: let
2651381310: EVENT: WohnzimmerRelays#Relay3=0.00
2651381341: SerSW : SetSwitch r1:0
2651381343: ACT : Let,11,0
2651381346: Command: let
2651383112: EVENT: Rules#Timer=8
2651383155: ACT : Let,2,20.00-1
2651383158: Command: let
2651383162: ACT : TimerSet,8,1
2651383165: Command: timerset
2651385112: EVENT: Rules#Timer=8
2651385147: ACT : Let,2,19.00-1
2651385151: Command: let
2651385154: ACT : TimerSet,8,1
2651385157: Command: timerset
2651387113: EVENT: Rules#Timer=8
2651387149: ACT : Let,2,18.00-1
2651387152: Command: let
2651387155: ACT : TimerSet,8,1
2651387158: Command: timerset
2651389113: EVENT: Rules#Timer=8
2651389165: ACT : Let,2,17.00-1
2651389168: Command: let
2651389171: ACT : TimerSet,8,1
2651389174: Command: timerset
2651391112: EVENT: Rules#Timer=8
2651391148: ACT : Let,2,16.00-1
2651391151: Command: let
2651391154: ACT : TimerSet,8,1
2651391157: Command: timerset
2651393112: EVENT: Rules#Timer=8
2651393147: ACT : Let,2,15.00-1
2651393150: Command: let
2651393153: ACT : TimerSet,8,1
2651393156: Command: timerset
2651395111: EVENT: Rules#Timer=8
2651395167: ACT : Let,2,14.00-1
2651395170: Command: let
2651395173: ACT : TimerSet,8,1
2651395176: Command: timerset
2651397112: EVENT: Rules#Timer=8
2651397147: ACT : Let,2,13.00-1
2651397150: Command: let
2651397153: ACT : TimerSet,8,1
2651397156: Command: timerset
2651399112: EVENT: Rules#Timer=8
2651399147: ACT : Let,2,12.00-1
2651399150: Command: let
2651399153: ACT : TimerSet,8,1
2651399156: Command: timerset
2651401111: EVENT: Rules#Timer=8
2651402144: ACT : relay,2,0
2651402149: EVENT: WohnzimmerRelays#Relay0=0.00
2651402182: EVENT: WohnzimmerRelays#Relay1=0.00
2651402208: ACT : timerSet,1,0
2651402211: Command: timerset
2651402214: ACT : timerSet,7,0
2651402217: Command: timerset
2651402219: ACT : Let,11,0
2651402222: Command: let
2651402327: Command: timerset
2651402330: ACT : timerSet,8,0
2651402333: Command: timerset
2651402335: ACT : Let,12,0
2651402337: Command: let
2651402351: EVENT: WohnzimmerRelays#Relay3=0.00
2651402384: SerSW : SetSwitch r2:0
2651402386: ACT : Let,12,0
2651402389: Command: let
Posted: 12 Dec 2019, 03:28
by ThomasB
There is an explanation for the problem by enesbcs posted here:
viewtopic.php?p=19650#p19650
TLDR; To summarize, you shouldn't rely on the P165 plugin's Relay states to trigger the rules.
I suggest using the "Generic - Dummy Device" plugin and create two variables that represent the two relays. Write your rules so they use the dummy's states instead of the P165 Relay states.
Posted: 20 Dec 2019, 19:38
by enesbcs
_Cyber_ wrote: 11 Nov 2019, 22:37
Did you try to use conditional checking for example:
on WohnzimmerRelays#Relay1>0 do
Instead of this?
Posted: 20 Dec 2019, 19:43
by enesbcs
ThomasB wrote: 12 Dec 2019, 03:28 There is an explanation for the problem by enesbcs posted here:
It's right but that post refers to the Sonoff Dual (and also Tuya) submodul. By the way the LCTech does not provide feedback about the relay statuses, it is only written once by this plugin.
